Old 05-14-2009, 08:08 AM   #5356
Johnny Wishbone's Avatar
Originally Posted by syndr0me View Post
What tricks are you guys using to get more mid-corner steering (carpet) with the spool?
Have you tried .5mm spacer under rear suspension block at front of car? Or maybe the 1/2 degree front arm sweep or try to go one step narrower front width, before that I'd try thinner hex drives on the front.
Old 05-14-2009, 08:22 AM   #5357
syndr0me's Avatar
Trader Rating: 32 (100%+)
Great suggestions, I'll give them a shot tonight! The car almost seems like it wants to hop around the turns as I'm on throttle and exiting. I don't know if that's typical for a spool, or setup, or overdriving.
syndr0me is offline   Reply With Quote
Old 05-14-2009, 09:45 AM   #5358
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Randy Caster View Post
A pack of black Rit dye goes a loooong way...
Do you want me to have the flags at half mass for you since you can't make the Reedy?
STLNLST is offline   Reply With Quote
Old 05-14-2009, 09:59 AM   #5359
linger's Avatar
+1 on all the suggestions. Also might try less front droop (higher droop value), and lower the inner front camber link to get the front end to dump over more. For whatever reason, when I tried running front arm sweep on carpet - it made the car feel very sluggish entering corners. I think the front arm arm sweep worked a lot better on asphalt than it does on carpet.
You rear end is "hopping". Now that is just weird.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 05-14-2009, 10:41 AM   #5360
syndr0me's Avatar
I'm driving it pretty hard and aggressive out of the turns. It actually seems more like the front than the rear.
Thanks again for all the suggestions, only a few more hours until I can try them!
Old 05-14-2009, 10:47 AM   #5361
Thirtybird's Avatar
I've noticed that when I put a spool in the front of my car too. Dialing down the dual rate/end point seemed to help me.
Racing a Kawada SV-10 in 2010
http://omgitsakawada.blogspot.com/
The VTA Photon! (Inactive - back to the Kawada!)
http://vtaphoton.blogspot.com/
Thirtybird is offline   Reply With Quote
Old 05-14-2009, 10:55 AM   #5362
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Spools are good and stable but man they are hard on the equipment.
Tires, axles, drive halves... theres just no give to them.
I'm going out on a limb here but i vow to make a one way or two even hook up like in the day. And umm... whatever happened to Karen Smith?
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 05-14-2009, 11:06 AM   #5363
syndr0me's Avatar
I feel like I can be just as fast with a one-way, but man, consistency is such a problem. 17.5 it's not so bad, but when you start going faster it really becomes a challenge. The trend lately seems to be spool in 13.5 and up.
It is harder on equipment, no question.
Old 05-14-2009, 12:27 PM   #5364
If the back end is hopping you might want to try to a different shock oil and maybe open the holes in the piston a little to try and get a better packing. I wouldn't change the spring but just adjust the dampning. I think if you where to use the 3 hole piston but increase the size of the holes it might help you out.
You could also try changing the rear wheel base, but I think the hopping is more a product of not enough dampning.
Old 05-14-2009, 12:30 PM   #5365
SammyZ's Avatar
Trader Rating: 138 (100%+)
spool.
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 05-14-2009, 12:55 PM   #5366
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Now I'm counting on you to do that.
Old 05-14-2009, 01:55 PM   #5367
how do you get no rebound on the shocks ??
if i do it then wehn i move the shocks up and down with the top on i can hear the air inside
the smallest amount of rebound i can get is 1mm
is that a small enough amount ???
setting the car as per jilles tamac set up
sidecarphil1 is offline   Reply With Quote
Old 05-14-2009, 02:09 PM   #5368
syndr0me's Avatar
I vent mine by drilling a hole in the plastic cap, as suggested by Corey. Seems to work quite well.
Old 05-14-2009, 04:04 PM   #5369
To elaborate on that, you need to drill about a 1mm hole in the plastic shock cap. This will reduce the rebound to just a couple mm.
Old 05-14-2009, 10:25 PM   #5370
syndr0me's Avatar
Lots of good testing tonight, thanks for the suggestions.
In the end, the thing I changed that was the magic bullet was putting the soft IFS chubs back on. The amount of steering I picked up mid-corner was phenomenal. I was never totally sold on them with a one-way, but man, they really brought the car alive with the spool.
I'm starting to kinda wish Tamiya would make some LCD-style drive shafts for the front like the Losi, XRay and now apparently, Hot Bodies.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
