Old 07-26-2009, 03:29 AM   #6046
penmark67's Avatar
Trader Rating: 14 (100%+)
Default .
Originally Posted by sidecarphil1 View Post
i was almost stopped for the right , left , right on the infield !!!
i had to use the LTCR for more stearing but could still do with some more !!!!
it is crazy !!!
gearing is hard to get right too !!!
Just use Craig Mc's setup from SMA , and if its too agro for you go -25 expo on the steering. More turn in than anyone needs.
Mark
penmark67 is offline   Reply With Quote
Old 07-26-2009, 07:51 AM   #6047
Trader Rating: 1 (60%+)
Hi gentlemen ! * Is it possible to use TRF416 wtih 5000 lipo batteries,I mean do they fit in TRF416 without any adjustments *?
cico is offline   Reply With Quote
Old 07-26-2009, 08:49 AM   #6048
dameetz's Avatar
All my batteries are 5000 LiPo, as long as it is not thicker than 24mm(If I m not mistaken) it will be ok and will not touch the upper deck.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 07-26-2009, 09:02 AM   #6049
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 07-26-2009, 12:48 PM   #6050
Hebiki's Avatar
Trader Rating: 26 (100%+)
a ThunderPower 5000 pack fits fine with no modifications.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-26-2009, 01:22 PM   #6051
Mark
i had enough steering but the problem i had was on the infield section it felt like the spool was locking the front drive train , there is nothing wrong with the car
i use the steal 44mm shafts but i think i could have done with the 42mm or a ball diff in the front
the problem today was driver error
finnished both races 5th of 6 !!!!!! and i was 1.7 seconds a lap slower then the leading 3 but that was the speedo settings and gearing !! still struggling with the SPX !!!!
but hey if it was easy every one would be doing it
sidecarphil1 is offline   Reply With Quote
Old 07-26-2009, 07:02 PM   #6052
ab1105's Avatar
Trader Rating: 20 (100%+)
Does anyone have any idea which brand/servo the TRF European guys are using?
ab1105 is offline   Reply With Quote
Old 07-27-2009, 01:37 AM   #6053
[QUOTE=nilsmedson;5454380]
Originally Posted by CHRIS CHAVEZ View Post
Do any of you guys know (for a fact) which Sanwa/Airtronics servo that Marc Rhienard is using in his 416WE car?
Sanwa erg wg and some times rz
Fullsize servos center better than lowprofile versions.
Mr_Orange is offline   Reply With Quote
Old 07-27-2009, 02:32 AM   #6054
ab1105's Avatar
[QUOTE=Mr_Orange;6121796]
Yeah, thats kinda what I am headed at. Whats better about using a low profile servo? I am using one and I can't get it to go lock to lock with a Tamiya servo saver. i am using a horn instead. I am wondering if a full sized servo would be any different.
Old 07-27-2009, 04:35 AM   #6055
even with my full size servo i have 150% travel on my transmitter for left and right steering !!!!
i got a low profile one on order will tell you the differance when it arrives
Old 07-27-2009, 04:50 AM   #6056
CraigM's Avatar
Trader Rating: 34 (100%+)
KO PDS-2413 (low profile) locks out easy and centre perfectly
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-27-2009, 05:35 AM   #6057
Are you sure your servo is set up properly. I never have to reach over 60 / 70% of steering to reach the max possible for the car. Even with the 416WE.
Than again, I'm using a different brand servo. Using the Sav÷x low profile. It feels more accurate en faster than the KO low-profile a lot of people are using. And it's a lot cheaper too
Rick Thomson is offline   Reply With Quote
Old 07-27-2009, 06:33 AM   #6058
syndr0me's Avatar
Trader Rating: 32 (100%+)
Man, is this the truth. I think they also have better holding power, so they don't want to drift when you're, say, holding a lot of speed through a tight turn. I went from a 9551 back to a BLS451 and was very surprised at the difference.
syndr0me is offline   Reply With Quote
Old 07-27-2009, 07:35 AM   #6059
yeah i think he is set up ok
if i go less then the car wont go to full lock and the servo is not moving the saver on full lock , i am using a Kimbrough servo saver and get about 35 degrees lock either side from centre
i built the car as per the book and he turns well
it is a KO servo , old but quick and works well
i have a Futaba 9550 low profile one coming and i will see what it does with that
Old 07-27-2009, 09:02 AM   #6060
94eg!'s Avatar
Trader Rating: 17 (100%+)
Low profile servo should not reduce your steering angle at all...
I had heard in the TA05 forum that the Kimbrogh saver does not have as long of an arm as the Tamiya Hi-Torque saver. This will reduce your total steering throw. That forum member got some back by using the offset hole on the Kimbrough, that sits a bit further away from the center. Just something to keep in mind...
94eg! is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
