Like Tree3Likes
Old 09-24-2009, 07:01 AM   #6676
auzzy_mate's Avatar
Originally Posted by Hatebreed View Post
what spurgears and pinions are you using in the 17.5 class? (48DP)
i`m going do race with a speed passion 17.5, any suggestions where i should start in gearing? (driving on a medium size carpet track)
64 SPUR - 36 PINION
SXX ESC / SP17.5 motor
Ben
auzzy_mate is offline   Reply With Quote
Old 09-24-2009, 06:44 PM   #6677
Trader Rating: 26 (100%+)
im looking for a good neutral starting setup for rubber tire carpet medium size track?
eddie10 is offline   Reply With Quote
Old 09-24-2009, 06:57 PM   #6678
tandman's Avatar
Send a message via Yahoo to tandman
Hey guys, I ordered my kit and most spares today from Speetech. I am still looking for a couple things;
46mm steel axles and JAAD thrust bearings. If someone can direct me to an online store that would be cool. Also, if I want to run a diff in the front , what axel lenght should I use?
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks Team Canada
tandman is offline   Reply With Quote
Old 09-24-2009, 07:14 PM   #6679
veecee's Avatar
Trader Rating: 34 (100%+)
I think syndr0me has a pretty good setup from the IIC. Have a look a few pages back or do a search on his posts.
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 09-24-2009, 07:48 PM   #6680
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
How are we stickin foam tires on this car?
I assume a different brand spindle carrier...
KB
OUT
Keith Billanti is offline   Reply With Quote
Old 09-24-2009, 08:09 PM   #6681
SammyZ's Avatar
Trader Rating: 138 (100%+)
KB
yeah i had to shave a ton of material from the steering knuckle to clear a
28mm foam tyre. But the car doesn't work for some reason with foams?
I couldn't get consistent droop settings, the car just acted wierd.
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 09-24-2009, 08:09 PM   #6682
SammyZ's Avatar
also the Square aluminum knuckle has a good fit with 28mm foams
if you go that route.
Hotbodies USA
SweepRacing USA
Old 09-24-2009, 08:12 PM   #6683
syndr0me's Avatar
Trader Rating: 32 (100%+)
I need to post it still. Haven't really touched my stuff since getting back.
syndr0me is offline   Reply With Quote
Old 09-24-2009, 08:33 PM   #6684
Johnny Wishbone's Avatar
If your going to run a front diff you can get away with the 42mm axles, usually only run the 46mm axles when using a spool as the short axle seems to break the nylon spool cups, (pin out to far in the cup), since the diff would use pin cushions it shouldn't be a problem. Soory, no idea about where to get the parts, maybe rcmarket, but shipping is expensive for a small order like that. Try Ampdraw, in the US, they have a lot of Tamiya parts too.
Old 09-24-2009, 08:41 PM   #6685
Go to Tryhards site, and use Oli Meggitt setup from Southend-indoor,or Corey Whiteman setup from Fastcats Grandslam, either on are very good starter setups and then fine tune from there. If traction is higher go to 1mm sus mount spacers over the .5mm ones and maybe adjust the rear toe according to what the car is doing. Either the XA/D or the XA/E tune for preference. Also if you want a little quicker turn in try a C/C front mount instead of the D/D, again depends on how high the traction is.
Syndrome started with Coreys setup and tuned from there, his car looked really good at the IIC.
Old 09-24-2009, 08:41 PM   #6686
JimmyMac's Avatar
46mm bones seem to be hard to find. I think Tamiya discontinued the part number from the EvoIV... but.... I'm not sure if this is correct, but I think maybe they opened up another part number for it as maybe a TA05 Ver II part number? I can't remember where I seen it. I'll surf around and see if I can't find it.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 09-24-2009, 08:44 PM   #6687
KB
When running foam we used to cut the front wheel width down to 26mm and sometimes 24mm. A real pain in the butt, but worth the effort.
Old 09-24-2009, 08:46 PM   #6688
JimmyMac's Avatar
Try this. http://www.rcmart.com/catalog/rc-ta0...7-p-15054.html
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 09-24-2009, 08:50 PM   #6689
I didn't keep the package that the 46s came in, I actually picked up a package that had 46 steel axles, 42 aluminum axles, the pins, float pins, setscrews and outdrives, since all my stuff was pretty worn out anyway. I don't think the outdrives are the exact replacements, but would work in a pinch and was chaeper than buying each piece seperately.............just sucks I don't have the number, got it from Ampdraw though.
Old 09-24-2009, 08:50 PM   #6690
JimmyMac's Avatar
Or this... http://www.rc-mushroom.com/product_i...oducts_id=6879
Or this... http://www.rc-mushroom.com/product_i...oducts_id=6905
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
