Like Tree3Likes
Old 10-17-2009, 01:32 AM   #6841
veecee's Avatar
Trader Rating: 34 (100%+)
Pics of Marc's 416X at ETS... Check how close the spur is to the rear diff pulley now!
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 10-17-2009, 02:12 AM   #6842
looks like he is using the 5*8mm ballconnectors in steel (or just black alu..)
where do i find the ball connectors in steel if the are availible? part number? (tired of being scared of them breaking when i get hit or hits someone)
Hatebreed is offline   Reply With Quote
Old 10-17-2009, 04:59 AM   #6843
veecee's Avatar
416X takes 1st round of qualifying at ETS!!!
Old 10-17-2009, 05:48 AM   #6844
Jackster's Avatar
Trader Rating: 19 (100%+)
Home : Go Shop at Speed Tech : Race Cars, Buggies, & Trucks : Electric Touring Cars
New! Tamiya TRF416X Competition Kit
The holidays are approaching again, and that can only mean one thing... A new Tamiya high end tourer... the TRF416X. Coming December 2009.
Jackster is offline   Reply With Quote
Old 10-17-2009, 06:35 AM   #6845
syndr0me's Avatar
Trader Rating: 32 (100%+)
53969 - 5x8 steel
53968 - 5x5 steel
In the steering assembly, I like to use the fluorine coated pieces that are also used as the "kingpins." They seem longer yet, and don't bend easily.
syndr0me is offline   Reply With Quote
Old 10-17-2009, 10:02 AM   #6846
syndr0me's Avatar
Looks like the Tamiya boys are getting it figured out at ETS. Interesting LiPo chassis from SpeedPassion for the 416. I'd love to see someone make one that would let us reverse the belts like the other cars are doing so you can move electronics closer to the center.
Old 10-17-2009, 02:32 PM   #6847
Xray T3
COPIED FROM REDRC about the T3
Front & rear diffs and transmission belts can be quickly & easily oriented to either the left or right side to balance the car for either LiPo or NiMH use
AND THE LINK
REDrc
sidecarphil1 is offline   Reply With Quote
Old 10-17-2009, 03:59 PM   #6848
syndr0me's Avatar
Originally Posted by sidecarphil1 View Post
Xray T3
AND THE LINK
REDrc
Yeah, that's a nice new feature of the T3. It's good enough for, what, 6th overall so far at ETS?
Old 10-17-2009, 08:00 PM   #6849
JimmyMac's Avatar
Haven't the TC5 guys been flipping their belts/diffs for awhile now? Not really for lipo reason, but the've been doing it for some time to have easier access to their pinions.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 10-18-2009, 08:16 AM   #6850
Stein Tumert's Avatar
Yeah, looks like the 416 with LiPo was good enough for the win...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 10-18-2009, 01:40 PM   #6851
There are alot of ideas about LIPO batteries regarding weight, chassis balance, battery position but I think the best solution is to put weights in the chassis cut outs and glue them to the battery. This was also seen on many cars at the ETS race this weekend.
Here is a proposal with Tungsten weights that have 60% more density than lead. This LIPO battery has the same weight as a 5 cell Nimh.
http://supertec.wordpress.com/2009/0...ipo-batteries/
Tamiya TRF416 / TRF416WE / TRF416X-robitronic-lipo.jpg
moonman is offline   Reply With Quote
Old 10-18-2009, 02:28 PM   #6852
syndr0me's Avatar
That's been my preferred method for a couple of years now. Since you don't have to shove a plate under the battery, you can still run the big packs and have them clear the top deck. I find shoo goo works well to secure the weights, as well as "carpet tape" since it's paper thin. Tungsten is definitely a good option, though I prefer to have some of my weight on the side of the pack to achieve proper ballast. So, I use stainless weights on the underside of the pack (usually just 4) and tungsten on the outside edge to help balance the car.
I was getting my stainless plates here, though they've been out of stock for a while now.
Old 10-18-2009, 02:58 PM   #6853
TryHard's Avatar
Well... technicallly, thats the WE with the X prototype bits... Looks like Wilck was running the same at the ETS too, with only Marc having a full blown X.
Easily disitingusihable by the topdeck screws at the rear...
Still, shows the Tamiya's work ubber well on the rug I keep getting told I have a cheater car...
| THard.co.uk | Xray | MuchMore |
Old 10-18-2009, 03:08 PM   #6854
TryHard's Avatar
I did the same last year. Found some 2mm thick lead roof flashing in my grandparents garage, so half-inched it :P Cut out the strips required, and mounted them under the pack with servo tape. Nice and easy
On another point entirely... I'm not convinced that flipping the belts over is needed. My reasoning is that the two heaviest electrics components (motor & Servo) can't be moved... so only moving the lighter components in isn't going to be such a help. Also, if your running a tall speedo, you'll only be able to get it in far enough to touch the top deck, which is a small gain over unflipped belts.
Fair enought the reciever can be moved a fair way, but even then, thats less than 10g (6.5g for the spektrum pro I'm using) moving closer to the centre, which will make naff all difference, because it's so close to the centreline already (thinking levers and moments here). So, IMO, is it needed? Nope...
Old 10-18-2009, 03:17 PM   #6855
syndr0me's Avatar
I've had the 416 since before it was available in the states, and am now on my 3rd kit... none have ever had the misfortune of seeing an NiMH. I agree it's likely not needed, it just seemed like it would be something interesting to try. It seems like the TRF team was able to overcome in spite of their old belt layout!
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
