Like Tree3Likes
Old 01-25-2009, 03:07 PM   #4171
miccal's Avatar
Trader Rating: 23 (100%+)
Is there a reason you are using TRF415MSXX-style steering linkages?
Originally Posted by TimPotter View Post
Since were showing chassis...
My wiring is such hack, cannot come close to Randy or the like... But I bet my diff covers are unique.. And is it sacrilege to have spring steel turnbuckles ?
miccal is offline   Reply With Quote
Old 01-25-2009, 03:12 PM   #4172
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by CraigM View Post
you didn't get short changed, they sell the back piece separately for about the same as the front piece. $50 servo saver anyone? Personally I bought the front bit because I see the pros using it, but didn't notice any difference
Blue IS Better ! Bling BLUE Bling thing.
John St.Amant is offline   Reply With Quote
Old 01-25-2009, 03:58 PM   #4173
TryHard's Avatar
You mean the Titanium ones over the alloy ones....
As for the servo saver... if you compare the alloy one with a new kit one... you probably won;t see much difference, however give it a few runs, and the plastic one wears badly, and becomes quite sloppy. With the Alloy front plate, this doesn't happen, stays nice and tight
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-25-2009, 04:06 PM   #4174
HiH
Ed
The Ti ones are $33 a pair.
Old 01-25-2009, 09:12 PM   #4175
miccal's Avatar
No that is not what I meant, I was referring to the steering arms. The ones in the picture appear to be off the TRF415MSXX, they are not the TRF416 ones. I circled what I meant.
HiH
Ed
Old 01-26-2009, 05:11 AM   #4176
Hard to tell from that angle. But it looks right to me. I refer to that as the steering rack, or bell crank. Pretty sure the 415 and 416 have different ones, but then again, anythings possible.
Old 01-26-2009, 05:15 AM   #4177
miccal's Avatar
Of course they do, hence my question!
Old 01-26-2009, 05:37 AM   #4178
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
I bought the car used so, I cannot answer that, I thought those were the right ones, but then again, with this car I keep on finding surprises every time I work on it.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 01-26-2009, 10:17 AM   #4179
Stein Tumert's Avatar
Well, he writes "spring steel", can't tell from the picture, but if it is "spring steel" then we are normally talking Hudy/XRAY....
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 01-26-2009, 10:22 AM   #4180
Koen's Avatar
If you read the rest of the tread you can see he doesn't mean this and that there's already an answer
Koen is offline   Reply With Quote
Old 01-26-2009, 01:07 PM   #4181
TryHard's Avatar
ahh you were looking at Tim's car... I was looking at sohlman's...
But your right, they are the 415 MSXX bell cranks... although you do have the 416 cross brace. Have a look at the two attached pics.
The old bell cranks are longer, so move the whole steering forward, which changes the ackerman as well (the piviot points in the steering would be different)
HiH
Ed
Tamiya TRF416 / TRF416WE / TRF416X-steering-1.jpg   Tamiya TRF416 / TRF416WE / TRF416X-steering-2.jpg
Old 01-26-2009, 01:29 PM   #4182
TimPotter's Avatar
Thanks Ed, did not know.. Thanks miccal for pointing that out, another surprise....
My guess they were put on there so more ackerman can be used without shimming the hell out of it..
Old 01-26-2009, 01:38 PM   #4183
Hebiki's Avatar
Trader Rating: 26 (100%+)
HiH
Ed
Ed, that used to be my car. i put those on there to try out. ended up leaving them on there since i liked it better.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-26-2009, 02:25 PM   #4184
miccal's Avatar
No problem.
What was better about it?
Old 01-26-2009, 03:29 PM   #4185
CraigM's Avatar
Trader Rating: 34 (100%+)
Ok guys, I'm having a bit of a handling issue and it's got me a bit stumped
Ever since getting back from the nationals last year I've had a lift off oversteer problem in the tightest corners of the tracks I race on. The only way I've been able to combat it is by lengthening the rear wheelbase but this is hurting my steering elsewhere. I'm running minimal rear droop so that's not the issue, and the only thing I've done differently to my old set ups running fractionally (2mm) more rebound at the rear than I did before. What's the best way to calm the whole thing down? I was thinking of going a little thicker with oil (running 400wt at the mo) all around and drilling vent holes in the top of the shock to take out some of the pack
also has anyone been able to make the WE front shock mounting positions work? it's been hard to tell with the issue above but whenever I incline my front shocks down to hole 2 on the damper stay my car seems slower
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
