Old 01-06-2009, 05:58 AM   #3886
I did a quick measurement of the stiffness of a brand new 416 and the 416WE main chassis when assembling my new car. The WE chassis was 10-20 % softer.
My experiance of the 416 when testing diffrent stiffness upper chassis has mostly been that softer is better for me.
moonman is offline   Reply With Quote
Old 01-06-2009, 11:51 PM   #3887
Adam?'s Avatar
On carpet with rubber tires (13.5) the car didn't feel nearly as direct with the new top deck. I suppose that's to be expected, as it seems to be meant for asphalt, but I figured it was worth a try. I'll keep it in the box for bad traction days.
Adam? is offline   Reply With Quote
Old 01-07-2009, 11:15 PM   #3888
CraigM's Avatar
Trader Rating: 34 (100%+)
Heres some idle chatter that may be of use to people...
I bent one of my C blocks the other day and took it as an opportunity to try some different suspension blocks up front. First I tried C/B, so a fraction narrower but .5 deg of sweep. This gave a bit too much steering off power but not enough on. Then I tried D/D again, which I had tried before but not with the HPI springs. This combo worked great, compared to C/C the steering is less direct but this made corner entry smoother and for me its easier to drive consistently
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-08-2009, 02:11 AM   #3889
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
what if you now went back to C/C and used a 0.5mm spacer on the wheels?
this would keep the D/D track width, but with the C/C roll centers....
curious to me anyways, as i am wrestling with these sorts of setup changes myself atm...
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 01-08-2009, 04:26 AM   #3890
veecee's Avatar
Nice findings Craig. I smoked my motor on my 2nd run so didn't get to try much...
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 01-08-2009, 09:23 AM   #3891
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Any have feedback on the belt question....
Thanks...
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 01-08-2009, 09:28 AM   #3892
RC MARKET's Avatar
Thanks...
old or new belts ?
RC MARKET is offline   Reply With Quote
Old 01-08-2009, 03:08 PM   #3893
TryHard's Avatar
TBH, I've found the car to be better with the cut brace regardless... Even on very high grip carpet and rubbers. Pretty much everyone else I've spoken whoose either tried a cut brace or new top deck ahs said the same thing...
Old 01-08-2009, 04:17 PM   #3894
Trader Rating: 21 (100%+)
Which brace are you referring to as the 'cut brace'?
Btw, great site!
MDawson is offline   Reply With Quote
Old 01-08-2009, 06:49 PM   #3895
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by CarKing View Post
I was looking for a little input from Ed or anyone familar with this kit if people are using 2 or 3 hole pistons on outdoor asphalt.
2
John St.Amant is offline   Reply With Quote
Old 01-08-2009, 06:59 PM   #3896
Trader Rating: 26 (100%+)
if i was to space my wheels out 1mm what will that do to my handling characteristics?
eddie10 is offline   Reply With Quote
Old 01-08-2009, 07:17 PM   #3897
CraigM's Avatar
ah multiquote is back
and you would have more camber rise compared to D/D due to the shorter links. hrmm
I heard about that, I almost did the same earlier - the faster track really builds the temps!
Originally Posted by John St.Amant View Post
2
Most asphalt set ups I've seen use 3
According to the setup books, wider track gives less traction. I think the idea behind spacing though is to give you a particular width regardless of what blocks you're using. So you might use D/D with no spacers, or C/C with .5, or B/B with 1 and have the same front track. By doing this you are changing RC and camber rise without altering the track, so the traction gained or lost is all RC and not track width related
Personally, I space my rear wheels by .5mm when using D/D because I've been told not to run a wider front track than rear, and the rear is narrower than the front when using D/D XA/E without rear wheel spacers. I've never tried having a narrower rear, but people on here have and make it work.
As John has mentioned previously, you may be flirting with danger running 1mm of spacers in a wheel with a shallow hex. I've never had issues with .5 and rubbers on asphalt, but foam on carpet would be another story
</megapost>
Old 01-08-2009, 10:23 PM   #3898
maxepower's Avatar
Btw, great site!
Hey Mark,
What's up? I thought you were running Kyosho! Welcome back to the "DARK SIDE". Or is it the Dark blue side. Yes, TRYHARD'S website is excellent for info on the 416 and the 415.
maxepower is offline   Reply With Quote
Old 01-08-2009, 10:24 PM   #3899
Superkarter's Avatar
Hi Craig
I've been told and have tried it myself that a narrower rear track than the front will make the car want to understeer and vice-versa.
Tim
Superkarter is offline   Reply With Quote
Old 01-08-2009, 10:58 PM   #3900
mok
mok's Avatar
my experiences have been that 0.5-1.5 is safe, but 2mm of spacers I would not..
(this has all been with rubbers on either carpet or asphalt)
i have been using speedmind, vtec, much more, tamiya and sorex rims with anywhere up to 1.5mm of spacers and never had a wheel come off..
i've got a tendency to believe that as long as about 1mm of wheel hub goes inside the rim then you should be ok (freak occurances aside )
i think realistically though, if you want 1mm or more of spacers then you should be moving to the 6mm hubs
-Mark
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
