Old 02-04-2009, 06:20 AM   #4291
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Originally Posted by John St.Amant View Post
I've been trying many different ways and places to put that file but it always trunkates prematurely. The link (file) is incompleet or something . I cant even get it to go to my desktop. Damnit I realy want to check it out too..
Is there another place I can d/l it ?
ED!?
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 02-04-2009, 06:30 AM   #4292
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
guys, i've put the 416 calc on my web server..
http://www.epracer.com/docs/TRF416%2...0Calc%20v1.zip
maybe you can try it from here, its the same file that ED posted and it works for me?
-Mark
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 02-04-2009, 06:53 AM   #4293
TimPotter's Avatar
Thanks Mark,
That worked...
Old 02-04-2009, 08:00 AM   #4294
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by TimPotter View Post
Thanks Mark,
That worked...
+1
John St.Amant is offline   Reply With Quote
Old 02-04-2009, 10:43 AM   #4295
TryHard's Avatar
Originally Posted by CraigM View Post
Hi Ed, I noticed when you put the WE set up into the front page you get different static RC values than on the set up tab
Good spot Craig. I'll get the changed now. I only copied the values over from the previous version, so forgot to update it now it works properly... Doh!
@ Hebiki.
The static roll centre is calculated using the ground as a reference point, along the centre line of the car. Minus figures means it is below the ground, postitive above. In answer to your question... -5 would roll more than -2, as the roll centre moves closer to the Centre of Gravity (which I think we can safely assume is above the ground... )
HiH
Ed
Old 02-04-2009, 10:51 AM   #4296
TryHard's Avatar
right, updated version with correct kit setups.... and a how to use bit on the front page
Also, for thoose that can't get the zip too work (has to be a zip to post on here), the file is also on my website as the excel sheet here
Regards
Ed
Old 02-04-2009, 12:04 PM   #4297
@ Hebiki.
HiH
Ed
Okay so... static roll center instead of just roll center . What would I expect from a lower number ? More camber gain durring compression? Help me out here. Please and thank you .
Old 02-04-2009, 01:11 PM   #4298
TryHard's Avatar
Static roll centre is simply that, it's the point the car would start to roll around.
A lower static roll centre will give an idication of overall roll centre, and can be used as a guide for determining how the changes will affect it. As a rule of thumb, a lower roll centre will give more roll, and hence more grip, but slower reaction.
Roll centre moves as the car rolls (dynamicaly)... and thats way to complex for me to calculate!
HiH
Ed
Old 02-04-2009, 05:46 PM   #4299
HiH
Ed
Sounds good . But umm... How should I corrilate the static roll center with what im more concerned about . camber gain! is -4 in the rear what u get with stock 416we settings? no axel shim and kit comes with 4mm adapters.
-1.88 in front. on the guages im getting similar camber gain readings but twice the static value . I'm missing something here.
Old 02-04-2009, 07:37 PM   #4300
Rommel's Avatar
Now Available!
"Custom Cut Urethane Chassis Protector" for the TRF416 #49495.
Rommel is offline   Reply With Quote
Old 02-04-2009, 07:55 PM   #4301
CraigM's Avatar
Trader Rating: 34 (100%+)
the static rc is a reference point, it's where the centrifugal force is applied when the car rolls. -1.88 means it's 1.88mm below the centre of rotation, so the centrifugal force has little leverage on the car compared with the rear which has more than twice the leverage at -4mm i.e. the rear will roll more and should grip accordingly.
Put another way, I don't believe the static RC height has a direct impact on camber gain, but rather you can achieve the same RC while altering the camber gain via the upper arm lengths
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 02-04-2009, 09:47 PM   #4302
I had spent an hour or so playing with #'s here and there.
Confusing a bit I'd say as the width of the car changed , so did the Static Roll center . More negative . from wider . then it hit me.
I am going to like this tool . If some one could ascimilate a profile of an upright and some pivot points so one could analize the geometry at work.
That would be outa sight ! line segments would do just fine.
Old 02-04-2009, 10:11 PM   #4303
bigkoitat's Avatar
Trader Rating: 6 (88%+)
I know this qustion has been answered elsewhere on this thread but I just ordered the 416 WE car and noticed the front swing shaft is aluminum. So I ordered the steel swing shaft, the question I have is what is advantage of the 46 over the 44? The specs on the car showed 44 for the front and rear, and I read in this thread and on Tryhard's site to go with 46's.
JAWS
TRF-416WE & 416-X / DHW / TEAMRCR.NET
bigkoitat is offline   Reply With Quote
Old 02-05-2009, 04:56 AM   #4304
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Anyone have a 416WE topdeck they want to sell here in the US?
Thanks,
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 02-05-2009, 06:18 AM   #4305
Stein Tumert's Avatar
Thanks,
Jimmy
NO, but there is a company in Finland selling one they make themselves. If you look back in this thread you will find it. They have great service and fast delivery.
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
