Old 01-04-2009, 02:42 AM   #3856
Low_E's Avatar
Send a message via MSN to Low_E
but then don't you have to tune with different foam disks needed to insert above between bladder and shock-cap?
And isn't it difficult to make 4 the same foams every time, as the thickness of this foam must make a difference, I guess.
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 01-04-2009, 06:57 AM   #3857
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
I've been using the alloy spacers and the thicker they are the more rebound you get. 2mm gives me pretty much full rebound and 1.5mm is half that and 1mm is almost none. No making and guessing here and I've been getting the same rebound on all 4 shocks so far
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 01-04-2009, 09:46 AM   #3858
Stein Tumert's Avatar
What "alloy" spacers?
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 01-04-2009, 12:16 PM   #3859
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Use o-rings.
Its about pack... do not overwill the shocks w/oil.
John St.Amant is offline   Reply With Quote
Old 01-04-2009, 12:39 PM   #3860
Adam?'s Avatar
Yeah, I'd probably use o-rings since they don't compress as much. At the moment, I'm running exclusively on high-traction carpet, and the car seems happier with less rebound, so I'm not messing with with adding anything inside. Shock caps are inexpensive, so it's easy enough to have another set on hand if you want to build them back up the normal way.
Adam? is offline   Reply With Quote
Old 01-04-2009, 01:54 PM   #3861
danjoy25's Avatar
Its the same spacers we use for camber link height, steering throw & track length adjustments.
Old 01-04-2009, 02:00 PM   #3862
Randy Caster's Avatar
Trader Rating: 45 (100%+)
Originally Posted by Adam? View Post
You should see the rip with an SMC or TP LiPo over the Orion! :O
When I do run a spec class like 10.5 I use the Orion 3800 LiPo packs and have never had a problem with someone having more power...
Old 01-04-2009, 02:03 PM   #3863
MuchMore makes a set of foam disks for above the bladders that has been the best way I've found to fine tune if you're running a hole in the cap. They come in a set with 3 thicknesses and then super thin double sided tape incase you want to make your own sizes.
Old 01-04-2009, 02:58 PM   #3864
STLNLST's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Xray To The Max View Post
Hey Guys,
I Thought i may be able to help you with Springs.
Brand/Colour......Comp./ Ratio
Hara Yellow..........12.89lb/230g
Hara White...........13.98lb/250g
Hara Black............15.11lb/270g
HPI Blue...............15.3lb/273g
Hara Purple...........16.24lb/290g
HPI Silver.............16.9lb/302g
Hara Red..............17.36lb/310g
HPI Pink...............18.0lb/320g
HPI Gold...............19.0lb/340g
HPI White.............20.3lb/363g
HPI Yellow............21.7lb/388g
HPI Red................22.4lb/400g
I Hope this Helps
Kind Regards,
Ryan.
Are you sure of the ratings? I thought the Hara silver was 14lbs???? You have the white listed at 13.98lbs I will have to double check all my spring rates and compare them to what you have posted.
STLNLST is offline   Reply With Quote
Old 01-04-2009, 03:02 PM   #3865
STLNLST's Avatar
I will be running the 3800 this weekend in 13.5 against the SMC and TP packs. I'm sure I'll be more than happy with the power. Scotty ran a 3600 at last years Reedy and won one of the Amain races with it against the SMC and whatever else others were running. Too many people bench racing C ratings.
Old 01-04-2009, 04:16 PM   #3866
Hi Guys,
Why you don't use Tamiya Springs? Are them not so good compared with other out there?
Thanks for your feed back.
lynx75 is offline   Reply With Quote
Old 01-04-2009, 04:37 PM   #3867
Adam?'s Avatar
Eh, I'm not a huge fan of bench racing, or mythical C ratings. I'm glad they're working out well for you guys. I'm sure your team manager is thrilled!
Old 01-04-2009, 04:59 PM   #3868
I'm sure you'll be happy with the stuff, it's been good for me. I've finally got the new motors figured out and they are up to speed with anything out there from what I've seen.
I'm not putting down any other manufacturers products, I just saw that someone is claiming you will smoke the Orion batts with other brand batteries, and in my experience that couldn't be further from the truth.
Old 01-04-2009, 06:45 PM   #3869
Xray To The Max's Avatar
Hey,
Haha, Sorry Man, i think i may have just put white instead of Silver. Sorry, no idea what i was doing
So with Hara Springs, you will have:
Red is Super Hard
Purple is Hard
Black is Medium
Silver is Soft
Yellow is Super Soft
I hope this helps, im sorry if i confused anyone
Kind Regards,
Ryan.
Ryan Maker - Team Xray - Hudy - Speed Passion - Ko Propo - Ryan Dezign.
Xray To The Max is offline   Reply With Quote
Old 01-04-2009, 06:47 PM   #3870
i bet you could check a lot of springs and most of them would be close but different enough. somehow i dont believe they are made with such strict standards as maybe the k-factory or x-ray springs.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
