Tamiya TRF416 / TRF416WE / TRF416X
#6661
I had mine for almost 2 years but maybe I don't run as often as you guys. So I figured it was worth it.
#6662
Hi again guys, when you put the 46mm steel driveshafts in the front to accomodate the spool does the standard wheel axles fit ok with these or do i need to change them. Thanks in advance....
Scotty
Scotty
#6664
i want a slightly bigger front bumper and remember reading there is one for the TRF
who makes it and where can i get one ??
#6667
the 416we, are the stock springs the white ones or the milky blue. i want to order the remaining so i have a complete set.
#6669
is that the set to get or the solid colored or milky blue sets.
#6670
The kit ones are white, so it depends if you want the extra springs to colour match? In terms of performance, there should be no difference between the whites and milky blues. If you race asphalt, consider getting HPI Pro 4 silver and blue springs.
#6671
what spurgears and pinions are you using in the 17.5 class? (48DP)
i`m going do race with a speed passion 17.5, any suggestions where i should start in gearing? (driving on a medium size carpet track)
#6672
yep
Mark M
#6674
i bought the milky blue coloured ones and i also bought the TA05 milky blue set of roll bars cos i think they look the nuts
i also bought the silver and gold HPi springs for outdoors racing
#6675
Bottom line..Get the whole set.U might need it.
