Old 06-05-2009, 11:19 AM   #5626
Fabricio's Avatar
Send a message via MSN to Fabricio Send a message via Skype™ to Fabricio
Default rc store in birmingham
Hello guys,
Where can I get a TRF416WE in the Birmingham area, I have a friend that lives there and I want him to buy it and send it to me here in Brazil.
ARC R10 - ORCA - SANWA - EPIC
Fabricio is offline   Reply With Quote
Old 06-07-2009, 09:39 AM   #5627
ok so i have had my 416we for about 3 months running stock
i had a 415 before this and hoped that tamiya had done something about the shit plastic swing shaft protectors ....................
but no ...............
replaced them before ETS last weekend , did 4 days racing and now they are screwed again ..........................
there is a small amount of wear on the diff outriders but nothing serious ..
how do you stop this or make it less ???
cheeRS phil
sidecarphil1 is offline   Reply With Quote
Old 06-07-2009, 12:13 PM   #5628
Szimon's Avatar
Hi experts,
after several years, I've moved back to the tamiya chassis (416WE) and I found out that the original manual doesn't contain the list of the toe-in suspension mounts. What I want to do? I'd like to set a lower toe-in at the rear from initial to 2-2,5 degrees....
could anyone help me please?
thnx
Szimon is offline   Reply With Quote
Old 06-07-2009, 12:24 PM   #5629
Originally Posted by Szimon View Post
Hi experts,
thnx
this is the World of info REF the TRF416 and World Edition
thard
and this is the link for the suspension bridge chart
i used 1C 1C front ( will fit 1D 1D when they arive from Honk kong
and rear i use 1XA 1D this i think gives 2 and a half degrees toe on the rear makes it slightly twitchy on the faster corners , i got 1E coming also to try on the rear for 3 degrees toe
hope this helps
if you look there is also a topic "ask jilles " check it out it is full of help on handling tips
Old 06-07-2009, 12:32 PM   #5630
Szimon's Avatar
Originally Posted by sidecarphil1 View Post
this is the World of info REF the TRF416 and World Edition.....cut....
thnx a lot!
Old 06-07-2009, 07:01 PM   #5631
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Hey guys, just wanted to let you know that the Manutech Racing LiPo tray is now available. I have tested a couple different variations and have found the best one which is now being sold. There are only pictures of the tray itself on the website right now, but there will be pictures up shortly of the tray mounted in my car.
The tray adds approx 115 grams of weight to the battery side of the car, and brings the pack just to the side of the upper deck so that it will fit ANY 2 cell LiPo pack out there without interfering with the upper deck in any way. Now you don't have to load the car up with a ton of lead weight to balance it out..
The pieces that I've received (even the first prototype) have all looked awesome, truely top notch fit and finish.
Available at www.manutech.info part # 141-101
Old 06-07-2009, 10:56 PM   #5632
When I start a race, the car is planted and feels great. But in the latter half, the car becomes a little rear happy and the tires start to make these squealing noise. Are my tires over heating?
redbones is offline   Reply With Quote
Old 06-07-2009, 11:22 PM   #5633
yeah i think so
what tyres do you run ??
post your set up on here and we will all try to help
Old 06-08-2009, 01:45 AM   #5634
CraigM's Avatar
Trader Rating: 34 (100%+)
cheeRS phil
They do need to be replaced often, but I've never had that kind of wear, even when I ran mod. Try filing inside the outdrives to take the sharp edges off them
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-08-2009, 12:21 PM   #5635
TryHard's Avatar
cheeRS phil
also trying greesing the out drives with some light greese. Will ease the contact point between outdrive and blade.
However, the blades are an accepted pearishable item... I'd prefer to be replacing them versus the outdrives all the time!
Regards
Ed
TryHard is online now   Reply With Quote
Old 06-08-2009, 12:33 PM   #5636
yeah i agree but i would have thought that tamiya would have changed the design with the new car ...
Xrays dont do it .....
bugger i have ordered another 10 packs form HK though
i'll try the grease idea but our track is quite dusty and i think the sand/dust and grease may make it a bit like grinding paste ???
will try though
Old 06-08-2009, 01:18 PM   #5637
i've been running an extra 1mm spacer under the rear suspension block on the front and 0.5mm under the front block
but my question is this .
A if i reduce them both be 0.5mm do i still get the same affect
B if i put 0.5 on the front and 0 extra on the rear what will this do ??
and does D D on the front help ??
i run C C at the moment and it seams to push the front end on a bit ...
if you want some more info on my set up please ask
my track is dusty and quite fast flowing low grip but aggressave on the tyres
cheeRS phil
Old 06-08-2009, 06:54 PM   #5638
CraigM's Avatar
cheeRS phil
Hi Phil,
-> this will preserve your current amount of anti dive and castor, but will also lower the front roll centre giving you more steering. This is quite a big change actually, so the difference should be quite noticeable
-> do you mean make them both 1mm total? This will take away your anti dive (less initial steering, more weight transfer to front under brakes) and also raise the front roll centre (less steering)
->D/D will take away some steering, it also makes the car easier to drive as it's less twitchy.
->this would be from the high front RC, the front tends to skate in corners when you have a too high front RC compared to the rear. Try going to 0 under the front-front block and 0.5 under the front-rear, with 5mm of spacers under the front camber link on the bulkhead. You should also have 0.5mm under both rear blocks, and rear camber links flat
Post your setup if you'd like some more help. I posted mine a few pages back, at your track I would use exactly the same geometry and shocks, but with C/C blocks at the front to help with steering in the high speed corners, and test both 1mm and 0.5mm spacers in the front wheels to see which is quicker
Old 06-08-2009, 08:09 PM   #5639
devious17's Avatar
Guys, can anyone advise me where can I source for the WE lower deck? I am having a hard time looking for one.
Audio,Video, Disco
devious17 is offline   Reply With Quote
Old 06-08-2009, 10:04 PM   #5640
yeah i think so
This is using sorex36R on track temp of about 100F.
The setup is Groskamp's base asphalt setup on a slightly dusty surface.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
