Old 12-19-2008, 12:30 PM   #3751
RC MARKET's Avatar
Originally Posted by Rogier View Post
Yes yes yes I know, but that's not an answer on my question...
i'll try check tomorrow
RC MARKET is offline   Reply With Quote
Old 12-19-2008, 01:18 PM   #3752
wide_mouth_frog's Avatar
dont feel bad, no one answered mine either lol
Team Wave - absdesigns.co.uk - Selections RC
wide_mouth_frog is offline   Reply With Quote
Old 12-19-2008, 02:02 PM   #3753
TryHard's Avatar
Can someone tell me the advantages of the new WE motor mount? And does this new mount fit on the 'regular' 416 without modifications?
It's a more secure mounting for the motor mount (two screws and an L shaped bracket), and slightly different shape against the motor side... having said that, in all honesty, I really don't think it's a vital part to have, unless your running mod all the time. And yes, it will fit the "regular" 416 fine
HiH
Ed
Old 12-19-2008, 02:05 PM   #3754
TryHard's Avatar
Originally Posted by wide_mouth_frog View Post
HI boys,
What is the dissadvantage of running the Ally uprights, hubs etc???
Cheers
they bend... rather have a cheap plastic part break fully, rather than bend and not spot the problem!
I had a big issue with the C-hubs on the 416 to start with, seems like the carbon ones are a bit brittle. Went for a while running 3-racing alloy ones until I spotted one had bent, then switched to normal plastic ones... haven't had an issue since, not broken a single one!
Having said that, they look good....
HiH
Ed
Old 12-19-2008, 02:10 PM   #3755
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Also, with the plastic parts being able to flex, they generally will give you more traction.
Old 12-19-2008, 02:50 PM   #3756
SammyZ's Avatar
Trader Rating: 138 (100%+)
when they bend you just replace it, i never even noticed a driving difference when mine were bent, way better than snapping a plastic one and then pulling the car off the track.
SammyZ is offline   Reply With Quote
Old 12-19-2008, 03:43 PM   #3757
TryHard's Avatar
Personally, I would rather it break. I spent a while chasing a setup issues before I spotted the bent C-hubs. It wasn't bent by much, but it made a big difference to how the car handled (as you'd expect with 6deg castor one side, and 4 the other ). For steering components at the very least, I'll stick with the plastic
Anyway, if your gonna replace it anyway, why not replace the 4 plastic part rather than teh 15 alloy bit?
Old 12-19-2008, 03:53 PM   #3758
Adam?'s Avatar
If you can make the IFS c-hubs work with your setup, they're basically indestructible! :-) Sloppy, for sure, but I've never had one break. They give a bunch of steering, too.
Adam? is offline   Reply With Quote
Old 12-19-2008, 04:03 PM   #3759
Hebiki's Avatar
Trader Rating: 26 (100%+)
stop posting and get to work on that 416 roll center calculator.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-19-2008, 04:48 PM   #3760
Stein Tumert's Avatar
Originally Posted by STLNLST View Post
There isn't a brushed 27T that can keep up with some of the 13.5 I have run. It would take Dieter, Reedy, Howart, and EA to make that happen
What is your gearing (final drive ratio) and how much RPM does your 13.5T do?
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 12-19-2008, 04:56 PM   #3761
STLNLST's Avatar
Trader Rating: 19 (100%+)
Depends on the track layout but I mostly run 4.6 FDR. I'm not too sure of the RPM since we don't have a way to really dyno these brushless motors.
STLNLST is offline   Reply With Quote
Old 12-19-2008, 11:54 PM   #3762
sakaguchinet's Avatar
Send a message via ICQ to sakaguchinet Send a message via AIM to sakaguchinet Send a message via Skype™ to sakaguchinet
Hi,
@Bent Aluminum Parts:
Try to leave one "weak part", then you never will have problems with bent Knuckles or Rear Hubs. I only use the front Aluminum Knuckles and rear Aluminum Hubs (0), and had never a problem, because these 2 parts are the most massive ones.
@New Motormount:
When driving a 2.5T BL there were issues with bent Motormounts. So Tamiya reinforced them in order to get even those "freaks" happy. In my oppinion it is a very nice solved and technically "WOW" solution - (when looking at the very precise fit of the L-Bracket).
Best Regards,
Dai
http://www.rc-square.de (German and English manufacturers site)
http://www.sakaguchinetshop.com (Tamiya TRF related stuff)
sakaguchinet is offline   Reply With Quote
Old 12-20-2008, 12:37 AM   #3763
kentech's Avatar
Totally agree!
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 12-20-2008, 12:40 AM   #3764
TryHard's Avatar
Originally Posted by kentech View Post
Totally agree!
+1
Old 12-20-2008, 01:44 AM   #3765
RC MARKET's Avatar
Tamiya TRF416 / TRF416WE / TRF416X-dsc05773s.jpg
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
