Old 02-09-2009, 12:24 AM   #4366
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
What length should the sway bar links be? It doesn't say in the manual.
Racing4Evo is offline   Reply With Quote
Old 02-09-2009, 01:13 AM   #4367
Kail's Avatar
Had my first race outing with my 416. Very drivable car: plenty of steering, tight back end, low tire wear rate, stayed very consistant throughout the 5 mins.
It performs quite a bit better than 415 and its diff is awesome.
Kail is offline   Reply With Quote
Old 02-09-2009, 03:13 AM   #4368
Best thing is to make sure the sway bar is horizontal when he car is is in normal position. But you should check to make sure the sway bar won't hit the drive axle during corner so lift you suspension arms and check if it hits. If it doesn't it's ok, if it does you should make the links slightly longer so the sway bar will be a bit higher.
Rick Thomson is offline   Reply With Quote
Old 02-09-2009, 07:26 AM   #4369
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
I know they dont but I know that they are suppused to be the same length and made to not bind up or crask into anything. Personally , I like to use shock ends and a 12mm grub screw. Looks good and its all Tamiya !
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 02-09-2009, 09:07 AM   #4370
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by bigkoitat View Post
It was actually a nice day today, good turn out. The only thing I changed from the set up was the shock position, went up one hole both front and rear on the towers. A couple of people drove my car and they seem to wash the rear end loose on almost all the corner exits. I had no problem driving it the way I had it setup, not all people drive the same I guess. The only problem i had was tire choice in practice and the Slash drivers using my car as a ramp as they cut across the track on the straight
Well I'm glad it worked for you, I wouldn't think that it would have worked out there. At least I know I'll have a good starting setup for when I come down
Old 02-09-2009, 09:33 AM   #4371
gansei's Avatar
415's aluminum rear upright on 416 we.
Tamiya TRF416 / TRF416WE / TRF416X-sany0010.jpg
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 02-09-2009, 10:01 AM   #4372
minimusprime's Avatar
Trader Rating: 19 (100%+)
that defeats one of the biggest improvements on the 416 tho... now you're back to running 950 bearings.
"I personally do not believe in luck. I believe luck is just an excuse for people that have failed in their mission to accomplish something." Allen McNish
minimusprime is offline   Reply With Quote
Old 02-09-2009, 10:23 AM   #4373
C van der Hagen's Avatar
The aluminium uprights are available as hop-up part for the 416, in 0 and 1 degree I believe
http://www.facebook.com/SepesRacingProducts
C van der Hagen is offline   Reply With Quote
Old 02-09-2009, 01:33 PM   #4374
hey can some of you guys that run the bitty design lipo tray post some pics with the battery all straped in. I want to get one but want to see what it looks like all mounted up. I want to put in my 415 msxx. Thanks
bigdog is offline   Reply With Quote
Old 02-10-2009, 01:23 PM   #4375
CraigM's Avatar
Trader Rating: 34 (100%+)
I'll take some shots when I get home, it's a nice bit of kit
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 02-10-2009, 01:42 PM   #4376
STLNLST's Avatar
Please post them. There are a few of us sitting on the bench waiting.....
STLNLST is offline   Reply With Quote
Old 02-10-2009, 03:01 PM   #4377
CraigM's Avatar
now you mention it, Ben posted some a while back...
Old 02-10-2009, 03:07 PM   #4378
Hebiki's Avatar
Trader Rating: 26 (100%+)
curious why you guys are using that tray? a 3800 sized lipo with a ppdbillet tray fits into a 416 with a slight modification to the upper deck to allow for a bullet connector to pass through.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-10-2009, 03:22 PM   #4379
I'm fitting in 5000 packs with the PPD tray with no modifications to the upper deck, modifying the + terminal on the pack so I don't lose any of the upper deck's structure.
Old 02-10-2009, 03:37 PM   #4380
CraigM's Avatar
I used the PPD tray with the SMC4000s, but the new 5200 40C pack is too high, and the 3000 or 3200 or whatever the smaller one is would be cutting it close for 6 minutes of 10.5 racing
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
