Old 08-17-2009, 08:24 AM   #6286
syndr0me's Avatar
Trader Rating: 32 (100%+)
1XA/1F is standard in the rear on the WE kit. It will give you 3.5 degrees of rear toe (per side). Generally, I find rear toe gives you more forward traction, and increases the stability of the rear in general, but often at the expense of corner speed.
syndr0me is offline   Reply With Quote
Old 08-17-2009, 09:24 AM   #6287
Stein Tumert's Avatar
Originally Posted by TryHard View Post
Managed to learn a few things after racing too, making use of a nicely rubbered in track, biggest suprise was going to an F block on the rear both settled the car, and increased the high speed on-power steering
Which block did you use together with the F block?
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 08-17-2009, 11:51 AM   #6288
OK, I think that 3deg toe is more than enough for the rear I like to run with 3deg or less so what is the next block number for 3deg? And what is a split block?
Ramyuras is offline   Reply With Quote
Old 08-17-2009, 12:29 PM   #6289
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
I call the one piece "bridge" and the 2 piece "split".
The lettering is based on a number line system . every sequential letter represents another 0.5 deg increment. The split blocks can be either X or not the X. The #1 represents a roll center change and does not effect toe in.
Narrow...
XD
XC
XB
XA
X
A
B
C
D
E
F
Wide
once again , every step is a half degree.
Hope this is a help to you .
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 08-17-2009, 12:50 PM   #6290
i use 1XA 1D rear and the lack of rear toe has reduced the drag on the straight and our straight is LOOOOOOOOOONNNNNNNG , and now i have a top speed 5kmh faster than using 1XA 1F
that is also some thing to think about
sidecarphil1 is offline   Reply With Quote
Old 08-17-2009, 01:01 PM   #6291
E Ahlo' Le Uhlo'.
Wider is better, Ask your g/f.
Old 08-17-2009, 01:12 PM   #6292
syndr0me's Avatar
Originally Posted by John St.Amant View Post
E Ahlo' Le Uhlo'.
Ever wonder where your girlfriend learned all those tricks?
Old 08-17-2009, 01:36 PM   #6293
Narrow...
XD
XC
XB
XA
X
A
B
C
D
E
F
Wide
So you would use the XA-D in the rear and the A-F to get your rear toe and front sweep? sorry for all this question but the 416we is not like the other kit I ever had, the kits I am use to have numbers to determine the toe.
Old 08-17-2009, 02:12 PM   #6294
The four blocks on my car right now from front to back are as follows...
1XC/1XC;1X/1F
Old 08-17-2009, 03:32 PM   #6295
94eg!'s Avatar
Trader Rating: 17 (100%+)
1XC/1XC;1X/1F
Are you sure? That seems like a really narrow front end...
94eg! is offline   Reply With Quote
Old 08-17-2009, 03:36 PM   #6296
Good eye 94,,, you are right .. its 1C/1C;1X/1F
Old 08-17-2009, 04:02 PM   #6297
veecee's Avatar
Trader Rating: 34 (100%+)
Normally I use C-C or D-D at the front. C-C is a touch narrower than D-D and will give a little more steering. If you want to run sweep, you can try D-C.
At the rear, I'm running X-D which gives 2 deg rear toe which I feel is plenty for 10.5. XA-D and X-E will give 2.5 deg but X-E will be a touch wider which should give a little more stability than XA-D.
These are all subtle differences that lets you fine tune the handling of the car.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 08-17-2009, 04:09 PM   #6298
Man I think my car would be a bit twitchy with 2 degrees.
Old 08-17-2009, 04:13 PM   #6299
Yea that is the reason I got the 416we you have so much fine tune options, now all I want to know is the difference between the suspension blocks so I can setup the car the way I want.
Old 08-17-2009, 04:19 PM   #6300
TryHard's Avatar
XA
I was racing on a small tight and twisty circuit, and more than anything need to stabilise the car. I've normally always run XA/E... and a friedn suggested trying F to help, and well, it did! Corner speed wasn't crucial, but stability was
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
