Old 05-08-2009, 06:43 AM   #5296
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by adamge View Post
It seems borderline retarded at first, but Tamiya halting production of this kit at the peak of its demand might be a lesson other manufacturers could learn from. Just think how many hobby stores are sitting on old T2'xxx kits they'll never sell. Or maybe Tamiya just has no feel or care for its customers, which is my other Tamiya theory.
Maybe they're doing it Nintendo Wii style!
I hear yah, it's weird how there seems to be these shortages from time to time. I think they're usually a sign of something new in the works.
syndr0me is offline   Reply With Quote
Old 05-08-2009, 06:55 AM   #5297
Skitee's Avatar
I don't think there'll be a new version of the 416 for a little while still, this is quite normal for Tamiya since none of the TRF cars have ever had ongoing production runs they just produce as many as they think the market needs every couple of months.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 05-08-2009, 07:16 AM   #5298
Trader Rating: 38 (100%+)
The Evo V was hard to get for a while but now it seems they have produced more. Im sure the same will happen with the 416
or8ital is offline   Reply With Quote
Old 05-08-2009, 08:01 AM   #5299
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by Randy Caster View Post
I'm assuming they will be a direct fit, guessing the 3 in the part number is 3mm which is what you need. One other o-ring you might want to try is Tamiya 42137 low friction TRF o-rings.
those TRF low friction O rings are very hard to get. I ordered the shock rebuild kit that comes with new guides and o-rings. I will compare those o-rings to the P3 (3mm) o rings from HPI.
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 05-08-2009, 08:31 AM   #5300
rtypec's Avatar
Default TRF Go!
Just swinging by to wish all of those participating in the upcoming Reedy Race the best of luck.
rtypec is offline   Reply With Quote
Old 05-08-2009, 08:45 AM   #5301
syndr0me's Avatar
How's that shaft drive in 17.5 theory working out? You gonna hit IIC this year?
Old 05-08-2009, 09:25 AM   #5302
I can't say I'm any faster then I am with a belt car. I will know better this weekend when I start racing outside. Im better outside then I am on the rug. It took me a few weeks to get things sorted out. I either got a bad batch of thread-lock or it doesn't mix well with the alloys Tamiya uses b/c I seemed to be losing all kinds of screws which kept messing with my setup. I think I got all the bugs worked out now.
I'd love to run the IIC sometime but not sure it will be this year. I will likely do one of the major races though but probably indoor champs or halloween classic.
Old 05-08-2009, 09:58 AM   #5303
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Instructions on the bottle suggest you may have oil in the screws themselves.
Try cleaning them with some motor spray first .
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 05-08-2009, 10:24 AM   #5304
Randy Caster's Avatar
Trader Rating: 45 (100%+)
The o-rings in your rebuild kit should be the same o-rings as the P3 from HPI I'm guessing. One thing I've noticed about the low friction ones is that they seem to outlast any other low friction o-ring I've tried in the past. I have had them on for about 6 or 7 track days now, and still don't have any leaking. Normally with a low friction o-ring I get leaking after the first day.
Old 05-08-2009, 10:29 AM   #5305
Is that with or with-out the Shock Boots?
Old 05-08-2009, 11:21 AM   #5306
stitchy's Avatar
Does anyone have a problem with the 1510 outdrive bearings seizing? I've had two go bad, and one was ceramic! Is there anything I can do to prevent this?
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 05-08-2009, 11:21 AM   #5307
good to know. I think it was the threadlock though. It wasn't the same shade of blue as all the others I've used. I switched to a different bottle and its been good so far. If it comes back I will definately try the motorspray.
Thanks!
Old 05-08-2009, 11:42 AM   #5308
linger's Avatar
Rod - instead of wishing us luck, how about you come out of retirement? I come out of retirement once a year to do the Reedy Race. You've got some skillz. It will only take you a battery pack or two to be back on pace.
The 1510 bearing is not really loaded hard at all. Mine last a very long time. I think you are just unlucky. The 5x9 bearings on the older 415 on the otherhand suck.
Shaft vs belt. A long time ago I kept testing back to back an Evo4 vs 415 with an underpowered 19T or 23T motor. The Evo4 always "felt" faster and seemed to accelerate harder, but the lap times between the two were always the same. I always just ended up confused.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 05-08-2009, 12:19 PM   #5309
syndr0me's Avatar
Ling, you should go to IIC!
Old 05-08-2009, 12:34 PM   #5310
Thanks!
It also says to shake well before using ... If it's been sitting around for a while .
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
