Old 01-15-2009, 01:35 PM   #4036
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Adam? View Post
Any objection to petitioning a moderator to remove the (no joke) from this thread's title? If we can get it renamed, what should we call it?
no need to petition. its done. thank the moderator Tony Phalen.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-15-2009, 01:52 PM   #4037
STLNST : you have made a good choice, the MRE is a great car and real easy to drive or set up, easyer than the 416. the car can take a good beating. and when built in the right way, you will have no problems what so ever.
TRF414x / TRF414 / TRF414 conversion pack / TRF414M / TRF414M2 / looking for a 414WCR / TRF414M2 SSG / TRF415 / TRF415MS / TRF415 MSX coversion / TRF415MSX / TRF415MRE / TRF416 / TRF416WCE/TRF501X / TRF501WC
gizmo is offline   Reply With Quote
Old 01-15-2009, 02:14 PM   #4038
STLNLST's Avatar
Trader Rating: 19 (100%+)
That's what I've seen at the track. I'm looking forward to running this car.
STLNLST is offline   Reply With Quote
Old 01-15-2009, 02:41 PM   #4039
Trader Rating: 62 (100%+)
Dameetz, those outdrives will not work, they are for the 415 series spool. The 416 spool outdrives are different. I used to use those but the hardenend dog bone pin tore through them pretty fast, that was in modified though, in other classes they might be fine.
Clint, if your going to run modified on asphalt, the 416 is a much better choice, a lot more stability. For carpet or stock, the MRE will be a real good car. Have fun!
patrick is offline   Reply With Quote
Old 01-15-2009, 02:44 PM   #4040
Hebiki's Avatar
are we gonna see you at TCS this year?
Hebiki Design Works
Old 01-15-2009, 05:32 PM   #4041
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by STLNLST View Post
Yep...passed on the 416. Until I get beat by one there's no need right
So all I'd have to do is come up there, race for a day, and you'd need to get a 416?
Old 01-15-2009, 08:01 PM   #4042
STLNLST's Avatar
I'm not running mod anymore so I'm good but I have seen this car keep up and beat the local mod driver quite a few times so I think I'll be alright. I'm all 13.5 for now.
Come on up. Better bring a 13.5 I remember the last time I issued a challenge was when the original jrxs came out. I offered to pay a racer's entry fee if they ever beat me with that car. Never had to pay up on that deal....I don't expect the 416 to ever handle like that car The price was killer so for what I'm getting.
Old 01-15-2009, 08:11 PM   #4043
I'm new to RC, I want to know what pinion and supr i need for running 4.0 brushless and 23T motor? thanks
ioxqq is offline   Reply With Quote
Old 01-15-2009, 09:09 PM   #4044
PutAwayWet's Avatar
Ask the question in terms of your Final Drive Ratio (FDR).
FDR equals your spur teeth/pinion teeth times your Internal Ratio.
Your Internal Ratio is your diff pulley teeth/center pulley teeth. (If you ever run a shaft drive it's your ring gear/bevel gear). It's 2.06 for the TRF416.
To cover the two motor combos you've quoted I'd probably run the 105t kit spur.
I've run 23t and had good luck in the 6.25 to 6.5 FDR range. That's six cell.
So, with a 2.06 Internal Ratio, a 105t spur and a target FDR of 6.5 calculate your pinion thus:
2.06*105/6.5=33t pinion
Shoot for a motor temp between 140 and 160 deg. Fahrenheit. You shouldn't burn up brushes too badly there.
Can't help you on the 4.0 brushless. But if someone has a conservative ballpark FDR to start with you're good to go to calculate it yourself.
PutAwayWet is offline   Reply With Quote
Old 01-15-2009, 09:12 PM   #4045
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
22... check temp frequently..
John St.Amant is offline   Reply With Quote
Old 01-15-2009, 11:50 PM   #4046
dameetz's Avatar
Is there a front one way for 416WE? Can you pls give part no for it?
dameetz is offline   Reply With Quote
Old 01-16-2009, 01:24 AM   #4047
Stein Tumert's Avatar
Yes, The original 416 came with one-way
3454520 TRF416 one way housing
9444623 TRF416 Freilauf Ausgänge
There is also availlable
49492 TRF416 "Middle One way" (Mittel-Freilauf Set)
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 01-16-2009, 04:55 AM   #4048
lyoha's Avatar
Originally Posted by JamesArluck View Post
what the handling differences are between the two before I drop 80 bucks on the WE chassis.
One piece long top deck, battery moving forward, new motor bulckhead, front direct drive, new drive belts, front 1C/1C and rear 1XA/1F lower suspension brackets.
Tamiya TRF-416WE - Speed Passion GT V2.0 - EPIC 10.5
BMI12RR - Sphere SSX - Vector X12 4.0
CRC Gen-X - Speed passion GT - Orion Vortex 5.5
Futaba T3VCS 2.4 FASST
lyoha is offline   Reply With Quote
Old 01-16-2009, 05:12 AM   #4049
I think he was only asking if the new 416 WE chassis plate handles differently than the original 416 chassis and if it is worth getting one for his original 416.
Stein Tumert
Old 01-16-2009, 05:19 AM   #4050
lyoha's Avatar
He asking:
Has anyone tested the original 416 chassis and the WE chassis back to back?
I`m compare both chassis - my(416WE) and my buddy(416).
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
