Old 10-03-2009, 08:39 AM   #6736
i normally set the car on the droop blocks and then move the left arm up to see how far it moves the right , measuring with a set of vernier calipers to see how far up it moves
then repeat on the other side and make them evan
sidecarphil1 is offline   Reply With Quote
Old 10-03-2009, 09:54 AM   #6737
Johnny Wishbone's Avatar
I use my droop gauge to set the sway bars. With all the tires off and the car on a flat surface. I lift one side arm up till the opposite side just starts to lift, as I'm lifting that side up, I use the stub axle and let it hook the steps built into the droop guage, taking note of which step its on when the other side just starts to lift. Then I'll do the same thing on the other side and locate the stub axle on the height that the other side had movement and adjust the lock on the link of the bar so I get the same opposite arm lift. I should mention that the droop gauge is stood on end and not flat like you would normally use the guage.
Old 10-03-2009, 12:40 PM   #6738
linger's Avatar
Originally Posted by Korey Harbke View Post
This is true. Chris blows all the time!
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 10-03-2009, 01:05 PM   #6739
Trader Rating: 26 (100%+)
do the stock reartic carriers have any toe built into them.
eddie10 is offline   Reply With Quote
Old 10-03-2009, 04:18 PM   #6740
veecee's Avatar
Trader Rating: 34 (100%+)
With the swaybars, which link do you adjust when one side is moving more than the other? And do you shorten that link or lengthen? It seems whatever I do, it never seems to make much difference...
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 10-03-2009, 05:24 PM   #6741
Thats why I like the guage method, once one side is locked on the step you can shorten or lengthen or move the link for and aft to get the adjustment your looking for. Normally the two links should be roghly the same length and then its just a matter of moving the link up and down the bar to get the reaction your looking for.
Remember that if one link is longer than the other it will change the roll rate from one side to the other.
Old 10-04-2009, 03:52 PM   #6742
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
Congrats to young Austin Vacek on his 2nd overall @ Stock Asphalt Nats!!! Way to go kid, i miss the old days of tryin to stay on the same lap as you heh. To think u'll only get faster in time...will ur Dad and Unc be able to keep up with their increased mechanic's duties .
R
UltegraSTI is offline   Reply With Quote
Old 10-04-2009, 11:20 PM   #6743
Korey Harbke's Avatar
Originally Posted by linger View Post
See, that's just mean lol
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 10-04-2009, 11:24 PM   #6744
Hebiki's Avatar
ling is a very mean person.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 10-05-2009, 05:57 AM   #6745
veecee's Avatar
Here's an updated setup running a 6.5 brushless. I might need to gear it up slightly as it hits top speed pretty quickly. The car feels very nice to drive in general and I'm getting more consistent in hitting my braking points with a 6.5. I've been running 10.5 up until now and will probably try mod this weekend and see how I go. I'll run the 6.5 until I'm confident and turning consistent laps before I try a faster motor.
This setup is well balanced and very stable in general. But it can get twitchy when changing direction very quickly under full lock. This is usually when I've overdriven the car and get my line wrong entering a fast chicane. I actually don't mind that as the car handles great and give me lots of steering which I like. But I might change the rear to an E block and see if it compromises the overall feel. Honestly though, I just need to drive better...
Old 10-05-2009, 11:10 AM   #6746
This setup is well balanced and very stable in general. But it can get twitchy when changing direction very quickly under full lock. This is usually when I've overdriven the car and get my line wrong entering a fast chicane. I actually don't mind that as the car handles great and give me lots of steering which I like. But I might change the rear to an E block and see if it compromises the overall feel. Honestly though, I just need to drive better...[/QUOTE]
Are you running outdoor or indoor?
Ramyuras is offline   Reply With Quote
Old 10-05-2009, 02:48 PM   #6747
veecee's Avatar
It's med/high grip asphalt outdoor.
Old 10-05-2009, 06:58 PM   #6748
miccal's Avatar
Trader Rating: 23 (100%+)
Is anyone like RC Champ or RainbowTen taking pre-orders for the TRF416X yet?
miccal is offline   Reply With Quote
Old 10-05-2009, 07:02 PM   #6749
chrisk's Avatar
Trader Rating: 32 (100%+)
RC-Champ is
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 10-05-2009, 07:04 PM   #6750
Vicko's Avatar
Trader Rating: 14 (100%+)
is there any pricing on the X yet?
Vicko is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
