Old 01-23-2009, 02:07 PM   #4126
Randy Caster's Avatar
Trader Rating: 46 (100%+)
And quite a bit darker.. Square has blue screws that look like they should match Tamiya.
Old 01-23-2009, 08:03 PM   #4127
Trader Rating: 28 (100%+)
I am about to put the short arms on my 416 and has a question. There are 2 sets of hole on the arm that are for the shocks and roll bar. (one set of holes is more outward than the others) How do I determine which set of holes are for the shocks?
Thanks.
joech is offline   Reply With Quote
Old 01-23-2009, 09:16 PM   #4128
Thanks.
Any of the holes can be used for the shocks, the arms can be flipped so that you have the option of making smaller adjustments. On my car, I'm running the outermost holes on the front, and 1 in from the outermost holes on the rear.
It's a nice feature, as now instead of 2 holes for adjustment, there are 4.
Old 01-23-2009, 09:17 PM   #4129
And my WC kit is slowly turning into a car
Tamiya TRF416 / TRF416WE / TRF416X-1232773933493.jpg
Old 01-23-2009, 09:20 PM   #4130
STLNLST's Avatar
Trader Rating: 19 (100%+)
I wouldn't have built two by now
STLNLST is offline   Reply With Quote
Old 01-23-2009, 09:21 PM   #4131
I prefer STLN1ST
Old 01-23-2009, 09:24 PM   #4132
STLNLST's Avatar
I prefer STLN1ST
Due to our current sponsor situation I can't comment Teammates don't battle each other.....besides....after this weekend we won't know which car is which. I'm jacking paint schemes....
Old 01-23-2009, 09:54 PM   #4133
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Well my new 416WE is running very nicely and was fast enough for pole position Friday night. But, as fate would have it, a few racing incidents and some back markers made the Main quite interesting. Eric Whipler passed me with 2 mins to go and all I could do was push hard. The car was excillent !
Will said my car was SICK ! Thats good right I cought up to the Whip but an off line excursion and another scary moment was too much for the 44mm aluminum swing shaft. Finished in 2nd with 3 wheel drive. Eric was driving fast as I've ever seen a 05IFS. Nice run BTW Whip! I'm praying the metal ones I ordered are here before next Friday.
John St.Amant is offline   Reply With Quote
Old 01-24-2009, 05:31 AM   #4134
Koen's Avatar
which servo-saver are you guys using on your 416? I see many squares on the photo's and I heard that Kimbrough are also really good, but... which one do I have to take? There are so many types, not only Kimbrough but square makes also more than one...
Koen is offline   Reply With Quote
Old 01-24-2009, 06:02 AM   #4135
dameetz's Avatar
Do you guys shim your spur gear assembly? Mine has lot of play, you can move it left,right. The instruction says to put one 0.2mm shim on each side of the shaft before you put the flanged bearings, I think its not enough or is it designed like that to have some play for whatever reason for it?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 01-24-2009, 06:34 AM   #4136
Koen's Avatar
I use 3 shims on the left and 2 on the right side, all of 0,2mm. The spur has just a very little play and the belts are perfect in the middle. On the belt tensioner I use a extra 1mm shim and it looks all perfect now
Old 01-24-2009, 06:35 AM   #4137
The paint scheme is only for me!
Old 01-24-2009, 06:39 AM   #4138
I'm using the kit servo saver with the Tamiya aluminum horn.
Old 01-24-2009, 09:06 AM   #4139
dameetz's Avatar
Thanks, any more building tips? I just filed the front and rear edges of the upper deck as it seem to be a bit longer. I noticed this when I trial fit it with front, rear bulkhead and steering system assembled. Somehow I have force it into place. Now it fits nicely. Did you guys also filed the upper deck? I hope i made the right move.
Old 01-24-2009, 09:29 AM   #4140
Kail's Avatar
Anyone can give a fair comparison between 416 and the wce edition? Thanks!
Kail is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
