Like Tree3Likes
Old 06-09-2009, 10:34 AM   #5656
Johnny Wishbone's Avatar
Hey John, I'll take some advice.
60 foot straight, 17.5 pulse motor, Ko SC 1.5, rubber tire, whats a good starting FDR? Timing on SC and timing on motor?
Any input appreciated.
Old 06-09-2009, 10:47 AM   #5657
stitchy's Avatar
John, I'd like some advice too. Tekin RS, Novak 17.5, rubber tire and 75 foot straight. What FDR? Thanks.
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 06-09-2009, 10:57 AM   #5658
jonest's Avatar
Which SPX model are we talking about? Stock Spec? Bullet?
Thanks.
jonest is offline   Reply With Quote
Old 06-09-2009, 10:58 AM   #5659
Randy- I will give you a call.
Korey-LOL....Great run at Reedy!!!!
MDawson...HAHAHA...How it goes?
Chris....LOLOLOLOL.
Great to hear from old friends again and hope to see everyone at the track.
Tamiya Racing Factory | RC3 Grafix
COREY LEWIS is offline   Reply With Quote
Old 06-09-2009, 11:06 AM   #5660
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Quickness and not speed is going to be key on a short track like that.
I would have the speedo set on the second most aggressive profile #7 .
The motor with the timing on 10 degrees to start. I recommend the highest "C" rating battery you can fit in the car. Capacity is not that important as long as you never over discharge it. Start with about a 4.4 final , if everything is going well your motor should be coming off the track at less than 140 degrees. I also like to put the throttle exponential on +50 to help me keep some momentum in the corners with out using too much trigger.
Good luck!
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 06-09-2009, 11:10 AM   #5661
Try the same as I had for the previous post ...
The Tekin has way too many options. lol
But the boost may not be effective for stock 17.5 because you will always be in the boost. I'd try it with out boost but an aggressive profile as well as the expo.
Old 06-09-2009, 11:13 AM   #5662
Originally Posted by John St.Amant View Post
Don't be a DICK!
rolleyes:
Takes one to Know one
jayco76 is offline   Reply With Quote
Old 06-09-2009, 11:14 AM   #5663
Thanks.
Theres a Bullet edition?
Isn't that the SXX speedo? (MOD)
I was under the impression the SPX was "THE" speedo for 17.5 and 13.5
The Losi Excellerin and the Tekin RS and pro models are the closest things to the SPX . The LRP is far and away the easiest to program/use.
Old 06-09-2009, 11:14 AM   #5664
The Evicerator
Corey Lewis!!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 06-09-2009, 11:15 AM   #5665
Nope .. I'm an ass.
Please make a note of it.
Old 06-09-2009, 11:25 AM   #5666
sonic31's Avatar
thanks for the info corey and john. the track i'll be running on is not that big and i know some of the guys run smaller spur to compensate for the extra traction, i threw an 88t 64pitch with a 40 pinion (4.52fdr) im using the lrp tc spec speedo with an smc 5000 28c lipo. but it does look to me like i need a bigger spur but i'll try anything until i get it right so anyways thanks for the info guys and please no more dicks! lol
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 06-09-2009, 11:28 AM   #5667
Change that 28c pack for a Thunder Power 3200 40c !
You will thank me later. Or maybe just wait till the 4000 40c is available.
Old 06-09-2009, 11:43 AM   #5668
Good luck!
The KO Sc 1.5 only goes to 6 so I'll roll one back from there, but when you temp your motor, where do you shoot from? Off the label, or the end bell or a couple of places?
Old 06-09-2009, 11:46 AM   #5669
Hebiki's Avatar
Trader Rating: 26 (100%+)
Good luck!
John... at least provide CORRECT advice. the Ko Propo BMC Vers 1.5 doesn't have profiles. it has timing settings and a customized throttle frequency profile.
Johnny.. here's background info for you. at the Reedy Race, myself and some other BMC 1.5 users had our duo's on the middle timing hole with timing set at 6 with a customize throttle profile.
i had my automatic brake set at 25 with brake frequent set at 0.794 or 0.792 (i forgot the exact number).
FDR for my car was at 3.9 and 4.1 ( i played with both) settled on 4.1. with the straight being over 140ft. rest of the info you can get from the BMC thread.
also, there's are plenty of great profiles on the BMC thread. check it out. back to 416 programming.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-09-2009, 11:49 AM   #5670
sonic31's Avatar
i know! i need to upgrade my lipo pack, cant do it just yet, im planning on purchasing GM motors lol just kidding, i want to run as is and see where i stand against the other racers then i make my move. thanks a lot john for the info really appreciate it.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
