Old 04-07-2009, 11:48 PM   #5041
Ricky/C's Avatar
Send a message via MSN to Ricky/C
oh. But if it protecs the chassis and iit wont have a negative result, I'm doing it
TRF 416 WE | LRP SPX Stock Spec| 17.5 SP | Sanwa M11
TRF 416 WE | LRP TC Sphere | Novak 3.5 | Sanwa M11
www.oneten.co.za >>>>>>>>>>>>>>>> Home of RC in SA
Ricky/C is offline   Reply With Quote
Old 04-07-2009, 11:53 PM   #5042
Skitee's Avatar
It will definately help protect the bottom deck.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 04-07-2009, 11:58 PM   #5043
Ricky/C's Avatar
I want to get it done before I build the chassis, but I work and cant get to the damn plastic place, maybe I should put a piece of bullet proof glass under it
Old 04-08-2009, 05:50 AM   #5044
Adam?'s Avatar
I decided to stop being a 13.5 chicken and run an 8.5 on our somewhat small carpet track. Man, this car is easy to drive with a spool! My timing will take some work, but taming more power doesn't seem quite so scary.
I tried a tip I picked up from Jilles to run a .5mm shim under the front rear block, which I believe gives the car anti-dive? Anyway, that made a surprisingly big difference, and really helped the car get the weight forward when entering the turns, and yielding enough steering without having to rely on more dual rate. I'd like to try C/C up front next.
Adam? is offline   Reply With Quote
Old 04-08-2009, 06:48 AM   #5045
sagejyoung's Avatar
what does the c/c do, will it alter the track width?
sagejyoung is offline   Reply With Quote
Old 04-08-2009, 07:06 AM   #5046
Tremor24's Avatar
Ya it'll narrow the front (if you running the 1d - 1d?), and add a bit more steering, especially for a small track, I'm running 1b in the rear front and 1c in the front front, with 1/2 degree front toe out, good combination as well!
Tremor24 is offline   Reply With Quote
Old 04-08-2009, 10:54 AM   #5047
TryHard's Avatar
That adds anti-dive, and also reduces castor. The reduced castor is the bit that helps entering the turns... as the Anti-dive helps to resist weight transfer forward, as the arms take some of the suspension loading as the picture below shows...
HiH
Ed
Old 04-08-2009, 11:10 AM   #5048
Trader Rating: 38 (100%+)
Actually isn't it anti-squat since it is on the rear? Though I guess "front rear" has two meanings. Is it the front piece of the rear of the car of the rear piece on the front of the car?
or8ital is offline   Reply With Quote
Old 04-08-2009, 11:15 AM   #5049
Ricky/C's Avatar
Hi Ed, would you mind please explaining each pic? If its supposed to be common sense, sorry I dont understand
Old 04-08-2009, 11:17 AM   #5050
Ed, is your picture assuming the front of the car is to the left or right? if its to the left then it is backwards.
Old 04-08-2009, 11:45 AM   #5051
AWK
AWK's Avatar
HiH
Ed
Since I have never messed with the anti-squat/dive, could you go over what each change does front and rear? I.E. shim under the front, front block...while a shim under the front rear block....
Thanks for all of your help Ed!
AWK is offline   Reply With Quote
Old 04-08-2009, 12:39 PM   #5052
1rcracer's Avatar
now u see why i was asking about the mouting blocks..
good look at that site and see what it says about each block size...
___________________________________
Team Novice!!
TEAM CORALLY RDX Φ - ZA
1rcracer is offline   Reply With Quote
Old 04-08-2009, 12:41 PM   #5053
1rcracer's Avatar
Chaps.. one of the best sources for setup info is the xray/hudy setup manual. it can be d/led from the xray site..
it explains everything in there....
even the secret to being fast
Team Novice!!
Old 04-08-2009, 12:42 PM   #5054
TryHard's Avatar
haha... ok here we go.
Front of the car is assumed to be on the right. The angled arrow underneath represents the force being placed onto the suspension arm when the weight transfers forward.
So in the left hand pic, the arm isn't taking any load at all, and infact only the shock takes the loading. This means that more weight will transfer forward, as in effect the front supension will be softer.
This also increases castor, so less turn in, but more mid-corner.
The mid setting would have the arm taking some of the loading (the little arrow going along it). As such this will stiffen the action a bit, and reduce the castor. The reason it stiffens the action is that a suspension arm won't deflect as much as a shock will
The Anti-Dive setting, well, devlops that further, with more of the arm taking the loading, and as such it stiffens the suspension. Also reduces castor so more initial steering. So in effect, you'll have less weight transfer forward (so good braking stability), but also better inital steering.
HiH
Ed
Old 04-08-2009, 12:43 PM   #5055
1rcracer's Avatar
Originally Posted by 1rcracer View Post
now u see why i was asking about the mounting blocks..
go look at that site and see what it says about each block size...
YOH thats some bad spelling....
Team Novice!!
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
