Old 09-11-2009, 04:54 PM   #6526
TryHard's Avatar
Originally Posted by veecee View Post
I have some info on the 416X from Champ:
"Tamiya says this kit will be including newly designed lower deck (2.25mm thick), upper deck (2mm thick), front & rear lower bulkheads, motor mount, center bulkhead motor mount support and rear belt. This kit will be released around December."
Ok, so having been having a chin wag this evening with my HHUK teammates... here's the theory
New motormount bulkheads and side bulkheads, and just a new rear belt... points to the motor going forward. Think about it, if the bigger pulleys are also included, then if the layshaft goes forward, the current front belt could be retained, and just a new (longer) rear required....
So, possibly aiming to make a bit of an improvement to balance for LiPo, especially now IFMAR has gone LiPo. Also potentially better spur access.
Not sure on the lower bulkheads, maybe a refinment more than a compelty new mounting (thinking curvey bulkheads on the 415MS from the 415)... than again, could be completely wrong!!! Guess will find out in October
Ed
Old 09-11-2009, 07:07 PM   #6527
nooo, I just bought my WE in June
But then, I should have expected it. But I don't think the X will be worlds of difference than the WE. Will I get it? we'll see. maybe if it takes off .5 sec off my lap times The economy isn't getting any better too you know...
redbones is offline   Reply With Quote
Old 09-11-2009, 11:27 PM   #6528
syndr0me's Avatar
Trader Rating: 32 (100%+)
Well, all done qualifying at IIC. I ended up 4th overall in amateur, and blew out in the last minute of my 13.5 run while charging for the top 15. I'm pretty bummed about that. I finally got the car to come around by going to 2.5 rear toe and shimming the rear blocks another .5 to 1 overall. I'm sure I'll get punted off the track tomorrow in the first turn.
That atomic company is showing off a gear diff for the 416.
syndr0me is offline   Reply With Quote
Old 09-11-2009, 11:38 PM   #6529
if you get chance put your set up sheet on for me
good luck today
sidecarphil1 is offline   Reply With Quote
Old 09-12-2009, 12:52 AM   #6530
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
I just went throught my 416we and I cant get my front belt to stop wobbling on the front pulley. Ive tried flipping and re shimming the center pullry but nothing happens
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 09-12-2009, 05:20 AM   #6531
Stephtruc's Avatar
No pics of 416X ??
Stephtruc is offline   Reply With Quote
Old 09-12-2009, 09:31 AM   #6532
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by Stephtruc View Post
No pics of 416X ??
Probably not until the show in October
tamiyarcracer is offline   Reply With Quote
Old 09-12-2009, 09:37 AM   #6533
sudhar93's Avatar
Send a message via MSN to sudhar93
This one of it
Tamiya TRF416 / TRF416WE / TRF416X-trf416x.jpg
Tamiya-LRP - Team Powers - RIDE -Sorex -Protoform - Sweep -Futaba - GQ
-------------Car Needs Minor Tuning, Driver Needs Major Tuning -------------
sudhar93 is offline   Reply With Quote
Old 09-12-2009, 09:38 AM   #6534
SammyZ's Avatar
Trader Rating: 138 (100%+)
lol, what a freaking joke. Looks like a 415
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 09-12-2009, 10:23 AM   #6535
Randy Caster's Avatar
Trader Rating: 45 (100%+)
Since when was the 415 a freaking joke?
I can't make out if that picture is new or old though...
Old 09-12-2009, 11:41 AM   #6536
i think it is some kind of 415 look alike
A, both belts are on one side
B, the motor mount looks odd
Old 09-12-2009, 11:54 AM   #6537
TryHard's Avatar
It's the 415/416 proto that was shown before the offical 416 pics came out... not new
Old 09-12-2009, 01:14 PM   #6538
I knew TH would come on and straighten us all out.
It was actually the color of the shock bodies that gave away it's age to me though...
Old 09-12-2009, 02:00 PM   #6539
syndr0me's Avatar
Any chance the new lower bulkheads are just the 2pc mounts? I kind of got the impression from discussions here that the TRF team hasn't tested anything other than those and the 20T pulleys, which were mostly because of the size of the Euros track. That seems to confirm what we've seen from pictures at recent big races at least. Before the WE was released, we saw plenty of pics showing them testing new parts.
Old 09-12-2009, 02:54 PM   #6540
kentech's Avatar
The new rear bulkheads will most likely be with the diff moved back as tested/run by the TRF drivers recently. What the changes to the front and center bulks could be I have no idea.
Here are just some ideas of what I would've expected on the X
- rear diff moved back as mentinoned above
- separate susp. blocks FR & RF
- 20T center pulleys
- carbon steering brace?
- 46mm front driveshafts?
- chassis with battery further back again? (altough with lipos that wouldn't necessary be prefered)
That's what I speculated on until yesterday. But with the statement "newly designed lower deck (2.25mm thick), upper deck (2mm thick), front & rear lower bulkheads, motor mount, center bulkhead motor mount support and rear belt", maybe there will be some more changes to the car. Just a couple of weeks and we'll see.
kentech.wordpress.com
kentech is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
