Old 04-04-2009, 11:52 AM   #4996
over gear's Avatar
Trader Rating: 15 (100%+)
Correct me if I were wrong.... I saw told to sand the side of the ring that face the diff hub. The extra roughness makes the ring grip better on the hub.
over gear is offline   Reply With Quote
Old 04-05-2009, 02:20 AM   #4997
TryHard's Avatar
Does the same on teh balls too... the slight key put into the surface of the rings (which is why you shoudl use 1000grit+) allows you to use less pressue on the diff, but it grips just as well.
Result = a very free but none slipping diff
taken from my site...
Uber Diff
Follow these simply steps to achieve a very smooth, but tight diff.
Sand Diff rings with 1000grit wet dry. This provides a key on the surface for the balls to grip, allowing a looser setting, without slip.
Use JAAD Racing 3mm Ceramic balls (JDRDB300) and ceramic thrust race (JDRCT0206), using Associated black stealth grease on thrust, and Schumacher diff grease. Ceramic balls are very hard and long lasting, and will stay the smooth for a very long time. The Associated grease is recognised as the best for thrust bearings, and the same goes for the Schumacher diff grease and the diff balls.
Cover with JAAD Racing diff covers (JDRTA0502). These keep the dirt out extremely well, avoiding your diff becoming gritty due to dirt between the rings, pulleys and balls. Remember to apply some grease to the region where the cover comes very close to the diff half, to avoid any binding in the diff action. To help avoid collecting any dirt in the out drives and thrust bearing, plug the long diff end with a foam pad (one of the red foams from the shocks works well), and tape over the hole for the diff setting screw. This will keep all the dirt out, and you won’t have to rebuild your uber smooth diff for a long time.
Building one with this technique, I've had my diff stay very free, but still tight, for months now... only just getting round to a rebuild now
HiH
Ed
Old 04-05-2009, 09:06 AM   #4998
Ricky/C's Avatar
Send a message via MSN to Ricky/C
Hi guys, I'm gonna be building my 416WE this week. I'll want to run it in Stock, as in 540 Johnson stock , but any setup/build help will be great!
I'm mostly running foam on tarmac, so any set-up help will be great Thanks
TRF 416 WE | LRP SPX Stock Spec| 17.5 SP | Sanwa M11
TRF 416 WE | LRP TC Sphere | Novak 3.5 | Sanwa M11
www.oneten.co.za >>>>>>>>>>>>>>>> Home of RC in SA
Ricky/C is offline   Reply With Quote
Old 04-05-2009, 11:39 AM   #4999
you might have problems installing a silver can in that car...
redbones is offline   Reply With Quote
Old 04-05-2009, 12:18 PM   #5000
Low_E's Avatar
Send a message via MSN to Low_E
when driving stock you might consider running a one-way instead of a spool.
Problem is that the WE is build around a Spool and you micht have oversteer when driving the One-way.
I haven't been able to find a good setup for the one-way, unfortunatly, for the 416 WE, when driving in a 27T-motor-class.
When driving in competition in the morning, when tracgtion and grip was low, the car went ok, but I always had to switch to the Spool because there came more grip on the track and the car became seriously oversteered.
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 04-05-2009, 01:36 PM   #5001
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
The silver can should fit no problem. You are going to need atlease an 88 tooth spur (if you are running 64 pitch) you will want to be atleast 50mm roll out to start. That should be pretty good for a tennis court sized track. Temp the com and try to keep it below 180. Spool would be better stereing for low traction conditions for sure but like he said , a one way will roll smoother and cary more speed but yeild more steering . recomend a much harder spring in front AND a firmer front tire. let out some droop . soft oil.. low angled shocks.
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 04-05-2009, 05:20 PM   #5002
miccal's Avatar
Trader Rating: 23 (100%+)
Another example of a John St.Amant incorrect statement!
The motor mount on the 416 only has a small hole for the input shaft of the motor. The hole is not big enough to fit a silvercan motor because the silvercan motor has the raised portion around the input shaft. You will have to widen the hole to fit it.
miccal is offline   Reply With Quote
Old 04-05-2009, 06:50 PM   #5003
Oh ye of little imagination... do I need to draw it out for you ?
Old 04-05-2009, 06:52 PM   #5004
SammyZ's Avatar
Trader Rating: 138 (100%+)
are the short reversible arms shorter than stock? will it affect width?
SammyZ is offline   Reply With Quote
Old 04-05-2009, 09:00 PM   #5005
Maybe they should have called them the narrow arms.....
Yes, it does.
Old 04-05-2009, 09:13 PM   #5006
CraigM's Avatar
Trader Rating: 34 (100%+)
Hey 416ers! quick update from the weekend
I built my car up using the base asphalt setup from Jilles Groskamp (but with HPI springs) and man did it hook up. I took out TQ at the interclub round at my home track and went on to second overall. I took the win in the first main, got in a bit of trouble in A2 but came back to 2nd, but nerves and lack of driving prowess got to me in A3 I dunno how the pros do it! Still a great day & everyone was saying how dialled my car looked
BC18, the short arms will make your track narrower which is why they are normally used with wider suspension blocks compared with the 416 (non-WE) kit
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 04-05-2009, 09:53 PM   #5007
jonest's Avatar
HiH
Ed
What do u mean by "wet dry"?
jonest is offline   Reply With Quote
Old 04-05-2009, 10:38 PM   #5008
CraigM's Avatar
it's a type of sandpaper
Old 04-05-2009, 10:43 PM   #5009
You should get a setup that helps settle your nerves... Or get a faster chassis so nerves don't matter LOL!
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 04-05-2009, 11:36 PM   #5010
ab1105's Avatar
Trader Rating: 20 (100%+)
Just a heads up...
My 416WCE review is now posted on my new r/c site...http://www.rcracing2.com
ab1105 is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
