Old 01-14-2009, 05:54 PM   #3991
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
Originally Posted by Hebiki View Post
i wish tamiya would release alum. rear hubs. thats my biggest problem is the ball stud backing out of a rear hub and the hole gets stripped.
check out the Square aluminimum parts found here...
http://www.rc-square.de/english/index.htm
these parts are made with exceptional quality and i know they have aluminium uprights, c-hubs etc for the TRF range of vehicles...
wouldnt worry about ordering from him either, everything arrives
-Mark
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 01-14-2009, 06:02 PM   #3992
Hebiki's Avatar
Trader Rating: 26 (100%+)
-Mark
Mark,
thanks for the link. but unforunately i keep all my Tamiya cars in TCS trim. both the 416 and TB-03 only get tamiya hopups that way i know im always legal for TCS racing.
- Chris
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-14-2009, 08:53 PM   #3993
STLNLST's Avatar
Trader Rating: 19 (100%+)
Well....I got my car already. My buddy took care of me and I will will be running the 415MRE. Looks like my TRF career will begin on carpet when I race next. I'm no crip but I'm sportin' blue....
STLNLST is offline   Reply With Quote
Old 01-14-2009, 08:56 PM   #3994
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by John St.Amant View Post
thats pretty cool but very light . It would be much better if it weighes like 4 oz. and its pricy.
Agree on the weight, my PPD is 3oz (whatever an oz is), so I plan on putting a 2.2oz lipo lead in the bitty design tray when it arrives
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-14-2009, 08:59 PM   #3995
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
oz. is an ounce man. or 28 grams
John St.Amant is offline   Reply With Quote
Old 01-14-2009, 09:03 PM   #3996
Originally Posted by StickyFingaz View Post
Fo sho. HELLA dialed...
I gotta admit though, I like the car better w/ the Sorexes.
Question for everyone else: Where can I buy a new style lower deck?!? You think the new batt position will really make a difference if I'm running Li-Po? I'm strapping weight everywhere on the car anyway...
Cheda bob makes a nice tray for a 416 .. tell him I sent you and he will charge you more . jk it weights almost 4 ounces and fits perfectly in the car . let alone puts the weight where u want it. LOW
Old 01-14-2009, 09:24 PM   #3997
Adam?'s Avatar
I shoo goo the individual weights from PPD to the bottom of my packs. It locks them in place so they don't move, gets some weight down low, and they're easy to remove when you're done. Then I servo tape some tungsten plates to the outside top and side edges of the pack, and sometimes a couple on the inside. They're 14g each, so it ads up quick. If you cover them in CF stickers, they look pretty dialed. I'm right at 1500g with weights one the pack only, and nowhere else. Balance is good since the weights are on the far edge of the pack.
This method lets the pack sit flat on the chassis, so you can use the 5000 packs like those from SMC and TP.
The guy that makes the Manutech plates is a fellow racer, and might be encouraged to make some 416 plates if there's a demand. They're brass, but work great if you've got a shorter pack, like an SMC 4000. The new packs have reliefs cut in them to let packs with nubs on the bottom sit flat.
Adam? is offline   Reply With Quote
Old 01-14-2009, 09:37 PM   #3998
3.141592's Avatar
I actually have this in mind but not sure that it really helps...i have a grub screw in the other hole in the rear hub which i thought would prevent the hole that you mount from collapsing and shearing under large impact. This is just a thought which i used to do it for my 2WD buggy and I have been running my current rear hubs for almost a year now and still ok...touchwood!
Originally Posted by Randy Caster View Post
I've made a modification to the hub that is an easy fix and makes it WAY stronger. Just take a 2.5mm drill bit and drill through the hole where the ballstud mounts on the hub so that it can thread in as far as it needs. This way you don't have to go to the short stud, or cut down the long one.
3.141592 is offline   Reply With Quote
Old 01-14-2009, 10:25 PM   #3999
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Dang, that was quick!
Let us know how it goes
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 01-15-2009, 12:09 AM   #4000
STLNLST's Avatar
He made me a deal that I couldn't pass up. Basically he made my mind up for me
Old 01-15-2009, 12:36 AM   #4001
dameetz's Avatar
A friend of mine got a 416WE, on the very first drive he broke the front plastic drive cup from the stock solid diff without hitting anything. Does tamiya or any other company has an upgrade for this? At the moment he's opted to get a normal diff up front which has aluminium drive cup.
dameetz is offline   Reply With Quote
Old 01-15-2009, 01:59 AM   #4002
CraigM's Avatar
The new SMC C-Max 5200 pack will still be too tall
I'd say he put the eccentric spacers in upside down
Old 01-15-2009, 03:34 AM   #4003
doriftu's Avatar
Adam,
how do you remove the shoo goo? What solvent you use or u just yank them out?
six-shifter.blogspot.com
supercharged-e36.blogspot.com
doriftu is offline   Reply With Quote
Old 01-15-2009, 03:48 AM   #4004
Low_E's Avatar
Send a message via MSN to Low_E
yup, been there too
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 01-15-2009, 03:59 AM   #4005
Default Need Help
I just wondering if anybody can tell me is there any front differential part for TRF 416? What is the part number for it? Thanks
Kalel is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
