Like Tree3Likes
Old 10-09-2009, 12:17 PM   #6781
Johnny Wishbone's Avatar
I have to be blind......I still can't see the wider front top deck spacing, can someone explain what I'm looking for, totally missed the bus on this one.
Old 10-09-2009, 12:43 PM   #6782
syndr0me's Avatar
Trader Rating: 32 (100%+)
Nah, I'm with you. I've spent a few minutes looking at the pics a few times now, and I feel like I'm looking at my WE. I suppose it's quite a testament to the longevity of the original design. Hell, my WE has the chassis and top deck from the original kit anyway.
syndr0me is offline   Reply With Quote
Old 10-09-2009, 01:52 PM   #6783
linger's Avatar
I don't know about wider, maybe something got lost in the translation.
It does look like the front bulkhead to chassis mount is moved more rearward.
Not enough difference to justify dumping my current 416 for the new one.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 10-09-2009, 02:56 PM   #6784
artwork's Avatar
Trader Rating: 62 (100%+)
Agree, I just got my 416WE and even before I received it the 416X was announced. I just cannot see what all of the fuss is about. The 416WE is a great car and until I need a new car I will not be making the switch. I get really excited when new cars come out, but in this case I just don't see any radically improved pieces to justify the change. Maybe when they hit the streets and my buddy Syndrome pulls the trigger on one I can check it out, until then I am still getting to know my new ride and excited to be part of the Tamiya sickness!
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is online now   Reply With Quote
Old 10-09-2009, 03:22 PM   #6785
syndr0me's Avatar
Is there something going on with the ends of the bulkheads where the sway bars mount? It doesn't look flush like the existing kits.
Old 10-09-2009, 03:32 PM   #6786
That picture is not very good, I think my eyes are going bad trying to find the little changes.
I went back several pages and I think Ed picked out the fact that the F/R suspension bridge is closer to the back part of the "foot" of the front bulkhead, took a long time to see it, and its harder to see without one in yer hand to compare it to. I just wonder if that means the for/aft wheelbase adjustment has been changed and the F/R bridge location has been moved forward, wonder if thats to try and help the weak point of the bent bridge and screws on hard impact, although it goes aginst the flow of most impacts. Just wild speculation on my part.
If I cant bolt the new motor mount to my car I think I'll just get the 1mm milled of the stock piece and run that way for a while.
Old 10-09-2009, 04:20 PM   #6787
Hebiki's Avatar
Trader Rating: 26 (100%+)
the "X" isnt sporting the new "split" suspension blocks.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 10-09-2009, 04:31 PM   #6788
veecee's Avatar
Trader Rating: 34 (100%+)
"Wider front bulkhead attachment screw positions and a new lower deck shape enhance the chassis' front rigidity"
So it's a different front lower bulkhead with mounting points that are further apart. You can also see in the RC-Japan chassis pic that there are spare holes for the current front lower bulkheads.
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 10-09-2009, 04:35 PM   #6789
veecee's Avatar
I agree the differences are very subtle. Not sure if someone of my ability can really tell the difference... So I might give it a miss as well.
Old 10-09-2009, 05:05 PM   #6790
haywood's Avatar
Trader Rating: 48 (100%+)
Yes,I agree also.I wish at some point they would make the step to design the car with lipo in mind.Nihms are dead in my neck of the woods.
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 10-09-2009, 05:24 PM   #6791
...pics above are very similar to the 416WE.
Tamiya TRF416 World Edition
exotica is offline   Reply With Quote
Old 10-09-2009, 05:35 PM   #6792
here are some pics of the 416X chassis kit and a list of the real differences you will find compared to the 416WE.
Specs & Features
Motor position has been shifted 1mm to center for optimum chassis balance.
Rear ball differential has been shifted 1.8mm towards the rear to improve rear traction and acceleration. Rear ball differential has been shifted towards the rear 1.8mm To improve rear traction and acceleration.
Wider front bulkhead attachment screw positions and a new lower deck shape enhance the chassis' front rigidity. Wider front BULKHEAD attachment screw positions and a new lower deck shape enhance the chassis' front rigidity.
Features new carbon 2.25mm lower and 2mm upper decks. New Features 2.25mm Carbon 2mm upper and lower decks.
Front pulley features a direct coupling while the center pulley also features a direct drive setup. Front pulley features a direct coupling pulley while the center also features a direct drive setup.
Newly designed parts such as lower and upper decks, rear drive belt, front and rear lower bulkhead, motor mount, center bulkhead, and motor mount support included. Newly designed parts such as lower and upper decks, rear drive belt, front and rear lower BULKHEAD, motor mount, BULKHEAD center, and motor mount support included.
Requires body, R/C unit, battery, motor, pinion gear, tires, and wheels (sold separately).
Old 10-09-2009, 07:30 PM   #6793
sonic31's Avatar
man im a serious whore when it comes down to the 416 but hanging on to my 416we seems like the logical choice right now even with the subtle improvements done to the 416x. now that lipo is legal for ifmar that means to me that further chassis design changes are inevitable mr. anderson(haha) exotek seems to be on par with that by the lipo chassis' they make for the tc5 and cyclone so i think to wait longer would be wise.
what say ya'll
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 10-09-2009, 07:37 PM   #6794
fat500's Avatar
Trader Rating: 29 (100%+)
perfect "c" you got that spx yet sucker
fat500 is offline   Reply With Quote
Old 10-09-2009, 07:41 PM   #6795
sonic31's Avatar
im gonna put that spx right up ur cars ass
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
