Old 06-23-2009, 01:35 PM   #5776
over gear's Avatar
Trader Rating: 15 (100%+)
isn't shorter camber link = more camber change? more camber = more traction, right?
over gear is offline   Reply With Quote
Old 06-23-2009, 03:20 PM   #5777
JimmyMac's Avatar
Shorter links also make the chassis respond quick. Sometimes too quick. So you have to be careful.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 06-23-2009, 05:23 PM   #5778
CraigM's Avatar
Trader Rating: 34 (100%+)
Goingfast: personally I would ignore the front holes on the hubs. These will give you crazy steering but wont free the rear up. Why don't you post your setup and we can go from there. Also is this carpet or asphalt? Without knowing your current setup or the surface, I would suggest trying less rear toe, a higher rear RC, and a shorter rear wheelbase. It could also be your shock oil, springs, hole on the tower, etc etc
Originally Posted by syndr0me View Post
The TOP car is on the way, but I figure this is a good learning experience for any car
The rear end of the TOP feels very stuck with the box setup too
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-23-2009, 05:30 PM   #5779
FK05 lover's Avatar
Trader Rating: 147 (99%+)
Hi Guys,
I'm taking delivery of a TRF416WE soon & was wondering if you's had any set up tips
for low grip surface, rubbers tyres, 17.5
Many thanks in Advance..
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 06-23-2009, 06:18 PM   #5780
Goingfast's Avatar
Trader Rating: 29 (100%+)
hi Craig
I think I might know what's my problem....I soaked the Jack Ripper for 20min. and I noticed the steering when away after 4.00 minutes mark so I believe the front tire traction wear off and it started to push....I going to try the black paragon can next time ..... Thanks for you input
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 06-23-2009, 07:47 PM   #5781
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by FK05 lover View Post
Hi Guys,
Give the box setup a shot first, you might want some HPI silver springs for the front, and blue for the rear, and build it without the .5 spacers under the rear blocks. That should give you a pretty good starting point for a low grip track.
Old 06-23-2009, 08:41 PM   #5782
CraigM's Avatar
Hi Guys,
Jim (I think),
Here's my winning setup from castle hill CC round. It'll work great in 17.5, maybe just go a little lighter on oil if you are running at night in cold temps
-Craig
Tamiya TRF416 / TRF416WE / TRF416X-craigm-2009-hills-cup-castle-hill-raceway-20090614.jpg
Old 06-23-2009, 09:49 PM   #5783
FK05 lover's Avatar
Thanks Craig
Jim
Old 06-28-2009, 09:33 PM   #5784
StickyFingaz's Avatar
Trader Rating: 15 (89%+)
Hello 416 owners,
I'm in the process of doing a thorough rebuild to my race ride, complete with a new WE chassis and suspension parts. When trying to mount my top-deck, it has to be finagled inside in a manner that is not so free. It's so tight that it affects the tweak of the car. The bulkhead pieces aren't new, but I didnt notice any bends when I inspected them. The top bulkhead pieces also seemed to sit flush when I installed them.
I'm thinking of sanding a litle material off the end of the top-deck, but that's a last resort.
Anyone have an experience like this or have any idea why this might occur? Before I tore the car apart, i'm pretty definite that I wasn't having this problem.
-M
Get the $%^& out of my way.
StickyFingaz is offline   Reply With Quote
Old 06-28-2009, 09:46 PM   #5785
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by StickyFingaz View Post
Hello 416 owners,
I'm in the process of doing a thorough rebuild to my race ride, complete with a new WE chassis and suspension parts. When trying to mount my top-deck, it has to be finagled inside in a manner that is not so free. It's so tight that it affects the twek of the car. The bulkhead pieces aren't new, but I didnt notice any bends when I inspected them. The top bulkhead pieces also seemed to sit flush when I installed them.
-M
A few pictures might help us help you ...
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 06-28-2009, 09:51 PM   #5786
syndr0me's Avatar
Trader Rating: 32 (100%+)
Hello 416 owners,
-M
I always sanded mine from the beginning. You can take off very little, it won't affect anything, and will ensure there's no binding, preventing proper flex.
I generally push straight down on both shock towers and then tighten down the top deck. This seems to do a good job of de-tweaking the chassis.
syndr0me is offline   Reply With Quote
Old 06-28-2009, 11:32 PM   #5787
I usually push down on the towers as well. I just want to make sure the deck sits flatly without having to work against something though.
I've been staring at the car for awhile now and am running out of ideas. Looks like i'll be sanding just a hair off of both ends...
Old 06-29-2009, 03:14 AM   #5788
HI_808's Avatar
Hello 416 owners,
-M
I had the issue too, but that was because I used CA on the ends.
HI_808 is offline   Reply With Quote
Old 06-29-2009, 06:05 AM   #5789
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
Hello 416 owners,
-M
i had the exact same issue, the top deck is a tad too long. you will need to sand each corner a little at at time until the tweak issue goes away.
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 06-29-2009, 06:27 AM   #5790
syndr0me's Avatar
It seems to me that maybe my car didn't have that problem when it was new, but developed it over time. My bulkheads all appear to be straight when I lay them on a flat surface, so maybe it's something with the chassis developing a curve over time? It always seems to tweak out fine once I tighten down the top deck with the car compressed at the shock towers. It's a shame nobody makes those chassis flattening plates for this car.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
