Old 05-16-2009, 10:24 AM   #5386
dameetz's Avatar
Originally Posted by piorc View Post
Hey guys, im from Brazil and jut got the new trf 416 worlds! Here in Brazil nobody races with this car, so i need some helps!
Here we run with X11 9.5T motors, with lipos or/and 6 cell nimh batts!
I would like to know which hop up parts i need to buy?
which parts broken a lot or need to be replaced more often?
we race at outdoors asphalt medium grip tracks.
tks a lot
You don't need any hop up for this car. For spares I ll get the front plastic spool outdrives (though the kit has one pair for spare), C Hubs (if you want, get the normal plastic one for TA05IFS part #51293) front knuckles (if you break the C hub most likely you ll break the knucles too...and maybe front universal shaft (get the black steel instead coz its tougher).
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 05-16-2009, 10:39 AM   #5387
syndr0me's Avatar
Trader Rating: 32 (100%+)
If you plan to use the spool, get the 46mm steel shafts for the front.
Also, I would consider getting the titanium tie rods for the steering. The camber links seem okay as aluminum.
You might want to get a 1E block for the rear to reduce the toe to 3deg. I think the kit comes with 1C blocks for the front, so you might want to pick up some 1D blocks to try up there as well.
Be sure to get a few packs of spare arms, some front knuckles, and some rear hubs.
syndr0me is offline   Reply With Quote
Old 05-16-2009, 10:50 AM   #5388
Originally Posted by syndr0me View Post
In the end, the thing I changed that was the magic bullet was putting the soft IFS chubs back on. The amount of steering I picked up mid-corner was phenomenal.
Really? Gotta try this out.
I'm starting to kinda wish Tamiya would make some LCD-style drive shafts for the front like the Losi, XRay and now apparently, Hot Bodies.
Second that. Absolutely hate that chatter/grinding noise at full turn.
redbones is offline   Reply With Quote
Old 05-16-2009, 11:22 AM   #5389
got mine built
2 weeks before the ETS
plenty of time for testing
sidecarphil1 is offline   Reply With Quote
Old 05-16-2009, 11:45 AM   #5390
Johnny Wishbone's Avatar
The length on the Xray LCD is not the problem, but the pin end of the shaft is larger in dia, so it won't fit in the out drives.
Old 05-16-2009, 12:45 PM   #5391
Think a dremel, sandpaper, and fingers of steel can get it in?
Old 05-16-2009, 12:58 PM   #5392
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
tks a lot
Front "C" and steering Blocks, Lower Control Arms,
Axles and maybe steel CVD's for the front end.
Wheel bearings and spur gears....
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 05-16-2009, 01:17 PM   #5393
well i have just been out with my new TRF416we
and i have one word !!!
WOW
jesus it has some grip and corner speed !!!!
even with half knackered vtec30s
roll on tommorrow's free practice and the ETS at apeldoorn
Old 05-16-2009, 01:40 PM   #5394
Send a message via ICQ to piorc
Tks guys! and to use lipo's? i need to buy some tray or something else?
piorc is offline   Reply With Quote
Old 05-16-2009, 02:12 PM   #5395
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Wait a couple weeks before you go out and buy a tray
Old 05-16-2009, 02:13 PM   #5396
I'm going to see if I can get a hold of a set to see what it will take to make them fit. The axle is a bit longer than ours, so it will take some extra shims, but as long as our hex fits on the axle the rest should be easy.
Old 05-16-2009, 02:15 PM   #5397
And do u have the part number for this tray?
Old 05-16-2009, 02:17 PM   #5398
Chedda Bob made the one I used .
Send him a personal message and please tell him I sent you .
Old 05-16-2009, 02:24 PM   #5399
tks a lot
Old 05-16-2009, 04:53 PM   #5400
Trust me and wait a couple weeks before you buy a tray...
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
