Old 08-10-2009, 06:51 PM   #6241
syndr0me's Avatar
Trader Rating: 32 (100%+)
Here's Corey's NEGS setup a few people asked about. He uses the soft IFS c-hubs, and drills a hole in the plastic part of the shock cap to vent them, which makes it very easy to get 0% rebound.
I usually start with this setup on high-bite, and then tune from there. My differences are:
60/40wt oil front/rear (Losi)
shims under inside links are +/- 1mm depending on conditions
.5mm anti-dive (shim under f/r block)
aluminum c-hubs
shocks aren't vented (about 5mm rebound)
5mm front hex (no spacer)
1E r/r block (3 deg toe)
WE chassis & top deck
We run Jaco blues. Sometimes I'll try less rear toe or straighter links in the rear if I want it to rotate more, but that seems to only be good for turning fast laps. It hurts consistency for me. The car seems pretty good like this, and it's basically the setup I plan to use at IIC when the grip starts to come up. Not sure if I'll detune the car early on, or just wait for the track to come to me. I'm not some spectacular pro or anything, but I've put in a lot of time with the car and arrived at this point after a lot of work. Your mileage may vary.
Tamiya TRF416 / TRF416WE / TRF416X-416-grandslam-race-2.jpg
syndr0me is offline   Reply With Quote
Old 08-10-2009, 07:11 PM   #6242
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
Syndromes car looked very good last weekend! He's being modest
Dustin Layne
smoke81 is offline   Reply With Quote
Old 08-10-2009, 09:41 PM   #6243
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
aluminum c-hubs
Set up sheets need to be fully filled out like track temp makes a difference with shock oil right? Thats outside right? Please remember I'm Dyslexic :P
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 08-10-2009, 10:00 PM   #6244
syndr0me's Avatar
Hehe, nah, I'm probably not the right guy to ask for setups. Nobody seems to like my cars, they're always too steery. I just figured I'd share since nobody seems to be running on the rug with this car.
Old 08-10-2009, 10:18 PM   #6245
veecee's Avatar
Trader Rating: 34 (100%+)
Guys, might be joining some friends for a mod fun run this weekend. Any suggestions for FDR with a 5.5 or 6.5 brushless and Lipos? I currently run a 10.5 with a FDR of 4.8. Thanks.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 08-10-2009, 10:26 PM   #6246
I will be running it on the carpet exclusively. And If everyone would state that on the set up sheet it would help a lot. Leave note like "twitchy but tight enough" ....Big help.
Old 08-10-2009, 10:27 PM   #6247
put a 24 on it...
Old 08-10-2009, 10:31 PM   #6248
veecee's Avatar
John, is that 48 pitch? Because that's what I use. Currently running 75/32 with a 10.5.
Old 08-10-2009, 10:39 PM   #6249
jonest's Avatar
I'm running Orion & LRP X12 6.5t at 7.2 (big track).... hope this helps.
jonest is offline   Reply With Quote
Old 08-10-2009, 10:49 PM   #6250
veecee's Avatar
Brilliant. Thanks guys!
Old 08-11-2009, 03:09 AM   #6251
Send a message via MSN to Bigger Brother
Originally Posted by sidecarphil1 View Post
hey Ed
have you got a good set up for a 416WE indoors on carpet / rubber tyres ??
either using 13.5 lipo or 23 turn brushed
havnt decided on class yet
Look on Ed's site at David Bowen's Carpet Wars starting point. That's where I started from a few weeks back, just started testing ready for carpet season. Will be doing some more testing tonight and I'll put my setup up later in the week if you want.... (I'm running 13.5)
I'm running on various tires at the moment, since this winter I'll be doing series using both Sorex 28's and Much More/Sweep 32's (although we may be having a new wheel/insert combo on the Much More's than the currently available ones).
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 08-11-2009, 05:03 AM   #6252
cool i will try it thank you and if you dont mind posting up your set up it would be cool
i tried the MM sweeps at ets at i thought they were poop after the first run , i think the sorex 32's or 28's are best but it is personal choice only
sidecarphil1 is offline   Reply With Quote
Old 08-11-2009, 06:13 AM   #6253
I like the feel of Sorex 32's on carpet, it was what I used at times last winter when the tire choice was free. I've also tried some LRP Vtec 30's which must be about 30-40 runs old and seem to stay very consistent. Not as quick as the Sorex's though.
Tires for me are determined by the series I'm running in: Eversley and Rug Racers series are using the Much More Sweep - but like I say we are hoping to try out a slightly different wheel and insert combo - I should get some within the next few weeks to test with. I've hardly done any running on any Much More tires so can't comment yet. The Carpet Wars series uses Sorex 28s, which I think are slightly faster than 32's, but really good for about 5-10 runs.
I'll try to get a setup sheet on here or on Ed's site sometime tomorrow!
Old 08-11-2009, 07:08 AM   #6254
Its gonna fly ! Hang on brother...
Old 08-11-2009, 10:04 AM   #6255
Johnny Wishbone's Avatar
Default Setups
It would also be nice if it was stated somewhere if your running 5 cell, 6 cell or Lipo. And what the placement of the cells are, if used.
Same for stating if your running the 416 or the WE chassiss.
I'm also only running on carpet/rubber tire, but haven't got a killer setup worth sharing, although its very similar to syndromes.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
