Like Tree3Likes
Old 08-31-2009, 05:17 PM   #6406
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by Grizzbob View Post
I have, & I regularly use AE springs on mine(mainly when I need one that's different from the rates of the Tamiya springs). The fit seems absolutely the same to me....
perfect thanks man
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 08-31-2009, 11:28 PM   #6407
Skitee's Avatar
Originally Posted by Ramyuras View Post
Man that suck I just got my 416WE and now they are not running/making the 416 any more, even if they take 1year for another car what about parts support? any one know for sure if this is true?
The TRF cars aren't in full time production, Tamiya produces a batch every couple of months when the demand is up for them. Don't worry about parts support either as mentioned earlier parts are still easy to find for the 415's, so support for the 416 will go on long after 416 production ends.
Yip the AE springs are a perfect fit
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 09-01-2009, 12:46 AM   #6408
Originally Posted by sidecarphil1 View Post
they wont end the 416 just yet although i do believe they will produce a reinhard or groskamp / european champion edition
since IFMAR already approved LiPo, do you think Tamiya still developing 416? or maybe there will be 416 euro edition and after a month they will release 417 LiPo friendly car?? same like MSXX MRE & 416 2 years ago
krat is offline   Reply With Quote
Old 09-01-2009, 06:37 AM   #6409
my 416 is lipo friendly
i have had no lipos that dont fit , all though i havn't tried the 5200's from lrp and the others
sidecarphil1 is offline   Reply With Quote
Old 09-01-2009, 07:54 AM   #6410
oops sorry
what i meant with "417 lipo friendly car" is radical change on chassis design which optimize LiPo usage, because 416 layout is originally designed for NiMH (battery on right side and electronics on left side)
Old 09-01-2009, 08:26 AM   #6411
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by krat View Post
oops sorry
So a Type-R?
syndr0me is offline   Reply With Quote
Old 09-01-2009, 08:44 AM   #6412
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by Besercoe View Post
Randy - Im pretty sure that the Cyclone ball is much larger than the Tamiya equivalent, as well as the pin is wider.
I would imagine that you could just get the HB POM spool outdrives to mate it up with the spool. Everything seems quite universal in the last few years, but if the outdrives dont fit, i would say oyu could use the entire HB Spool.
Actually, I'm pretty sure that the ball will fit in our outdrive no problem. I think the only modification would need to be filing the outdrive a bit to accept the larger pin. I haven't tried it myself yet so I can't be 100% sure, but I'm pretty sure about it.
Old 09-01-2009, 08:48 AM   #6413
the alloy part of my steering tooches before the C hub touches the knuckle
and my steering on my DX3S is at 150% throw and 10% expo
Without modification, the bellcranks will most likely limit your steering throw, but it is still possible to get the knuckle to touch the c-hub if you wanted to, which I would consider full steering lock. I generally set my car with about a 1.5-2mm gap between the knuckle and c-hub when it is at full lock left or right. If you can get enough steering without having to even turn that far then your car will carry more cornerspeed because of less binding in the universal.
Old 09-01-2009, 08:50 AM   #6414
I have a feeling that with IFMAR implementing Lipo's, that everyone will be working on new TC platforms in the near future.
Another pretty cool idea I have seen run out my way is 1 cell lipo TC. The cars are extremely light (1200+- grams) and tire wear is minimal.
Old 09-01-2009, 01:36 PM   #6415
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
and with a 3.5 its just a tad faster than a 13.5
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 09-01-2009, 02:15 PM   #6416
I think that 1 cell racing could pick up if 10.5 was stock, 7.5 or 8.5 was superstock, and for modified, I'm sure we'd start to see 1 or 1.5 turn motors making an appearance before long.
The 3.5 motors they were running were just normal 3.5's, with the right tuning, I would think that laptimes would be really close between 1 cell and 2 cell cars.
But the main reason I like it is it drops the cost of racing, which is what I think is killing the on-road scene.
Old 09-01-2009, 02:36 PM   #6417
Trader Rating: 22 (100%+)
The cyclone ball is bigger, however the HB spool as a complete unit has different spacing between the bearings and if you use the HB POM spool outdrives on the 416 spool they are to short.
I drilled out the 416 outdrives by 0.4mm and widened the slot.
Still yet to run it though.
bjspinner is offline   Reply With Quote
Old 09-01-2009, 03:28 PM   #6418
How much did you have to shim the axle? And did you use the shims on the inside or outside of the axle?
Old 09-01-2009, 03:41 PM   #6419
I think it was 0.5mm on the inside of the axle.
Old 09-01-2009, 03:51 PM   #6420
Stilo's Avatar
In Finland we run usually AE springs because on lower grip that we usually have, those seem to work best. I guess those are a bit more progressive, so when driving in lower grip the car starts to roll a bit easier. With tamiya springs the car hasnīt got enough grip to lean on, so it is a lot faster to react to steering and it is way too twitchy to drive. With AE springs the car rolls more so it is a bit slower to react which in this case is a good thing. Car also seem to have more mid corner steering with AE springs.
But when the grip is good (almost traction rolling etc.), Tamiya springs have enough grip to work and to lean on and AE springs kinda collapse and give way too much weight transfer and make the car really loose and slow in changing direction.
Usually we use ae blue in front and silver on rear, or tamiya white/blue
Team EuroRC.com
Stilo is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
