Like Tree3Likes
Old 01-02-2009, 09:24 AM   #3826
TXwasabixx1's Avatar
hey guys can I use trf dampers on my tb03??
TXwasabixx1 is offline   Reply With Quote
Old 01-02-2009, 09:48 AM   #3827
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Yes, they should fit no problem.
Old 01-02-2009, 10:00 AM   #3828
Jimmy Jacobson's Avatar
Hey Tran What you talkin Long time no hear from you
Jimmy Jacobson is offline   Reply With Quote
Old 01-02-2009, 01:44 PM   #3829
DaveG28's Avatar
Trader Rating: 62 (100%+)
Hi all,
Sorry if this is somewhere further back in the thread but have a couple of questions about the Worlds Edition:
Is the new battery position optimised for Lipo? I have seen one shop claim so but Tamiya usa just say its a new position?
I am not a fan at all of Spools up front, from my vague recollections of the original 416 (sold it back in April!) to run a diff up front it is just identical to the rear diff but flipped over yeah for the pulley to line up correct with the belt?
From the pics have they gone for steel front driveshafts? I bent one of the lightweight ones from the original kit nearly every race!!
DaveG28 is offline   Reply With Quote
Old 01-02-2009, 01:54 PM   #3830
Adam?'s Avatar
Diff fits just fine up front, just flip it over.
Not sure if the new kit comes with steel driveshafts up front, but most of us bought them about 1 run after we got the car when we realized the aluminum ones don't work with boards. I've yet to bend a steel one.
With the short arms, you'll want 42's up front if you run a diff, otherwise they can bind on the t-nut.
Adam? is offline   Reply With Quote
Old 01-02-2009, 02:11 PM   #3831
DaveG28's Avatar
Hi mate,
Do you mean 42mm shafts? I was going to ask about which steel one's, I couldn't find any the right length when it first came out!
Old 01-02-2009, 02:25 PM   #3832
Originally Posted by habis View Post
Coating.....nothing else
And switched order of the o-ring and rod-guide for better support of the piston shaft.
Mr_Orange is offline   Reply With Quote
Old 01-02-2009, 02:53 PM   #3833
Adam?'s Avatar
Originally Posted by DaveG28 View Post
Hi mate,
When I use a diff, I use the 42mm steel shafts up front. With a one-way or spool I'll use the 44mm steel. I think when the car first came out, only 46mm were available, but we were able to use those with the one-way if you took the o-rings out.
TAM53501 - 42mm steel
TAM54078 - 44mm steel
TAM51092 - 46mm steel
These days, I run 42mm in the rear with the diff, and 44mm up front with the one-way.
Old 01-02-2009, 02:59 PM   #3834
brqsdad's Avatar
Adam? Are you going to make it to Cleveland for the Nats in March?
brqsdad is offline   Reply With Quote
Old 01-02-2009, 04:15 PM   #3835
Adam?'s Avatar
Nope, it's not in the racing budget this year. :-( I'm considering IIC again, but that's about it.
Old 01-02-2009, 04:52 PM   #3836
DaveG28's Avatar
Thanks Adam, looking to get back into touring and looking at different cars, got most of a 416 diff lying round already (outdrives, rings, pulley assuming they're 37t, maybe even the screw/nut) so wouldn't cost me much on top of the kit to get running!
Is the balance ok with using Lipo?
Old 01-02-2009, 06:06 PM   #3837
Adam?'s Avatar
LiPo balance seems to be okay, but you'll want to add weight to the battery side. What pack do you plan on running? I've used the SMC 5000's and 4000's with relative success, and will be trying the TP 40C's if they ever ship. For the taller packs, I shoo goo weights to the bottom of the pack that fit into the battery slots, which helps keep the pack in place. For the shorter packs (like the SMC 4000), I use one of the weighted plates that secures into the slots and just servo tape it to the pack. Then I line the outer side (and top) of the pack with tungsten weights to bring the car up to weight, and help balance that side.
http://www.ppdbillet.com/RC_accessories.html
http://maximum-velocity.com/tungstenplates.htm
Old 01-02-2009, 06:58 PM   #3838
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
hi guys, just would like to ask the part number of the 416 short arms, thanks
buboy28 is offline   Reply With Quote
Old 01-02-2009, 07:26 PM   #3839
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
53928
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 01-02-2009, 07:53 PM   #3840
buboy28's Avatar
Originally Posted by mok View Post
thank you very much now all i have to do is get those 42mm steel dog bones
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
