Old 09-20-2009, 12:14 PM   #6646
i had a race today indoors
first one of the year
it went well 1st final i got hit and it broke a spool outdrive then i started out last in the 2nd and finished 4th started the next final in 4th and again got hit in the first corner !! busted again !!
started from the rear again in the 4th final and ended 4th and in the last final i started again from the rear of the grid ( safest option i thought ) and finished 2nd
sidecarphil1 is offline   Reply With Quote
Old 09-20-2009, 03:47 PM   #6647
veecee's Avatar
Trader Rating: 34 (100%+)
Nice work mate! It's always hard starting from the middle of the grid. Indoor would be even worse...
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 09-20-2009, 03:50 PM   #6648
SammyZ's Avatar
Trader Rating: 138 (100%+)
congradulations mate! What did you break when you started the final in 4th?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 09-20-2009, 05:00 PM   #6649
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by reenmachine View Post
So was the air duct a bad idea or something? How come it's not in the WE kit? There's not much there to mount the speedo to -- what do you guys do?
I've never run the air duct, but even without it, there is plenty of material to mount the ESC to, I have never had one come loose and they are still a pain to pry off of the chassis.
Old 09-20-2009, 05:06 PM   #6650
I got a chance to race yesterday at a smaller track that I haven't been to in a while. Gotta say it's the first time in a long time that I really struggled on the setup, just never was able to get dialed in. I think it's time for a full rebuild on my car, too many parts getting sloppy Still managed to salvage 2'nd place, had to hold off about 5 or 6 seperate attacks in order to keep the position, Barry Baker got a great start and drove clean and won by a mile.
Old 09-20-2009, 06:30 PM   #6651
syndr0me's Avatar
Trader Rating: 32 (100%+)
What surface? What was the car doing wrong?
syndr0me is offline   Reply With Quote
Old 09-20-2009, 06:39 PM   #6652
Asphalt. The car didn't really do anything wrong, it just wasn't nearly as good as it usually is. I'm going to strip it down to the chassis and rebuild the car completely, I have a feeling just too many parts are worn out on it right now.. I've been lazy
I was using the Mazda 6, but I feel like the Mazdaspeed 6 would have been a better choice. I meant to pack it, but totally forgot, lol.
Old 09-20-2009, 09:44 PM   #6653
SammyZ's Avatar
has anybody experienced bending/breaking of the stock
aluminum ball studs and turnbuckles?
Hotbodies USA
SweepRacing USA
Old 09-20-2009, 09:51 PM   #6654
veecee's Avatar
Yep, I've bent the ackerman ones before and changed them to steel. Also bent steering turnbuckles and changed them to titanium.
Old 09-20-2009, 10:14 PM   #6655
sudhar93's Avatar
Send a message via MSN to sudhar93
So far ive only bent the steering linkage once.
Tamiya-LRP - Team Powers - RIDE -Sorex -Protoform - Sweep -Futaba - GQ
-------------Car Needs Minor Tuning, Driver Needs Major Tuning -------------
sudhar93 is offline   Reply With Quote
Old 09-20-2009, 10:34 PM   #6656
another spool outdrive
i also spoke with another tamiya driver and he advised using the 46mm steel shafts
which i did and from then on it was plain sailing , but i was soooooo nervous on the drivers stand holding off the guys behind me , they were quicker than me but didn't force past , it was nice and clean racing
i honestly thought i was going to shit my self stood on the drivers stand , it is my best every result , and on carpet which i have never raced on before only practiced at our local tiny indoor track
Old 09-21-2009, 05:11 AM   #6657
Yeah during a sideways barrier swipe i managed to turn one of the rear ally turnbuckles into a U shape!
I have steel ones on the rear now.
_____________________
"To finish first, first i must finish!"
www.mkrctc.org.uk
www.akularacing.co.uk
Toblerone is offline   Reply With Quote
Old 09-21-2009, 05:24 AM   #6658
veecee's Avatar
Yeh a rebuild every now and then is good. I did mine a couple of weeks ago and found some things I wouldn't have otherwise - eg a slightly bent hinge pin. No idea how long I've been running with that as I haven't broken an arm for a while... Also replaced all the plastic shock parts and worn ball nuts/studs with some fluorine coated items. While I was at it, I put in some foam washers like the offroaders do. Hopefully this will make the ball nuts/studs will last longer. Also replaced a set of shock shafts after the nitride coating wore through. I'm now itching to get this baby back onto the track!
Old 09-21-2009, 06:46 AM   #6659
SammyZ's Avatar
i noticed the coating on my new shock shafts wore off after maybe 20 runs. Im not going to replace them again this time as I did not notice any difference, except i was out $12
Hotbodies USA
SweepRacing USA
Old 09-21-2009, 09:20 AM   #6660
+1
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
