Like Tree3Likes
Old 09-14-2009, 02:20 AM   #6556
kentech's Avatar
Default TRF416X
Based on what's posted on the TRF site today
http://www.tamiya.com/trf/
rear diff moved back
motor moved 1mm in
Japan version with front & center one-way
Export version with spool
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 09-14-2009, 02:26 AM   #6557
just ordered myself a 416we (dont think that the X would make me much of a better driver than the existing version anyway )
what 48dp spur do you recommend for the car?
and i`m planning to try the 17.5 class on carpet, any recomendations on gearing? (orion and speed passion 17.5) will be driving on carpet with rubber tires
Hatebreed is offline   Reply With Quote
Old 09-14-2009, 02:32 AM   #6558
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by entitymugenmtx View Post
OK guys Im all done with my car and now Im stuck on a Lipo. I was looking at the SMC 5200 50C I wanted to see if anyone is running this lipo, and if so does it just fit right in?
thanks David
It's a good lipo but you'll need a lipo tray to run it because it's too high, or you could go a smaller capacity.
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 09-14-2009, 03:27 AM   #6559
veecee's Avatar
motor moved 1mm in
Nice one kentech! Hope Champ will have the export versions...
Not sure about 17.5 but I use a 72T (with 31T pinion for 10.5). Maybe something between 63-69T?
SMOKEM --- XPRESS --- HIRO SEIKO
veecee is offline   Reply With Quote
Old 09-14-2009, 06:43 AM   #6560
hi all
i have a TRF416we and just about to buy the 2.5mm chassis for the winter indoor season
A is it worth it ??
B will the normal 2.5mm chassis fit the World Edition alloy parts ??
part No is 49495
sidecarphil1 is offline   Reply With Quote
Old 09-14-2009, 08:24 AM   #6561
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by sidecarphil1 View Post
hi all
A is it worth it ??
part No is 49495
The chassis will work with the WE parts without any problems. Please also take into account that it does move the batts back about 5mm, this will make the car slightly more aggressive. If you are running rubber tires, the WE chassis will work fine unless your track is tight and has a lot of bite.
Old 09-14-2009, 09:31 AM   #6562
am i better saving my money then ??
i thought for 35 it was a good buy for indoors
+ YouTube Video
this is where i am racing at the weekend , and ideas on set up ??
Old 09-14-2009, 04:38 PM   #6563
Originally Posted by jonest View Post
The major diff between a 416WE v 416 are the followings:-
1) Lower Deck - battery position move forward (about 5mm)
2) Single piece upper deck
3) Redesigned motor brace (slightly tougher)
4) Front toe block c/w kit (1C + 1C)
5) Rear toe block c/w kit (1XA + 1F; 3.5 deg)
Sugg to get the following as fine tuning
1) 1D + 1E toe block (Rear)
2) Ti turnbuckle (Front Upper link)
3) WE wheel lock nuts
Sugg to get the following as spares
1) Arm + Knuckle + C-Hub + Belts + Spool Cups
thanks what about bearings, shims and screws?
Titanum28 is offline   Reply With Quote
Old 09-14-2009, 05:59 PM   #6564
haywood's Avatar
Trader Rating: 48 (100%+)
Default Las Vegas
I thought Marc and Jiles were to be in Vegas for IIC 09, were they not?
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 09-14-2009, 06:05 PM   #6565
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
For some reason Tamiya wouldn't approve the trip for the team guys. Was truly the biggest let down of the week. (nothing scotty or even marc and Jilies could of done about it). Was great watching those guys last year.
Dustin Layne
smoke81 is offline   Reply With Quote
Old 09-14-2009, 06:23 PM   #6566
adamge's Avatar
Meh, we still had foreign stars shining this year. Juho and Naoto were on fire, and Andy's driving was incredibly consistent.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 09-14-2009, 06:31 PM   #6567
smoke81's Avatar
No doubt, but no one can argue that the TRF boys are on fire... Hell I can't remember the last race they didn't have at least two out of the top three.
Call me greedy, but the more fast guys you can get at a race the better!
Cool thing about Andy coming is he did it on his own dime. I really didn't mean to sound like I wasn't glad they all came though.
Dustin Layne
Old 09-15-2009, 12:10 AM   #6568
if i change the steering spacer from 5mm to 4mm what affect on the car does this have ???
this is one of the tuning ptions i have never changed or tried ??
Old 09-15-2009, 07:12 AM   #6569
It will take out entry steering and give a bit more exit steering.
Old 09-15-2009, 07:41 AM   #6570
SammyZ's Avatar
Trader Rating: 138 (100%+)
thats a given, always stock those with any race car. Also get spare hingepins, i've found some bent ones in my cars. But moreover you should be stocking TONS of spares as parts do wear. Diff balls wear, thrust bearings, diff balls, pulley's, belts, CVD's, axles, bearings, ball cups, etc.
On this car I find the aluminum turnbuckles and aluminum ballstuds a weak point and are prone to breakage. You may want to stock spares or switch to hardened steel peices (tamiya makes these) and titanium tie rods.
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
