Tamiya TRF416 / TRF416WE / TRF416X
#6466
when i see 5mm droop on the setup sheets, how is that read and what tools are used
#6467
Is acetone safe to use on 416 graphite chassis? I'd rather just use that. Also i didnt file down the edges, i just CA'd it out of the box. This should be fine?
Thanks!
Thanks!
#6468
http://tamiyausa.com/articles/featur...article-id=413
#6470
Hi guys first post so please be gentle. I was wondering if anyone who runs the tamiya spool in their 416 has had any problems with it. I was at an outdoor meeting yesterday and ran the spool and had to keep replacing the black plastic pieces that the anodised cup goes over. I had to do this every 2 runs and wasn't hitting anything. I was using a 10.5 LRP Vector motor geared at 5.4. This is the first time that i had put the spool in the car and i'm quite annoyed at how weak this spool is compared to the 415 and MSX spools i had in the older cars.
Any help will be greatly appreciated.
Scotty........
Scotty........
#6471
Cool thanks, I'll give that a go when I get home. Will this wipe off all that white cloudy stuff?
#6472
Scotty........
Scotty........
#6473
Thank you so much m8...
Scotty
Scotty
#6474
#6475
Scotty........
Scotty........
#6477
#6480
Just started building the spur gear section of my 416 last night, having a hell of a time finding the 0.2mm shim (BR2). Is this a silver or blue part? I m pulling my hair out.
I went and got myself some Loctite CA as well, the liquid type. I found this method much easier. All I did was drop it on the edge and let gravity pull it along. Do I have to go around all the internal edges as well?
Thanks.
Thanks.
