Old 12-21-2008, 06:51 PM   #3781
myan_gsr's Avatar
Hey guys,
Need a spur/pinion combo to acheive a FDR ratio of 3.9-4.4 (for silvercan). Does anyone know what will fit in there as the larger pinions seem harder to fit under the upper deck. 48P and 64P gearing options would be ace!
thanks in advance,
Steve
---Tamiya 416X---Tamiya TRF416WE---Tamiya TA05R---Tamiya F104 Pro ---Tamiya F103R 15th Anniversary ---Tamiya F103---Tamiya F103GT---Tamiya TL01---
www.brccc.org
myan racing (coming soon)
myan_gsr is offline   Reply With Quote
Old 12-21-2008, 11:58 PM   #3782
Stein Tumert's Avatar
Originally Posted by myan_gsr View Post
Hey guys,
thanks in advance,
Steve
Check TryHards Gearing sheet
http://www.thard.co.uk/viewtopic.php?f=24&t=31
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 12-22-2008, 05:19 AM   #3783
myan_gsr's Avatar
Cheers for that, just the info i needed, lets just hope I get the right combo
www.brccc.org
Old 12-22-2008, 01:30 PM   #3784
TryHard's Avatar
didn't manange to get the roll centre calculator fully sorted yet... need to take some measurements off my car first.
However, I do have a fully working example, with some guestimated values , updated the look a little bit, and added in an important setup change, which is the chassis thickness (after all, most of us set our ride-heights to the underside of the plate... extra thickness in the chassis will raise the rc).
I've attached the example below, along with the updated 415 version as well (it was a slow day at work...). That one does have all the correct measurements in it
I'll update the 416 as soon as I get a chance, but hopefully you can all see what I'm trying to acheive.
Cheers
Ed
Old 12-22-2008, 01:37 PM   #3785
minimusprime's Avatar
Trader Rating: 19 (100%+)
ed those zip files come up corrupt for me after i download them.
"I personally do not believe in luck. I believe luck is just an excuse for people that have failed in their mission to accomplish something." Allen McNish
minimusprime is offline   Reply With Quote
Old 12-22-2008, 01:53 PM   #3786
TryHard's Avatar
hmm, I'll try zipping them again, seem fine on my PC. Then again, I'm using 7zip, not winzip.
Try downloading them again now.
Regards
Ed
Old 12-22-2008, 02:06 PM   #3787
Regards
Ed
still corrupt.
Old 12-22-2008, 02:08 PM   #3788
CraigM's Avatar
Trader Rating: 34 (100%+)
416 one works fine for me
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 12-22-2008, 02:10 PM   #3789
i guess it's this crappy work computer. Carry on then nothing to see here.
Old 12-24-2008, 02:07 PM   #3790
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
TTT. Happy Holidays to my fellow 416ers.
Just to update everyone that I've been doing alot of testing on my local track, mainly testing on shock rebounds and have come to the conclusion that putting a 1mm hole on the shock cap and using different size spacers to change rebound is alot more accurate, alot easier to change setup when needed, less messy and economical as you don't have to top up oil everytime. Thanks to the person (Corey "Whitey" Whiteman) that suggested this method.
Ive done close to 30 packs this week alone (6 mins each) running a 4 turn motor and I can't believe how strong the drivetrain.
Next test will be how the 2.5mm chassis compares to stock 2.25mm
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 12-24-2008, 02:42 PM   #3791
HI_808's Avatar
Do you race on carpet? I was wondering if the vent hole works on asphalt as well.
HI_808 is offline   Reply With Quote
Old 12-24-2008, 02:45 PM   #3792
danjoy25's Avatar
I race asphalt. The mod should work as it makes adjusting rebound easier and more accurate than other methods. You can start running full rebound by using a thicker spacer and fine tuning by running thinner spacers if you want more grip by just taking the shock cap without disturbing the seal which makes it less messy and cheaper as you don't use oil everytime.
I suggest you buy 2 packs of the Vparts as you get the 2 plastic shock caps on each packet and you can experiment.
Old 12-24-2008, 07:24 PM   #3793
ali_g's Avatar
In all honesty (and this has been pointed out before) your not gonna see a huge difference between a WE car, and one that has been given all the "regular race" parts (short arms, gut top deck etc).
Simply put the WE is supplied to mimic the current setups most of us run, whereas the original 416 was supplied with parts most people don't sue any more (Long arms, one way etc).
Is it worth it... if you have a fully hopped up 416, probably not. If you don't have one, then it's certainly a more sensible buy than an original 416.
HiH
Ed
TryHard, u ever list the difference between the two version of 416 & what is required to convert the normal 416 to a 416we
ali_g is offline   Reply With Quote
Old 12-25-2008, 12:59 AM   #3794
TryHard's Avatar
not as of yet... but it's something I should do
I'll give a crack some time in the new year, plenty of stuff to be getting on with for the site now
But as a quick one... if you have a 416 already with a spool, short arms etc, then all thats really different on the WE are the top deck, chassis plate, belts and motor mount. Thats it.
As mentioned before, IMO, none of thoose are the be all and end all... the top deck and possibly the chassis plate would be the two biggest performance enhancers (cells are further forward on the WE, so should help with steering).
HiH
Ed
Old 12-26-2008, 10:01 AM   #3795
TryHard's Avatar
I've added a WE info link on the site now... might try and do a conversion guide later when I get some more time.
Anyway, I've just updated the suspension block chart, added in an extra table with partnumbers for all the relevant blocks.
http://www.thard.co.uk/viewtopic.php?f=24&t=30
HiH
Ed
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
