Old 06-30-2009, 07:18 AM   #5806
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by sidecarphil1 View Post
i run the 46mm steal shafts after i broke the alloy 44mm ones , but i havn't broken an out drive , wore one out though
my steeringg and suspension have not changed , but i use 5mm 4mm downstops
the titanium screws were heavier , i cant understand it !!!
did bend the steal screw for the front , rear suspension mount , how do i stop it happening ???
If you use a steel screw, You may make the car tougher but will more likely bend the lower suspension mount. If I were hitting things I might prefer to use the softer screw because it is cheaper to replace. I have bent one in the past.... okay , I bent two. But not on the same day.
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 06-30-2009, 08:54 AM   #5807
Johnny Wishbone's Avatar
Originally Posted by jonest View Post
I broke NONE with the 46mm but the suspension travel seems funny. I'm running 6mm (F) 5mm (R) downstop setting.
If your running a narrow front setup with 46mm shafts make sure that your not too deep into the spool cups, you may have to notch a small relieve to free up the back side of the cup. I think anything after a B/C block should be checked.
Old 06-30-2009, 09:53 AM   #5808
jonest's Avatar
Now you reminded me, I'm running C/C.... no wonder it felt funny... hmmm... back to D/D or change to 44mm???
jonest is offline   Reply With Quote
Old 07-02-2009, 01:38 PM   #5809
AWK
AWK's Avatar
There is a new article on Tamiyausa.com explaining how David Jun measures droop on his cars. I thought it would be helpful to pass along: http://www.tamiyausa.com/articles/fe...article-id=413
AWK is offline   Reply With Quote
Old 07-02-2009, 01:48 PM   #5810
RC MARKET's Avatar
416WE Kit back in stock !
RC MARKET is offline   Reply With Quote
Old 07-02-2009, 04:16 PM   #5811
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Definately the best way to measure, and measuring that way you can run the same droop no matter what version car you have.
Old 07-02-2009, 05:36 PM   #5812
Setting the droop that way also makes it easier to get that last percentage and in finer increments. Especially When you camber is consistent. But really most accurate when the camber is set at zero degrees.
Old 07-02-2009, 06:31 PM   #5813
LOSI123's Avatar
Trader Rating: 63 (100%+)
does anyone know if tamiya 53473 rims are flexible at all, or very stiff. thanks
LOSI123 is offline   Reply With Quote
Old 07-02-2009, 07:31 PM   #5814
I'd say they are somewhere in the middle, probably on the stiffer side though.
Old 07-02-2009, 08:18 PM   #5815
LOSI123's Avatar
thanks, i have only ever had one set of tamiya rims before, they were spoked and where so stiff you could not even make them flex in your hand at all.
if this is the case then i didnt want to buy the above rims as when they are that stiff they tend to crack or chip easy if you arnt a perfect driver, lol
Old 07-02-2009, 10:24 PM   #5816
CraigM's Avatar
Trader Rating: 34 (100%+)
Personally I prefer using a droop gauge with blocks as they take out any inconsistencies on the bottom of your chassis like slighly protruded screws
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-02-2009, 11:59 PM   #5817
how do you stop the droop screws chewing into the chassis plate ??
mine is wearing quite bad now and the car is only 6 months old !!!
cheeRS phil
sidecarphil1 is offline   Reply With Quote
Old 07-03-2009, 08:08 AM   #5818
Send a message via MSN to maxrcp
Default gearing 416 we
Hi
i am using lrp 6.5t motor and 7,4v lipo on my 416 we.... in big track
i need something like 7.0:1 (as mentioned on my engine manual)
what gearing I have to use?
i gonna use pitch 48 on my gears!
tks
maxrcp is offline   Reply With Quote
Old 07-03-2009, 08:23 AM   #5819
sonic31's Avatar
hey phil, back in the 90's i ran 10th scale pan cars and we used very thin pieces of brass cut into small squares glued under the set screw for the plate and i know it will work for the 416 and others too... try it
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 07-03-2009, 09:39 AM   #5820
Brass is kind of soft .. We used a broken razor blade supper glued to the chassis.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
