Like Tree3Likes
Old 07-29-2009, 07:50 PM   #6091
syndr0me's Avatar
Trader Rating: 32 (100%+)
Building my first WE kit, I've been rocking two original cars since day one. Man, it's a work of art.
So how much different is this WE chassis going to be with its batteries moved forward? I see the TRF guys all seem to prefer the original?
syndr0me is offline   Reply With Quote
Old 07-29-2009, 08:00 PM   #6092
Korey Harbke's Avatar
I'm not a tamiya or TRF guy... but usually batteries further forward make the car a little smoother and easier to drive. It doesn't have as much weight of the rear, so there is less weight transfer to the front of the car off throttle and through the middle of the corner.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-29-2009, 08:18 PM   #6093
corallyman's Avatar
Trader Rating: 99 (100%+)
Originally Posted by sidecarphil1 View Post
yeah you can
i do
i use silver / gold
Sidecar,
Do you have the exact part numbers for the HPI springs you use?
Thanks,
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 07-29-2009, 09:12 PM   #6094
syndr0me's Avatar
-Korey
Hmm, okay. Losing mid-corner steering would be unfortunate, it seems like I'm always looking for it with the spool.
Old 07-29-2009, 11:09 PM   #6095
Just quit your whining and wheel it! If you don't I'm going to have to hijack this thread and tell you to get a HB cyclone... just kiddin.
Old 07-29-2009, 11:13 PM   #6096
SammyZ's Avatar
Trader Rating: 138 (100%+)
do you guys replace the shock shaft
when the ti-coating wears off?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 07-29-2009, 11:13 PM   #6097
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by Thirtybird View Post
The diff half does work, been doing it that way all along, but I'm still considering the muchmore tool for my diff rings.
A. it's magnetic and going to hold onto the diff ring
B. it's a lot easier to hold perfectly upright due to its shape (compared to a diff outdrive). The last thing I want are my fingers cramping up from sanding diff rings!
I thought you were used to holding small things .
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 07-29-2009, 11:14 PM   #6098
Skitee's Avatar
I usually change the shafts when the coating is gone.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 07-29-2009, 11:15 PM   #6099
SammyZ's Avatar
why?
Hotbodies USA
SweepRacing USA
Old 07-29-2009, 11:18 PM   #6100
If you are wearing your coatings off you most likely have dirt packing up in the bottom O-ring. removing the spring cup and taking a brush to carefully remove debris from this area will make the shafts and seals last much more... lol sorry much longer :|
Old 07-29-2009, 11:21 PM   #6101
Skitee's Avatar
Although the difference would be very slight there will be a differing level of smoothness on the shaft, this may affect the shocks operation and if one shaft's coating has worn off and the other hasn't then you may have two shocks operating differently.
Old 07-29-2009, 11:24 PM   #6102
Skitee's Avatar
Thanks John I try to keep everything as clean as possible between runs anyway, we only run outdoors here and most of the tracks are blown off and prepped but they're still dusty. So eventually they wear anyway.
Old 07-29-2009, 11:28 PM   #6103
Its good to keep coated shafts on all 4 indeed.
That coating is in fact a wear indicator. And do need replacing.
If it leaks is that an STD?
Old 07-29-2009, 11:56 PM   #6104
syndr0me's Avatar
Of all the advice I see on this site, I really think this is the best. And I mean it. I think we tend to overanalyze things way too much, and overlook the importance of being able to adapt easily.
The Cyclone is a beautiful car! I have the pleasure of racing against one (in the hands of a team driver) a couple times a week. I think it suffers a bit from the same problem as Tamiya in the US, which is good parts support from the hobby shops.
Old 07-30-2009, 08:44 AM   #6105
WHAT ?! I got all the parts I need for my 416....
All I gotta do is ask.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
