Like Tree3Likes
Old 12-10-2007, 09:02 PM   #511
wallyedmonds's Avatar
Originally Posted by linger View Post
Great, even Canada gets the 416 before I do. That's messed up.
You suck Corey.
wallyedmonds is offline   Reply With Quote
Old 12-10-2007, 10:16 PM   #512
maxepower's Avatar
Exclamation 416 revisited!
In the pictures from Corey Whitman it appears that the diff is larger than usual. It looks as big as the 501x and so does the center pully!
maxepower is offline   Reply With Quote
Old 12-11-2007, 11:03 AM   #513
hey,
a question to the gear-battery problem.
In the Xray is an batteryblock who stops it to get into the gear..
..is there anything like this in the TRF 416 or nothing?
greetz
Tamiya TRF 416
KoPropo EX-10 Helios
Graupner DS-8418
GM Brushed
"This gona b easyy..!"
Max Steiner is offline   Reply With Quote
Old 12-11-2007, 02:31 PM   #514
yes more balls
Originally Posted by Max Steiner View Post
hey,
greetz
but you dont need it if you do things right.
Old 12-11-2007, 04:34 PM   #515
So is $500 the normal price for this car or is it inflated? I hope to see it somewhere around the 415 or TA05MS price range when it is "officially" released.
redbones is offline   Reply With Quote
Old 12-11-2007, 04:36 PM   #516
where are you seeing $500. Most prices I've seen are around 439. Speedtechrc is selling it for that
DOTMAN is offline   Reply With Quote
Old 12-11-2007, 07:38 PM   #517
KoE
KoE's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to KoE
Default ball diff
anyone using 15 balls instead of 12 as per manual? what different would that makes?
Yo!
KoE is offline   Reply With Quote
Old 12-11-2007, 09:33 PM   #518
KoE
KoE's Avatar
Default centre pulley
i put 0.2mm spacer between pulley cap to remove slight wobble in the left centre pulley.
gone were the days when changing spur was only a 2-screw job on TA04
Yo!
Old 12-12-2007, 03:56 AM   #519
OleC's Avatar
Have anyone noticed noticed that there is a lot of play sideways in the center layshaft on the 416?
The manual requires one 0,2mm shim at each side of the pulley holder, but there is still 0,8mm of play (just measured it with a digital caliper)
Edit: Oh, I guess that is what KoE is talking about also...
Anyone else noticed this?
OleC is offline   Reply With Quote
Old 12-12-2007, 03:58 AM   #520
C van der Hagen's Avatar
Use the included shims as required.
C van der Hagen is offline   Reply With Quote
Old 12-12-2007, 04:43 AM   #521
OleC's Avatar
So it is supposed to be this much play?
I dont see any harm in it, just seemed a bit strange.
Old 12-12-2007, 09:36 AM   #522
TRF415boy's Avatar
Better than binding...
TRF415boy is offline   Reply With Quote
Old 12-12-2007, 10:01 AM   #523
Eirik's Avatar
I think that C van der Hagen meant that you should use the included shims to adjust it to be perfect!
0.2mm or 0.6mm, whatever to make it fit properly....
Eirik is offline   Reply With Quote
Old 12-12-2007, 07:04 PM   #524
Trader Rating: 37 (100%+)
Anyone put a Lipo in this thing yet...
Orion, Trinity, Core, or any other? Just wondering if they fit in this new Tamiya.
Nexus is offline   Reply With Quote
Old 12-12-2007, 09:35 PM   #525
The center pully is 18T vs 16T on the 416.
duckman996 is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
