Old 07-22-2009, 08:18 PM   #6001
sonic31's Avatar
i managed to build a slipper spool with the diff parts and slipper pads from assoc. and was wondering if anyone else did this and if so how did the 416 drive with it? im racing this weekend and wanted to know what to expect since practice time for me will be very limited. thanks
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 07-22-2009, 09:26 PM   #6002
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by veecee View Post
Hey Randy, what body do you run on your setups? If you want steering, maybe give the LTC-R a try. I hear the R9-R gives crazy steering...
Problem is with that body, it needs support to keep the hood from flapping up and down. Has anyone other than me try cutting out the slots in the rear wing ?
I though it had less drag and more down force.
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 07-22-2009, 10:40 PM   #6003
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I have been using the Mazdaspeed 6 LW body mostly lately. For the new track, I am having a 4 or 5 year old Yokomo Stratus Type E body painted up. This body has more steering than anything else on the market, hands down. I think they stopped production on them though. If anyone sees one on a shelf somewhere PM me and I'll buy it!
Old 07-23-2009, 12:18 AM   #6004
over gear's Avatar
Trader Rating: 15 (100%+)
Camber link questions. Please correct me if i'm wrong.
long and paralle camber link = more traction?
short and angled camber link = less traction?
over gear is offline   Reply With Quote
Old 07-23-2009, 01:04 AM   #6005
Others may tell you it is but it's just not that simple.
And without a visual aid , I can not explain.
Old 07-23-2009, 01:28 AM   #6006
Korey Harbke's Avatar
I agree... that body was awesome. Still my favorite one to date.
-Korey
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-23-2009, 04:35 AM   #6007
HI_808's Avatar
I think longer links mean more roll and short links give less roll. But the shorter you make the camber link, the more camber change you get through the travel of the suspension. So, altering the links' angle and length for more traction depends on the reason why you don't have enough traction. A car can under-steer and over-steer from too much or little weight shift. Camber change also affects traction. That's where the "feel" comes in and you have to determine what effect you need.
For a 416, it might be best to go with Jilles Groskamp's set up for the camber links and 0.5 mm suspension mount spacers under the rear blocks. It provides great roll characteristics and camber change. Personally, after spending some time playing around with those links, I wish I had seen the set up earlier because it would have saved a lot of time.
HI_808 is offline   Reply With Quote
Old 07-23-2009, 05:13 AM   #6008
CraigM's Avatar
Trader Rating: 34 (100%+)
hehe yeah I felt the same about Jilles' base setup
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-23-2009, 05:22 AM   #6009
yeah
the only thing i have changed from the jille base set up is the springs , i use HPi silver and gold
sidecarphil1 is offline   Reply With Quote
Old 07-23-2009, 05:26 AM   #6010
niznai's Avatar
I think you're trying to fight it with your memory instead of trying to understand what happens and that's why you said it the other way around. It is not the length of the link that dictates your roll. The length of your camber link allows you to use camber intake to keep traction (i.e. contact patch) as the car rolls into corners but if you don't have body roll in the first place there's no use for camber intake.
Secondly, understeer and oversteer are often confused with slipping. Oversteer and understeer have more to do with inherent design characteristics of the car rather than traction (and indeed with a few settings that can correct one way or another this situation).
Slipping on the other hand does have everything to do with traction and quite often people look at the car that basically drifts and they say "oh it has too much oversteer (or understeer, as the case may be)". I think "oversteer" and "understeer" should be kept for when grip is not lost but because of certain characteristics/settings of the car determine it to follow the respective trajectory (tighter than your input would have you think for oversteer or larger for understeer) but without losing grip at any time.
Sure, at the limit, and oversteering car can end up in a slide as can a badly understeering car, but those are indeed extreme situations.
I have opened this side argument because I see too many people trying to cure false symptoms by applying rules mechanically like magic formulae (which they're not).
My suggestion then is make sure you do indeed have the symptom (problem) you say you do, otherwise you will end up in confusion.
Our cars should probably be designed as neutral as possible to allow for tuning in all situations, traction conditions and power levels. This is very difficult to achieve from a manufacturer's point of view (just as it is with real cars), but I think most cars on the market right now are very close, so you can tune them to oversteer, understeer or be neutral.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 07-23-2009, 06:31 AM   #6011
HI_808's Avatar
Did I leave a "magic formula" somewhere? Please clarify what you mean and answer my questions. First off, I said the length of the links has an effect on roll as well as camber change. What you are saying is that the length of the roll center link/camber link has no effect on roll?
And as far as understeer and oversteer, tires always operate under some slip angle when the car is in motion and slip angles increase as you approach the limit of adhesion. Thus, a car which understeers at corner entry and and a car that oversteers at corner exit will both "slide" if you push it enough. Do you define "slide" and "slip" as going beyond the limit of adhesion? Practically speaking, when cornering, I also don't quite understand how you can slide or slip without over-steer or under-steer first occurring.
Old 07-23-2009, 07:28 AM   #6012
u/k > u/s
I had to take some toe in out of the rear , for some reason one of my blocks didn't change to what I wanted so I made a compromise and ended up wider and even less toe that I wanted..... and it was awesome baby ! 1B/1F 2 deg and wide, no spacers at the wheel. Aggressive and yet stable.
Old 07-23-2009, 07:28 AM   #6013
niznai's Avatar
I didn't say you did (or anyone else for that matter). What I did say however was that incomplete explanations induce a false sense of understanding in people who end up not realising there is a logic behind all reasons why you should do that or the other and believe it's all some sort of black magic. You used vague notions quite similar to black magic yourself here:
And here's an example of mechanical formula (I don't think there's any magic within):
why does anyone need to memorise such useless gobledygook?
I prefer to use logic and observation and my explanation reflects that rather than "magic" or "feel" or "vibe" or whatever else people come up with.
And don't take it personal, I am just trying to suggest people can reconstruct things by thinking (rather than rely on memory), no need to get defensive.
Team Greasy Weasel
Old 07-23-2009, 07:32 AM   #6014
I didn't say you did (or anyone else for that matter). What i ddi say was that incomplete explanations induce a false sense of understanding in people who end up not realising there is a logic behind all reasons why you should do that or the other and it's all some sort of black magic (you used the word yourself here: ) and end up trying to memorise nonsense like it is a magic formula like this:
+1
Old 07-23-2009, 01:47 PM   #6015
i have just tried my car out with the steering support off to provide more chassis flex and to me it was inconsistant ...
felt like one lap the car would turn in good and stay tight but then the next lap it was pushing the front end on and then sliding the rear out on power out of the corner !!!!
i will try it with the plate fitted again tommorrow evening and see what happens
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
