Old 04-10-2009, 04:32 PM   #5071
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Randy Caster View Post
Actually I run anti-dive on a lot of my setups, it really helps get the car into the corners harder, but makes the car harder to drive and more twitchy feeling. Once you get it set up right it can cut down the laptimes a little bit on decent grip med to tight asphalt tracks.
+1 for anti-dive. I'll use it all the time now I've got it working
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 04-11-2009, 08:10 AM   #5072
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Ok so you comprimised ... Y didnt you just use the 2 degree caster blocks?
please remember I'm dyslexic....
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 04-11-2009, 09:04 AM   #5073
TryHard's Avatar
The anti-dive change only changes the castor by less than a degree... and also promotes the other changes mentioned (less weight transfer forward).
Changing the castor blocks just changes the castor... that's it
Old 04-11-2009, 10:01 AM   #5074
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by bigkoitat View Post
I ran a 3.5 before on my older car at DHW but only had a one-way at the time so it was alot harder without brakes and proper set-up. I'm going to give it a try next race now that I have brakes and proper set-up. That La Mirada track sounds awsome!! Do they still have practice at Tamiya on Saturdays?
Tamiya is open for free on every Sat, they get the track set up by around 9am, it's not too bad of a drive from San Diego, honestly the track is worth it...
Old 04-11-2009, 10:21 AM   #5075
bigkoitat's Avatar
Trader Rating: 6 (88%+)
I just have to get some Tamiya tirs and a bodie. I been up there back in 03' for practice
JAWS
TRF-416WE & 416-X / DHW / TEAMRCR.NET
bigkoitat is offline   Reply With Quote
Old 04-11-2009, 04:00 PM   #5076
so what is the better car ??
the TRF416 or the world edition ??
i'm looking for an upgrade from my "old" TRF415MSXX MRE
think it is time for the old boy the hang up his droop screws
i race outdoors on a fast flowing smooth tarmac track
AND do lipos fit without modifications ??
sidecarphil1 is offline   Reply With Quote
Old 04-11-2009, 04:30 PM   #5077
bigkoitat's Avatar
If liked the 415 MSXX-MRE than you'll love the 416WE I raced both cars for about 3 months and have to say the 416 is easier to drive. I run the Orion 5000s with no mods either. Not saying the 415 is a bad car but if you want to upgrade than go with the 416.
JAWS
Old 04-11-2009, 04:33 PM   #5078
Tremor24's Avatar
Since the rear of the front blocks has a spacer under it already, how do I know exactly how much anti-dive it has? I'm running a 3mm spacer under the flipped over block, and none under the front front block. Does anyone run more than three mm? because the block is very close to the pulley on mine already.
thanks!
Tremor24 is offline   Reply With Quote
Old 04-11-2009, 09:58 PM   #5079
Super Moderator
Grizzbob's Avatar
I have to agree, I've had my 416 for just over a year, but I just (this weekend) got ahold of the stuff I needed to convert it to WE spec(the short suspension arms, new top deck, new belts, new shocks, all but the lower deck & spool, & I don't really feel I need those right now on the carpet tracks I'm racing on), & just adding to new top deck, shocks & belts made a real difference for me, car DEFINITELY picked up more rear grip & seemed to have more overall grip(actually made it push at first, but going to a softer front & firmer rear spring balanced it out nicely), & its path control & transitional handling feel VERY good(even better than before, & it was certainly no slouch in that department before the upgrades). I'd STRONGLY reccommend getting one, you will NOT be disappointed....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 04-11-2009, 10:35 PM   #5080
For practice you can run whatever tires and body that you want, it's only for the TCS racing that you have to run all Tamiya products.
Old 04-11-2009, 10:39 PM   #5081
thanks!
I don't have my car right here with me to look at, nor do I remember what the kit comes with under that block, but the kit settings will put you at 0 degrees. If you add shims under the rear block, you will be adding anti-dive, however if you go with a fewer amount of shims there, it will essentially lower the arm mounting position as well as add kick up to the front end. For kick up we generally add shims under the front block, rather than lower the rear.
Old 04-11-2009, 11:21 PM   #5082
ab1105's Avatar
Trader Rating: 20 (100%+)
A 3mm spacer is standard under the 1C front end/back block (upside down one). Adding .5mm adds "anti-dive".
ab1105 is offline   Reply With Quote
Old 04-12-2009, 06:08 AM   #5083
You guys must run outside on the tarmack. I've got so much steering its stupid! (carpet)
Old 04-12-2009, 10:16 AM   #5084
what is the differances between the TRF416 and the World Edition ??
Old 04-12-2009, 10:23 AM   #5085
Scroll back a couple hundred pages . Its all there somewhere.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
