Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 01-11-2009, 12:16 PM
  #3916
habis's Avatar
Just returned from DHI with Marc as the winner.
find videos here
http://www.rctv.dk/dhi2009/index.html
Just spoke to the TRF team on the new car and set up. On this years DHI they all used the WE with the set up from last year only changes was:
Oil: MuchMore 550 F/R
Sus Mount C/C, aX/E
Rear damper in Hole 4
Through out the race they stayed almost the same - but played a little with the rear damper position and oil and D/D vs C/C
Another thing was the one piece top deck- they played alot around with the topdeck -to provide enough rear flex- they use the old two piece deck or the 2 piece deck with the rear brace cut in two or when using the one piece, they took out screws
PS: if your delrin cups is worn by the swing shaft cut a grove in the cup - it will prevent the free movement of the suspension arm and can create a unstabile car
habis is offline
Old 01-11-2009, 12:44 PM
  #3917
habis's Avatar
see lower corner on the muchmore tray - the cut brace
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-cimg0292.jpg   Tamiya TRF416 / TRF416WE / TRF416X-cimg0319.jpg   Tamiya TRF416 / TRF416WE / TRF416X-cimg0287.jpg
habis is offline
Old 01-11-2009, 12:59 PM
  #3918
Wholy Ship Batman! Look at all the fuzz on the axels !!!
I was going to do the suspension upgrade but once I started figuring all the whatevers I just broke down and picked up the WE kit. I got a 416 for sale cheap now.
John St.Amant is offline
Old 01-11-2009, 01:55 PM
  #3919
Trader Rating: 27 (100%+)
Originally Posted by tonyv
Hi Mark, good to see my archnemesis from the 2004 worlds driving a real car for a change
Yes, and the rear piece appears to be cut through the middle.
Nice to hear from you Tony. You have to admit that 2nd Main had a dramatic ending
Tamiya has been good for me. It got me a TCS Championship title. It will be fun sharing notes. You always had great insight for Xray drivers when you ran for them.
MDawson is offline
Old 01-11-2009, 02:31 PM
  #3920
Adam?'s Avatar
Oooh, I see some TRF guys using an iPhone. They should check out igearchart.com! :-)
Adam? is offline
Old 01-11-2009, 02:33 PM
  #3921
CraigM's Avatar
Trader Rating: 34 (100%+)
find videos here
Sus Mount C/C, aX/E
thanks for the report! nice to see some good looking podium girls too, nitro offroad has a lot to answer for
CraigM is offline
Old 01-11-2009, 02:34 PM
  #3922
Yeah Mark, that second one was fun. Deserved two winners
It'll be a pleasure sharing notes. Been running the car almost a year now and love it. So easy to get it right. And as long as you keep an eye on the diff, the bearings and the spool outdrives it is also easy to keep it running well.
Drop me a PM or e-mail when you have something to discuss.
tonyv is offline
Old 01-11-2009, 05:09 PM
  #3923
Default i can buy 416WE in web (HK) ??
i can buy 416WE in web (HK) ?? i check many web is out stock
mamaa is offline
Old 01-12-2009, 04:33 AM
  #3924
habis's Avatar
try vellrip in SG, he has one.....
habis is offline
Old 01-12-2009, 05:11 AM
  #3925
habis's Avatar
hey.....so you like the podium girls
http://www.racerc.dk/video/dhi%20cup%202009%20slut.WMV
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-dhi_2009_0516.jpg   Tamiya TRF416 / TRF416WE / TRF416X-dhi_2009_0633.jpg   Tamiya TRF416 / TRF416WE / TRF416X-dsc_0454.jpg
habis is offline
Old 01-12-2009, 09:38 AM
  #3926
Trader Rating: 26 (100%+)
does the 416 wce come with a spool a one way or both. also which suspension holders does it come with
eddie10 is offline
Old 01-12-2009, 09:55 AM
  #3927
habis's Avatar
Comes with a spool and with C/C, Ax/F..........exchange the F with E
habis is offline
Old 01-12-2009, 10:20 AM
  #3928
RC MARKET's Avatar
no !
RC MARKET is offline
Old 01-12-2009, 10:38 AM
  #3929
habis's Avatar
Originally Posted by RC MARKET
no !
RCMarket: when do you expect to restock????
habis is offline
Old 01-12-2009, 11:18 AM
  #3930
there are more holes in the shock towers for top shock mounts .
diffs are externally adjustible and have knotched drive rings.
(1C,1C inverted+3mm)/(1XA+0.5mm,1F+0.5mm) from front to rear.
hope that helps you.
