Old 04-24-2009, 05:30 AM   #5191
SirPenguin's Avatar
Send a message via Skype™ to SirPenguin
Originally Posted by sagejyoung View Post
cool post your setup.
has anyone ever broken a camber link ball joint? i think the kit ones are rubbish
Dude, Stop hitting stuff, then you wont break anything
< Currently Wheeling >
Associated - TC5F
KO Propo - VFS-1 BMC | EX10 Helios
IP5000 30C
SirPenguin is offline   Reply With Quote
Old 04-24-2009, 06:00 AM   #5192
CraigM's Avatar
Trader Rating: 34 (100%+)
All in due time. I have 2 more days to try and find a couple moe tenths
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 04-24-2009, 07:10 AM   #5193
Ricky/C's Avatar
Send a message via MSN to Ricky/C
What's so special about the kit bearings that come with the WE?
TRF 416 WE | LRP SPX Stock Spec| 17.5 SP | Sanwa M11
TRF 416 WE | LRP TC Sphere | Novak 3.5 | Sanwa M11
www.oneten.co.za >>>>>>>>>>>>>>>> Home of RC in SA
Ricky/C is offline   Reply With Quote
Old 04-24-2009, 07:42 AM   #5194
veecee's Avatar
Originally Posted by CraigM View Post
I know a guy who bought a knock off corally 12th scale. Looked just like the real thing, but there was nothing connecting the left side of the diff to the axle.. 1wd 12th scale anyone?
Today was practice day for the state titles and my 416 is really hooked up. I can't wait for the racing to begin
Good luck Craig. You've been having a great run lately. Bring the 416 a State title!
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 04-24-2009, 08:31 AM   #5195
JimmyMac's Avatar
Never bent or broken one in all my years of racing Tamiya. That must of been a very bad crash! You can always switch to steel ones if that becomes a problem for you.
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
JimmyMac is offline   Reply With Quote
Old 04-24-2009, 08:33 AM   #5196
SammyZ's Avatar
Trader Rating: 138 (100%+)
what hard urethane bumper do you guys use? or do you just cut a custom one?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 04-25-2009, 12:44 AM   #5197
Ricky/C's Avatar
Can anyone tell me if I should change the kit bearings to ceramics if I'm going to be running 17.5/13.5
Old 04-25-2009, 02:03 AM   #5198
Skitee's Avatar
Ricky I wouldn't say that ceramic bearings are a must have upgrade, they are more like a nice to have.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 04-25-2009, 03:07 AM   #5199
Ricky/C's Avatar
Thanks Skitee, so the std bearings are fine? The car feels tight?!
Old 04-25-2009, 04:54 AM   #5200
TryHard's Avatar
Use the TB03 larger version, it's bigger than standard, and supports shells better. Its a direct fit.
Check you belt settings... Could be the holders are off on setting side to side. Also if the belts are new, it will take a couple of runs to break them in.
Old 04-25-2009, 11:18 AM   #5201
They are coated with a much lighter oil so they spin easier. Takes the step of degreasing out which was a + for me.
I tried ceramic bearings before, and I honestly cannot tell the difference. Main thing is to make sure the bearings aren't binding and I think you are set.
redbones is offline   Reply With Quote
Old 04-25-2009, 03:54 PM   #5202
Trader Rating: 21 (100%+)
The WE bearings make the drivetrain a lot freer. I usually didn't like to run ceramics in the wheel bearings as they did not like side impacts and would blow apart rather easily.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 04-25-2009, 05:22 PM   #5203
StickyFingaz's Avatar
Trader Rating: 12 (88%+)
I made holes and shaved off a lil material for the carbon bumper support in a P-Dub bumper for an AE TC5... now my car is a tank!
I don't remember that last time I broke anything on the front end...
Team Tamiya/TRF - Team KO PROPO - NorCal Hobbies
StickyFingaz is offline   Reply With Quote
Old 04-25-2009, 07:08 PM   #5204
Thumbs up Ceramic bearings
Hey guys, just a few words from the experts regarding Ceramic Bearings. The thought that ceramic bearings are sensitive to side impacts is 100% a myth. If anything, the ceramic balls in ceramic bearings are even stronger than the steel balls that are in non-ceramic bearings. They will not deform, crack, or be affected by side impacts in any way whatsoever. A side impact could damage the inner or outer race of a bearing for smaller width bearings especially, and depending on the impact, but if anything, ceramic bearings are less prone to side impact damage as the ceramic balls are superior in strength and modulus of elasticity to their non-ceramic counterparts.
The other advantage to ceramic ball bearings is that under load and stress the balls will not deform like steel balls. When balls deform under stress and heat they cause increased friction which will cause the car to slow down.
The lighter weight of ceramic balls also decreases the centrifugal force placed on the outer race of the bearing during racing, further decreasing friction.
If anyone has any other questions please let us know. Thanks!
ACER Racing
ACER Racing: the Fastest, Smoothest, Lightest & HARDEST BALLS in the INDUSTRY.
acerracing is offline   Reply With Quote
Old 04-25-2009, 10:04 PM   #5205
JimmyMac's Avatar
I've used Acer Bearings with great success. Though I've never had them in my 416, they were in all my Tamiya cars before that; 415, TA05, Evo's, 414, etc, etc. The ceramics made my TA05 the smoothest/freest belt car I've owned.
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
