Old 02-24-2009, 02:00 AM   #4516
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by tim fry View Post
Can anyone point me in the right direction for a cheap deal on a 416?
rcchamp was the best before the currencies went tits up, so I guess it depends how the pound is faring against the yen
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 02-24-2009, 03:15 AM   #4517
Ricky/C's Avatar
Send a message via MSN to Ricky/C
Originally Posted by gansei View Post
416 rear belt tensioner for extend center pulley and rear belt's life
How the heck did you get the weights on your chassis to look like CF???
TRF 416 WE | LRP SPX Stock Spec| 17.5 SP | Sanwa M11
TRF 416 WE | LRP TC Sphere | Novak 3.5 | Sanwa M11
www.oneten.co.za >>>>>>>>>>>>>>>> Home of RC in SA
Ricky/C is offline   Reply With Quote
Old 02-24-2009, 04:32 AM   #4518
tc3team's Avatar
CF look adhesive tape is my take...
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 02-24-2009, 04:56 AM   #4519
http://rcmarket.com.hk/product_info....oducts_id=1371
DarrenSimpson is offline   Reply With Quote
Old 02-24-2009, 05:25 AM   #4520
yonathanyoni's Avatar
Trader Rating: 25 (100%+)
Default TRF416WE
Hi guys! can anyone tell me where can i find Tamiya TRF416WE picture? and what is the different between standard 416 & 416WE? thanks a lot guys!!! cheers...
:. Running Quiet Cutting Deep .:
yonathanyoni is offline   Reply With Quote
Old 02-24-2009, 05:33 AM   #4521
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
There is a comprehensive list of the different features on this forum. Take a look back a few pages.
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 02-24-2009, 08:08 AM   #4522
jonest's Avatar
How about the difference in terms of performance between a 416 vs 416we?
Any1 can share his views or findings?
jonest is offline   Reply With Quote
Old 02-24-2009, 08:35 AM   #4523
Honestly ... the weight distribution is a little better . As far as my 4 scales can tell. Other than the new car being fresh... Not a whole lot. They sat the New upper deck makes more rear traction , but I think thats more about the 3.5 degrees of toe in in the rear. I kinda did a twist test and an A/B comparison. As far as racing goes ... I think not many people could tell the difference if they drove them one after the other.
Old 02-24-2009, 08:50 AM   #4524
STLNLST's Avatar
Trader Rating: 19 (100%+)
3.5 rear toe...... Why so much? Does the car need rear bite that bad?
STLNLST is offline   Reply With Quote
Old 02-24-2009, 09:04 AM   #4525
Korey Harbke's Avatar
More intial turn in, and increased weight transfer to the front off power/on the brakes since it creates a little more drag in the car. Then when you get on the throttle you have lots and lots of forward grip. It's something I was baffled about when a lot of guys went to 3 deg of rear toe on carpet with foam tires untill I tried it in mod. When the rest of the car is setup properly, it works really well.
-Korey
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 02-24-2009, 10:38 AM   #4526
-Korey
Outdoors ok... but on high bite carpet ... its too much toe.. too much drag. 3 is fine .
I ended up putting in both one ways as well. Car works great now. everything else is in kit form.
Otherwise the car would take forever to get thru the middle of the corner.... Oh yeah , I took 1mm out of the ackermen spacers too.
Old 02-24-2009, 10:44 AM   #4527
jonest's Avatar
When throttle, the car tends to swirl to one side, left if not wrong.... is it because the car is not balanced?
And I'm using front D/D, should I swap to C/C if track is smaller?
Old 02-24-2009, 01:18 PM   #4528
Thats deffinately a possibility . But I would check the droop in the front.
I bet one arm is lower than the other.
Old 02-24-2009, 01:21 PM   #4529
AWK
AWK's Avatar
Does anyone have a good tool to check the left to right balance of a chassis? I remember seeing one my MuchMore or Hudy but can't seem to find it now.
AWK is offline   Reply With Quote
Old 02-24-2009, 01:38 PM   #4530
Ok.. heres my $0.02 worth on that .
I've seen a half ball with a wire in it for balancing.
It looks like it works great! But....
For the money , Harbor Freight has a 0.1 increment up to 500 grams scale for $10 I got 4 of them. Theres even a little indentation in the middle so your drugs...I mean wheels find the center nicely. With 4 of them on a flat surface you can check weight distribution front to rear, left to right , and even check cross jack if you think its necessary. If you can get about 360 grams on every corner you are in like Flint!
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
