Old 01-03-2009, 01:55 AM   #3841
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by TryHard View Post
I'm currently running 450wt all round indoors, and probably wouldn't change it too much for outside
I've been in the 400-500 range for outdoors, with 550 for really high grip. Are people generally running the same weight oils all around or a bit thicker on front?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-03-2009, 02:39 AM   #3842
TryHard's Avatar
I tend to run slightly heavier in the front, mainly as I'm normally running a slightly stiffer spring up front as well. Usually only 5wt heavier though, don't think I've used more than 550wt anywhere.
Old 01-03-2009, 02:54 AM   #3843
In the Euros in Spain, the TRF team run 60 and 70 all arround.
70 when the track was hotter and 60 when was more cooler.
RFrancis is offline   Reply With Quote
Old 01-03-2009, 02:55 AM   #3844
ohhh
And HPI silver springs all arround
Old 01-03-2009, 05:27 AM   #3845
doriftu's Avatar
hi all,
I just completed my TRF416 WE and got a new lipo pack. I plan to add weights to balance the car.
Can someone share the 416's bare chassis weight?
Thanks in advance.
six-shifter.blogspot.com
supercharged-e36.blogspot.com
doriftu is offline   Reply With Quote
Old 01-03-2009, 10:42 AM   #3846
TryHard's Avatar
Originally Posted by doriftu View Post
hi all,
Thanks in advance.
I know with all my gear, I need to add around 160g of lead to the car to get to 1500g. I've listed all my items used below
Orion Carbon 3600
LRP Sphere TC
LRP 13.5 + LRP Motor fan (the BIG one ~35g)
Spektrum Pro Reciever,
Futaba S9550
MRT iPT
I was until recently running Ti and Aluminium screws on the car, then had a thought that I might as well change the Ti ones to steel. So all the lower deck screws are now steel, with the upper ones nice blue alloy. Helps to keep the weight low, think I was able to gain around 10g or so of weight by that.
HiH
Ed
Old 01-03-2009, 11:02 AM   #3847
Adam?'s Avatar
You should see the rip with an SMC or TP LiPo over the Orion! :O
Adam? is offline   Reply With Quote
Old 01-03-2009, 12:27 PM   #3848
SchuMi2's Avatar
Originally Posted by Vicko View Post
hey dose any one know the spring rates of the Hara's match springs in lbs?
are they the same as the normal HPI spring lbs with the same color?
thanks
66961 Yellow 230 12.89
66962 White 250 13.98
66963 Black 270 15.11
66964 Purple 290 16.24
66965 Red 310 17.36
Hope this helps
SchuMi2 is offline   Reply With Quote
Old 01-03-2009, 12:51 PM   #3849
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
black spring? are you sure its not blue ?
and you missed the gray spring ..
John St.Amant is offline   Reply With Quote
Old 01-03-2009, 12:55 PM   #3850
SchuMi2's Avatar
These are the Hara Springs. I didn't know there were more. If there is I don't have those numbers.
Old 01-03-2009, 01:17 PM   #3851
Oh .. my bad
Old 01-03-2009, 01:29 PM   #3852
RC MARKET's Avatar
Oh .. my bad
is around Front Gold , Rear Silver Spring
RC MARKET is offline   Reply With Quote
Old 01-03-2009, 02:37 PM   #3853
Xray To The Max's Avatar
Hey Guys,
I Thought i may be able to help you with Springs.
Brand/Colour......Comp./ Ratio
Hara Yellow..........12.89lb/230g
Hara Silver...........13.98lb/250g
Hara Black............15.11lb/270g
HPI Blue...............15.3lb/273g
Hara Purple...........16.24lb/290g
HPI Silver.............16.9lb/302g
Hara Red..............17.36lb/310g
HPI Pink...............18.0lb/320g
HPI Gold...............19.0lb/340g
HPI White.............20.3lb/363g
HPI Yellow............21.7lb/388g
HPI Red................22.4lb/400g
I Hope this Helps
Kind Regards,
Ryan.
Ryan Maker - Team Xray - Hudy - Speed Passion - Ko Propo - Ryan Dezign.
Xray To The Max is offline   Reply With Quote
Old 01-03-2009, 07:48 PM   #3854
Vicko's Avatar
Trader Rating: 14 (100%+)
Thanks guy thats helps alot.
also ran my 416wc frist time this weekend, my frist real race on rubber, carpet and won the B-main, which is great since I never really ran rubber
carpet before... I just needed more on-power steering when the traction came up to get into the A main....
Vicko is offline   Reply With Quote
Old 01-04-2009, 01:12 AM   #3855
Adam?'s Avatar
If you prefer your shocks with little to no rebound, the mod Corey suggested with a hole in the (plastic) cap is phenomenal. It makes things ridiculously easy, and screwing the cap on tight doesn't mess with things. I look forward to trying it on the track. So far, this is the best my shocks have ever felt.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
