Old 02-24-2009, 04:32 PM   #4531
CraigM's Avatar
Trader Rating: 34 (100%+)
You'll need to detweak it on a tweak station prior to doing that or your readings will be off side to side. I use the Hudy simple chassis balancing tool
http://www.amainhobbies.com/product_...ducts_id/32203
Jonest: I doubt it would be the weight causing your issue. Check the droop like John said, and make sure you haven't lost a pin from one of your uni's and your belts are intact
C/C will give a more direct steering feel compared with D/D. It's personal preference really, but I prefer C/C in most situations
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 02-25-2009, 02:37 AM   #4532
alan1467's Avatar
Looking at going lipo in my 416.
Whats lipo's are people using and did you have to modify your to desk to fit them or the conections?
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 02-25-2009, 06:39 AM   #4533
jonest's Avatar
Thanks guys, I'll check the droop and try the C/C combination this coming weekend race.
Thanks.
jonest is offline   Reply With Quote
Old 02-25-2009, 08:08 AM   #4534
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
For the orion pack I had to radius the upper deck a little so I could plug in the + wire. But the Thunder Power 5000mah 40c... didnt have to change a thing .. and it ROCKS!
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 02-25-2009, 09:25 AM   #4535
syndr0me's Avatar
Trader Rating: 32 (100%+)
Some thoughts...
Switching away from the Tamiya servo saver (to the Kimbrough) solved all the wandering issues I've been having. It doesn't feel as direct as a new Tamiya (without slop), but they don't seem to last long. Why isn't there a truly great servo saver out there?
I find the one-piece top deck feels better (carpet/rubber/13.5). The car is less twitchy, and seems more predictable overall. I've gone back and forth between them a lot, and keep ending back with the new version.
The car has always seemed a little prone to over-rotating. I went back to the Mazda6 (instead of the Speed6 and R9-R) and things feel a lot better. It's not as aggressive, but so much more predictable, and pleasant to drive.
syndr0me is offline   Reply With Quote
Old 02-25-2009, 10:13 AM   #4536
Originally Posted by syndr0me View Post
Some thoughts...
Try one of those aluminum servo horns for the tamiya servo saver . If theres any play , jam a small piece of thin cardboard where the springs meet the two halves . But the alu. arm should do nicely.
Old 02-25-2009, 02:54 PM   #4537
CraigM's Avatar
Some thoughts...
What rear wheelbase are you running? On low grip asphalt I have found a big difference between 2.5/2 and 3/1.5 in rotation.
Old 02-25-2009, 03:36 PM   #4538
Hebiki's Avatar
Trader Rating: 26 (100%+)
Some thoughts...
i recently had really bad wander on my car... then i switched from the tamiya white.. to the tamiya black with the aluminum middle piece and the wandering issues went away.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-25-2009, 03:55 PM   #4539
STLNLST's Avatar
Trader Rating: 19 (100%+)
Black is beautiful
STLNLST is offline   Reply With Quote
Old 02-25-2009, 05:53 PM   #4540
CraigM's Avatar
I was using the black with the alloy insert and it was still an issue. The kimbrough solved it
Old 02-25-2009, 05:54 PM   #4541
Hebiki's Avatar
awww crap. i hope mine doesnt go bad.
Hebiki Design Works
Old 02-25-2009, 06:30 PM   #4542
JimmyMac's Avatar
Kimbrough=poopoo! haha Like I said, turn the car on, grab the wheel/tire, and you can turn it by hand. They just give in too easy=lose of steering.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 02-25-2009, 06:52 PM   #4543
syndr0me's Avatar
1XA - 1E
Old 02-25-2009, 09:46 PM   #4544
CraigM's Avatar
Sorry I'm not talking toe I mean spacers in front/behind the arms
Jimmy, I got the extra stiff kimbrough but have yet to do that test. If it's that weak I'm just gonna stick an alloy horn on the servo and carry a spare
Old 02-25-2009, 10:14 PM   #4545
syndr0me's Avatar
Ah, silly me. It's whatever I grabbed off of Corey's setup. I haven't messed with wheelbase much at all, I generally just try and tune around it. :-) Perhaps that's my problem right there...
There's an extra stiff Kimbrough? Hmm, I'll investigate. Mine does seem a little soft.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
