Old 04-30-2009, 09:34 AM   #5251
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by TryHard View Post
John,
You really should read and understand the posts better...Tony nowhere actually said that running -20 camber would actually be feasable, we could't actually achieve such a setting on the car for starters! What he's doing is very simplying using engineering principles to demonstrate the point, by taking an extreme example and showing what would happen with that. Being an engineer myself, it's very easy to spot that.
Your really trying to discuss three things;
Roll centre
Static camber
Camber gain
Now static roll centre position does have an influence on camber gain, as the link posiitions are used to calculate it. Changing your camber gain settings WILL alter your roll centre position. There are no two ways about it, as they both rely on the link angles. Static camber will not however influence roll centre, so the two can be considered mutually exclusive.
Now I mentioned before, the calculator is a guide, nothing more. Its there to give a comparison on settings, mainly as it only calculates the STATIC position only. There's no way I have the time to make one up to calculate the dynamic roll centre.
Your doing the same thing you did before with the flex topic... Trying to compare the real world with the small world, and completely forgetting about scale effects. You mention about audi's and subaru's in a previous post, but I very much doubt any of them would be able to top out at over 300mph, let alone corner at that speed.... Something else to bear in mind is that link positions are a lot easier to change on our cars, as we don't have to redisgning mounting points etc.
Instead of bagging the change as pointless, think of it as another weapon in the arsenal. I guarantee you'll feel a huge difference to the car.
Ed
Yeah I know .... I have a 416WE and a 415MSXX and did a comparison. Guess what ... there was NO DIFFERENCE! But no one wants to listen to me ... I was right on that instance too. THEY WERE BOTH THE SAME! I almost broke a car proving it to myself and kept the results to myself cause every one would just argue with me. One piece or two was the only difference....
As for scale speed , that is for entertainment purposes only.
Real world situations work perfectly in scale or F1 teams wouldn't do mock ups in wind tunnels in 5/8th scale. Want to argue about it again?
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 04-30-2009, 09:54 AM   #5252
Thirtybird's Avatar
So, these past two pages of arguing were because John said "add camber to go faster" without qualifying it with "within the limits of reason" so that it is clear to people who are unfamiliar with setup? c'mon guys, there is a way to discuss a point that is constructive and helpful, and there's a way to make it into a ridiculous discussion - the second way isn't going to help anyone...
Racing a Kawada SV-10 in 2010
http://omgitsakawada.blogspot.com/
The VTA Photon! (Inactive - back to the Kawada!)
http://vtaphoton.blogspot.com/
Thirtybird is offline   Reply With Quote
Old 04-30-2009, 10:01 AM   #5253
JayL's Avatar
It's real simple to have a final answer:
run on a track with timing
add your camber whatever
time
take out camber whatever
time
who wins: the fastest time
not hard
JayL is offline   Reply With Quote
Old 04-30-2009, 10:13 AM   #5254
STLNLST's Avatar
Trader Rating: 19 (100%+)
time
time
not hard
Maybe one day I will win Tryhard has all this killer info and I haven't made him look good yet You still racing this weekend???
STLNLST is offline   Reply With Quote
Old 04-30-2009, 10:47 AM   #5255
syndr0me's Avatar
Trader Rating: 32 (100%+)
Sometimes I think these guys like to whip on John over some past animosity, and not what he's saying lately.
syndr0me is offline   Reply With Quote
Old 04-30-2009, 11:12 AM   #5256
RC MARKET's Avatar
SMC
40C 4700mah LiPo Marc R Edition
Tamiya TRF416 / TRF416WE / TRF416X-4740cm%5B1%5D.jpg
RC MARKET is offline   Reply With Quote
Old 04-30-2009, 12:06 PM   #5257
TryHard's Avatar
The reason for a mock up at 5/8ths scale is you wouldn't actually be able to get a wind tunnel to run at full speed on a 1:1 scale... the thing would rip itself apart. They still have to take into account scaling effects.. hence why a number of teams have issues with wind tunnel calibration, where by gains made in the tunnel weren't being replicated in full scale.
For the flex, lets just agree to disagree...
Moving on!
Old 04-30-2009, 12:30 PM   #5258
Moving on!
Speed ... no matter what scale is CONSTANT. If they want to test a 5/8th scale car it is still run at FULL SCALE speed. The only difference is the ratio of down force between scales. The rolling road and wind are both factored @ 100% or the test would be moot. Even a 10th scale T/C travels the same distance as you or I and the physics against mother nature are constant. You can say scale speed but for all practical purposes its meaningless.
Perhaps one day we may race and if you beat me .....
Old 04-30-2009, 03:05 PM   #5259
CraigM's Avatar
Trader Rating: 34 (100%+)
Has anyone got a good foam/carpet base setup? There's a big indoor meet coming up & I've never run foam on the rug
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 04-30-2009, 03:16 PM   #5260
Originally Posted by RC MARKET View Post
SMC
There is an LPR 5300 40c pack that has a translucent case and can be flipped over as well. Funny tho. after many hot debates on deans plugs and barrel connectors .... perhaps Danny has given in and done what I've been suggesting all along.
Old 04-30-2009, 03:30 PM   #5261
JayL's Avatar
um no, he went EFRA spec, barrel connectors
Old 04-30-2009, 05:45 PM   #5262
CHRIS CHAVEZ's Avatar
Originally Posted by Hebiki View Post
Chris... TA05 milky white or all black sway bars work fine.
Speedtech has it in stock...
Milky white version:
http://www.speedtechrc.com/store/ebp...id=461&id=7556
Black version:
http://www.speedtechrc.com/store/ebp...id=459&id=5842 (not in stock though)
- Chris
With your info, i shot down to the mighty Speedtech and picked up the milky blue set and a few other goodies.
Thank you sir,
Chris
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 04-30-2009, 07:52 PM   #5263
I suggested universal connectivity and was outright chastised because the deans plugs were "better" . You think EFRA would want inferior technology as a standard? I didn't think so either. Tell me I'm wrong again! Go on!!
Old 04-30-2009, 08:08 PM   #5264
dameetz's Avatar
I m using Jilles basic foam carpet set up. It worked for me. Though there are a few things that I change like I went back to 1C-1C at the front and I don't use the suggested Xray spring instead I use Kyosho springs.
Jilles Basic foam carpet set up
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 04-30-2009, 09:30 PM   #5265
Default Setup
Just got a 415msxx,need a good starting setup for outdoor asphault,17.5.Sedan newb.
Rccarmaverick is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
