Old 08-03-2009, 10:05 AM   #6166
sonic31's Avatar
i agree on the price issue with xray i really hated that when i bent an axle i had to pay 20bucks just for one! that, i think, is a rip off. i think i might buy a set of those split mounts.
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 08-03-2009, 10:29 AM   #6167
sonic31's Avatar
my car hope yall likes...
Old 08-03-2009, 11:14 PM   #6168
CHRIS CHAVEZ's Avatar
Originally Posted by sonic31 View Post
hey chris, i had that same issue where my smc 5200/40c pack had a 1mm gap between the top deck so i had to mount the battery almost half way off the chassis, i said f-it and sold that pack and i just bought that 4700/40c smc pack. if you hold the car up and manually flex it with the 5200 in it you will notice how it hits the top plate, as far as the tray thing check out ppd or pdp or something its around here so.mewhere
I found the PPDBillet.com tray and it's very nice, especially the price!
Originally Posted by CraigM View Post
The ppd tray doesn't move the lipo outside the top deck line so it wont be suitable with the 5200 SMC. Check out the bitty design tray, it isn't cheap but it fits with no mods
I'm very interested in the design of this tray because its not supposed to effect the flex of the chassis but still put the weight were it needs to be. Although, do you know if anybody sells them in the U.S.A.
Originally Posted by Stein Tumert View Post
I am using the XRAY Lipo Balancing Weights.
http://www.teamxray.com/teamxray/pro...ssis%20Weights
That might be the best idea but do you have any pics of how you mounted it to your 416?
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 08-04-2009, 12:54 AM   #6169
ChattyMatty's Avatar
so, to contine to belabor the point...is the WE really $125+ better than the standard 416 for low power apps like RCGT or VTA? (outdoor asphault)
Sorry for the nube qustion, but I have a disease...and when I see the Evo IV for $230, I can only say to myself "That's a great deal, why not spend twice that on a TA05MS?"...which led me here as the 416 is down to $375...
Tiger 1 FO
Hilux High Lift
Hotshot
Sand Scorcher
ChattyMatty is offline   Reply With Quote
Old 08-04-2009, 01:01 AM   #6170
Stein Tumert's Avatar
Same way as in a T2 008/009 which has predrilled holes, in the Tamiya you need to drill one hole for each weight...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 08-04-2009, 05:40 AM   #6171
penmark67's Avatar
Trader Rating: 14 (100%+)
Default Track
Originally Posted by sidecarphil1 View Post
show piccys whan you are doing it
i will be interested
Hi Phil, after 12 weeks of ass busting work our track is ready (apart from the barriers) (saturday) check it out. (and our new site)
Mark M www.aerccc.org.au
penmark67 is offline   Reply With Quote
Old 08-04-2009, 07:25 AM   #6172
sonic31's Avatar
chatty, if you're only looking for a tourer to do gt with then spend less $ a 416we is awesome but i think can be overkill for that class, myself, we have a gt class and its pretty cool but i would'nt go further than a tb03 or ta05.
i heard some good things about the tb03 so i'd consider that... inexpensive and easy to upgrade!!!
Old 08-04-2009, 07:30 AM   #6173
Default Pics
Here we go...
Tamiya TRF416 / TRF416WE / TRF416X-img_4693.jpg   Tamiya TRF416 / TRF416WE / TRF416X-img_4699.jpg
Stein Tumert
Old 08-04-2009, 07:33 AM   #6174
when are you coming to re do our track mate
sidecarphil1 is offline   Reply With Quote
Old 08-04-2009, 09:11 AM   #6175
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Here we go...
Those weights are nice but ... moving the cells that far out slows down the polar moment. That car will not rotate or change directions as quickly.
Chances are you will get hit on the side and rip the screw out of the chassis. Hope it doesn't happen to you but ... I know it would happen to me ,,lol
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 08-04-2009, 09:19 AM   #6176
syndr0me's Avatar
Trader Rating: 32 (100%+)
http://www.ppdbillet.com/RC_accessories.html
Down at the very bottom, there are some stainless "inserts" that fit into the battery slots. I just shoo goo those to the bottom of my packs (or use thin carpet tape) and arrange them in such a way that they prevent the pack from moving around. If I need more weight, I just use double-sided tape and stick tungsten weights to the pack. You can cover those in CF stickers to make them look nice, and even sharpie the edges black if you want.
I fit an SMC 5200 40c in the car (with the stock chassis) no problem.
syndr0me is offline   Reply With Quote
Old 08-04-2009, 09:29 AM   #6177
This solution actually keeps the weight closer to the center than with a tray...
The outside supports are not kept in place only by a screw... Maybe it will break, but many cars at our club has this set up now for the last 3 months, and no breakage so far...
Interesting how you can make such final statements on how well the car rotates....
Stein Tumert
Old 08-04-2009, 09:33 AM   #6178
The outside supports are not kept in place only by a screw... Maybe it will break, but many cars at our club has this set up know the last 3 months, and no breakage so far...
A lot of guys did that sort of thing here and for some reason, they don't anymore...
A wider weight distribution will always slow down the polar moment.
Old 08-04-2009, 09:36 AM   #6179
Senna Racing's Avatar
http://feralbatteries.com.au/images/...201:28:38%20AM
this is what i use it gives good banace to the car and hangs to the right a bit but not a great Pic.
will clean up the wiring and post a pic. soon
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 08-04-2009, 09:40 AM   #6180
Now that a REALLY nice way to do it and I bet its cheaper than those X-Ray ones. And lower CG as well.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
