Like Tree3Likes
Old 02-06-2009, 01:08 PM   #4336
RC MARKET's Avatar
Originally Posted by doriftu View Post
Hi Rommel,
any plans to do the protectoer for 416 WE chassis?
We have TRF416WE Lower deck !
RC MARKET is offline   Reply With Quote
Old 02-06-2009, 03:01 PM   #4337
Rommel's Avatar
Originally Posted by CraigM View Post
Thats a negative, they've moved the batteries for WE
Thanks for the correction. I guess I will have to make one for the WE soon
Rommel is offline   Reply With Quote
Old 02-06-2009, 03:05 PM   #4338
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by bigkoitat View Post
Yes I am every other Sunday, and next Sunday at Hobby Town in San Marcos
Killer, when I started racing HobbyTown San Marcos was my first track. I've been down to DHW's track once, want to come again in the near future.
Old 02-06-2009, 04:14 PM   #4339
bigkoitat's Avatar
Trader Rating: 6 (88%+)
Sweet! Frank runs a good program, I have'nt missed a race since July. When my real car is running right I'm headed to Bending Corners.
JAWS
TRF-416WE & 416-X / DHW / TEAMRCR.NET
bigkoitat is offline   Reply With Quote
Old 02-06-2009, 04:21 PM   #4340
Do you have the 416 or the 416 worlds?
Old 02-06-2009, 05:01 PM   #4341
doriftu's Avatar
hi guys,
i need help on the WE spool
The screws on the pulley attached to the direct holder was loosen. I am having difficulty removing the direct coupling (BL10) to get to the screws. Any suggestions?
In the step7 of the manual, it was stated to remove the end of BL9 (which obviously I didnt). If so, how would this hold the direct coupling (BL10) in place?
Thanks in advance
I am referring to this step.
1)What does the instruction meant by 'remove' for derlin direct cup (BL9)?
2)I want to disassemble the spool and having difficulty removing the aluminum coupling (BL10) to start with.
Any help is much appreciated. thanks
six-shifter.blogspot.com
supercharged-e36.blogspot.com
doriftu is offline   Reply With Quote
Old 02-06-2009, 06:08 PM   #4342
To disassemble the spool, you just need to pinch the end of the outdrive (BL9) with pliers and slip the aluminum sleeve (BL10) off the end.
Old 02-06-2009, 06:41 PM   #4343
doriftu's Avatar
Thanks for the response Randy.
I am damaging the plastic outdrives (BL) and scratching the aluminum sleeve (BL10) with the pliers and not getting any results.
will try harder then...
Old 02-06-2009, 07:02 PM   #4344
bigkoitat's Avatar
I have the 416 World Edition, This thing is nice
JAWS
Old 02-06-2009, 11:20 PM   #4345
It's tough, but just keep at it and I'm sure you can get them off.
Old 02-06-2009, 11:21 PM   #4346
Well I have a setup posted on teamtrf.com for BCR, it's for the original 416 but should transfer fine to the new car if you end up going there.
Old 02-06-2009, 11:42 PM   #4347
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
I use a same size bearing to compress the plastic outdrives then I push the alloy sleeve with bearing the same time using a long nose pliers or body scissors. I find this method works best for me.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 02-07-2009, 12:39 AM   #4348
Sal Amato's Avatar
Trader Rating: 26 (100%+)
Can anyone tell me the difference between these two shock kits http://cgi.ebay.com/42102-TAMIYA-TRF...A1%7C294%3A200
http://cgi.ebay.com/Tamiya-53571-TRF...A1%7C294%3A200
360 RC SPEEDWAY 2.0
AWESOMATIX USA-SANWA--BSR--TEAM SCREAM --SWEEP RACING USA--TQ WIRE--ROCHE USA--LRP
Sal Amato is offline   Reply With Quote
Old 02-07-2009, 02:06 AM   #4349
TryHard's Avatar
Another option is to take you pliars, place them between the spool pulley and the bearing, and then lever against the bearing. With the bearing resting against the outdrive cover, should pop the cover off.
HiH
Ed
Old 02-07-2009, 07:44 AM   #4350
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Hold the spool on a 45 Degree angle.
Press down (on a hard surface) to one side of the delrin drive output piece while holding (and pressing down on) the aluminum ring.
Once the "Half" has pressed past the lip, It comes right off.
No harm... No Foul !
John St.Amant is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
