Old 05-18-2009, 01:37 PM   #5446
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by Randy Caster View Post
The Tamiya axles have 4 holes for the drive pin on the universal. If one pair of the holes should wear out, just use the other pair of holes rather than replacing the axle.
the axles have 4 holes drilled for the drive pin? Why would the steel axle hole wear? Have you guys ever seen the pin holes wear? Ive never worn out a steel axle before
ive seen bent steel universals, broken cross joint pins, etc, but worn holes?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 05-18-2009, 01:52 PM   #5447
Trader Rating: 38 (100%+)
I've seen a pin rip through before. Someone did it to one of mine when driving my car. I was relieved to find there was another set of holes.
or8ital is offline   Reply With Quote
Old 05-18-2009, 01:58 PM   #5448
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
I had a pin slide out of one side and the bone beat the axle (cvd cup) to death before the race was over.
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 05-18-2009, 02:19 PM   #5449
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Maybe things happen faster for me because I am running low turn motors, but there isn't a moving part on any car that I can't wear out. The axles will take a lot longer than the other parts will to wear, but they still do get a lot of strain put on them, especially the fronts. Good rule of thumb would be to switch to the 2'nd set of holes when you replace the driveshaft and coupler/pin.
That 2'nd set of holes aren't there for looks.
Old 05-18-2009, 03:00 PM   #5450
JayL's Avatar
weight savings
I have had the hole get alittle play as well, switched and it tightened right up
JayL is offline   Reply With Quote
Old 05-18-2009, 08:41 PM   #5451
niznai's Avatar
Diff outdrives wearing out? Just replace the blades on your universals and the outdrives will last forever. The axles have 4 holes instead of 2, so rather than replacing them, Tamiya gives you the option to move the pin to the other hole and basically have a brand new axle for free.
Xrays have four holes too. Come to think of it all the cars I have seen do.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 05-18-2009, 08:54 PM   #5452
SammyZ's Avatar
this is the part were talking about right? so the cup has 4 holes drilled?
Hotbodies USA
SweepRacing USA
Old 05-18-2009, 09:21 PM   #5453
niznai's Avatar
That's what I understand.
Team Greasy Weasel
Old 05-18-2009, 10:14 PM   #5454
That may be an old picture because it looks like there's only 2. Any you buy now will have 4 holes though.
Old 05-18-2009, 10:16 PM   #5455
STLNLST's Avatar
Trader Rating: 19 (100%+)
All of mine have 4 holes. I'll post pics if I got back downstairs tonight.
STLNLST is offline   Reply With Quote
Old 05-18-2009, 10:20 PM   #5456
Super Moderator
Grizzbob's Avatar
Correct, any of them that I've bought in recent months have 4 holes, & the guys are right, the extra ones DO come in handy. I've also ripped one on ocassion, & I could keep using it just by switching to the other set of holes.....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 05-18-2009, 10:24 PM   #5457
STLNLST's Avatar
I blew by Randy so fast that I had to go to the extra set to get rid of the play
....man am I going to get it now.
Old 05-18-2009, 10:59 PM   #5458
niznai's Avatar
In my experience it is the little pin that wears out not the holes in the axle, so I would check those too. The axle should be a higher grade steel so it should wear down a lot less than the pin. What I do at first is turn the pins around so the part that pushes against the hole is fresh and swap driveshafts left to right. That is because the pins wear only on the half that pushes against the hole, not all the way around. Same goes for the large cylinder the pin goes through.
Team Greasy Weasel
Old 05-18-2009, 11:26 PM   #5459
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by niznai View Post
For us in Australia everything is even more expensive to buy since we don't have a Xray importer and we have a crap Tamiya importer (I don't think 416 ever came officially to Australia).
Not too sure where you live, but Custom Model Cars is the Oz Xray importer, and Toy Traders (Tamiya Importer) don't bring TRF in because of Tamiya Japan's wholesale pricing structure that means they are priced out of the market when compared to Japanese and HK retailers that ship here... well thats what they say anyway - I know of a large hobby shop that enquired about picking up TRF only and TT told them to "go away"... or words to that effect
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 05-18-2009, 11:39 PM   #5460
niznai's Avatar
I live in Perth.
About xray, I am not sure the company you named is officially the xray importer (i.e. has a contract of exclusivity with Xray) because we have a numebr of people here in WA who import xray stuff and sell it in their shops.
As for TT they are just revolting to deal with. Six month waiting for spares order through your local hobby shop would push anyone out of the hobby altogether. And the excuse with the Japanese wholesale pricing I think is just baloney. if that was the case, everybody would be priced out of the market and the entire world would buy Tamiya off HK shops on the web.
My personal opinion is that it is the Australian import charges plus the Australian parallel import legislation plus Australian pricing structure (read huge overheads) that drives prices up in Oz, not anything else. That is based on prices for other cars like the Avid and Xray that come from Europe and have huge prices here, so TT excuse doesn't play here. If you look at it it is cheaper to buy stuff like this everywhere overseas rather than in Australia. It is only shipping and our weak currency that keeps us from buying from Europe directly for instance but on occasions (when our dollar goes up) it actually tips the balance (I have bought a lot of stuff from Europe that way when our dollar was higher). That's why I think TT is just lame and they should just leave us alone and let someobody else pick up the import license from Tamiya. Numerous hobby shops around here have just given up on stocking anything Tamiya for that reason. Ultimately i see Tamiya will just lose interest in our market (which is small to begin with) and won't bother anymore. That will be a chance for somebody else to pick up the contract and do a proper job of it. I just hope it happens sooner rather than later.
Team Greasy Weasel
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
