Like Tree3Likes
Old 03-30-2009, 08:03 PM   #4966
I do convert Jilles setup from LRP Masters into PDF, here is the document! Let me know in case of any mistake!
For those who are looking for setups, there is Ed website or this page as alternative.
Jilles, will it be possible to get some info about you TRF guys used during WC in Bangkok?
Arn0 is offline   Reply With Quote
Old 03-30-2009, 10:17 PM   #4967
sagejyoung's Avatar
Thumbs up
Originally Posted by JGH View Post
Hello guys,
You guys are absolutely right about the fact that we don't share a lot of info and set-ups on this forum.
I have tried to keep up in the beginning on the TRF 416 topic but there are so many posts I get a little confused.
Nevertheless I try to get more involved in the forum again or maybe if you guys think it's a good idea I can start my own thread?
Attached is my set-up from the LRP race yesterday.
Jilles Groskamp
i think you should start a thread..
sagejyoung is offline   Reply With Quote
Old 03-31-2009, 12:19 AM   #4968
wide_mouth_frog's Avatar
Originally Posted by TryHard View Post
Hmm, where were you running the shocks in the arm? 1 or 2? Could have tried moving it back into 2 on the arm, if in 1.
Maybe 4.5mm or 4mm might have worked better for initial bite, but maybe would have lost some eleswhere. Could also have narrowed the car down, with 0.5mm or 0mm on the hexes.... erm other ideas, softer oil in the front?
I take it that was the STCC? Might have to break mine out at some point outdoors this year....I'm getting the itch already
Thanks chap... really was at a bit of a loss... my front end seemed soft enough... maybe I will try velcro on the tyres next time hehehehe
Team Wave - absdesigns.co.uk - Selections RC
wide_mouth_frog is offline   Reply With Quote
Old 03-31-2009, 12:22 AM   #4969
Hello guys,
Jilles Groskamp
Really nice of you to take time out Jilles... I am sure you will get bombarded with questions now..... but atleast we will get the correct answers
and many congtats on your results!
Old 03-31-2009, 01:39 AM   #4970
JimmyMac's Avatar
Have you girls seen this? I know it's steel cups, but maybe you can use it for back up....
http://shopping.rcmodel.hk/product_i...vrsqa8bmdptdt2
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 03-31-2009, 01:53 AM   #4971
JGH
Hello everyone,
Thanks for all your comments yesterday.
I just started a new thread called: "ask" Jilles Groskamp Tamiya 416(WE) / SpeedPassion motors.
I will try to help all of you as good as I can!
Jilles Groskamp
JGH is offline   Reply With Quote
Old 03-31-2009, 02:06 AM   #4972
sagejyoung's Avatar
question: is there a thicker upper deck for the WE? i would like to know if i could upgrade/use it.. and if so how thick is it?
Old 03-31-2009, 02:13 AM   #4973
Ricky/C's Avatar
Send a message via MSN to Ricky/C
There is no official Tamiya part, maybe someone else makes one?! But why?
TRF 416 WE | LRP SPX Stock Spec| 17.5 SP | Sanwa M11
TRF 416 WE | LRP TC Sphere | Novak 3.5 | Sanwa M11
www.oneten.co.za >>>>>>>>>>>>>>>> Home of RC in SA
Ricky/C is offline   Reply With Quote
Old 03-31-2009, 06:00 AM   #4974
sohlman's Avatar
Trader Rating: 89 (100%+)
Are the Tamiya #51293 TA05-IFS hub-carriers 2 degrees or 4 degrees?
Steve Sohl
sohlman is offline   Reply With Quote
Old 03-31-2009, 06:17 AM   #4975
sagejyoung's Avatar
i'm thinking 4 degrees...
Old 03-31-2009, 06:20 AM   #4976
veecee's Avatar
Trader Rating: 34 (100%+)
Googling would have been faster than posting... 4 deg!
SMOKEM --- XPRESS --- HIRO SEIKO
veecee is offline   Reply With Quote
Old 03-31-2009, 09:52 AM   #4977
jonest's Avatar
Simple answer.... cause there is not really any impetus from anyone within TRF to do so
I know TRF USA is giving it a stab (massively comendable guys ), but from the EU and Japan boys and girls, it's a bit hard... Jilles poped on here for a while, but hasn't been here for a long time now.
Also, Marc is quite reknowned for not noting down his setups
Any of the ones you find, will tend to be taken by other people at the races, and then passed on...
HiH
Ed
Had a chat with David Jun of TRF US and one of the Japanese rep from Tamiya during the KLGP race here in Malaysia regarding the setups, the rep promised to update the website more frequently with the setups..... hopefully...
And it's great to see Jilles here again....
jonest is offline   Reply With Quote
Old 03-31-2009, 05:43 PM   #4978
CraigM's Avatar
Vesa Yli posted once that the V-Dezign deck was slightly stiffer than the stock 416 one. I've been using the V-Dezign one for ages because it was the first available but keep meaning to order a genuine WE one to see if there is much of a difference
P.s. for you guys with ageing 416s, check your spur gear spindle for wear underneath the pulleys. Mine are sloppy as and visibly worn!
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 03-31-2009, 10:25 PM   #4979
SammyZ's Avatar
Trader Rating: 138 (100%+)
what is a spur gear spindle?
SammyZ is offline   Reply With Quote
Old 03-31-2009, 11:44 PM   #4980
miccal's Avatar
Trader Rating: 23 (100%+)
Center shaft.
miccal is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
