Old 12-09-2008, 03:45 AM   #3601
chrisk's Avatar
Trader Rating: 32 (100%+)
from one page back
Here's the front & center one-ways at pretty good prices. This seller also ships very quicly (less than a week from Japan to US)...
http://stores.ebay.com/Rdvtg-Hobbies...ftidZ2QQ tZkm
The part number the 415 "bridge" mount 1D is: 51064
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 12-09-2008, 03:48 AM   #3602
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by ioxqq View Post
I'm interested in getting a front oneway set for the 416. Want to know what is the part number? thanks
i got one i wont need. want to buy it?
my 416WE is almost done.. just need to do the rear hubs and steering knuckles. cant wait to drop in my Ko Propo BL ESC!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-09-2008, 03:54 AM   #3603
zacabrandy's Avatar
Originally Posted by veecee View Post
Aaron, if you are getting a WCE you will already have the spool and short arms. The only things worth picking up would be some HPI springs in Silver, Blue and maybe Pink as well. The 416 wins races on every surface. The only surface where it hasn't taken a big win is foam carpet, although I might be wrong...
Aaron, the results pretty much speak for themselves... and not just on the international stage, it goes very well in a clubmans hands. Veecee's right though, with a WCE car, you have pretty much everything in the box. Only things I would suggest are;
Spring set's - HPI Blue, Silver, Gold, Pink as well as the Tamiya spring set are pretty much all you need. I seem to struggle a little with the feel of the HPI's indoors, and prefer the Tamiya's for that
Roll bar set - Just gives you all the options, although most run Medium front, and soft or medium rear all the time
Some extra suspension blocks - more for reducing the rear toe-in than anything.
And thats about it... the car really does work very well, and all the tuning options are more than anything refinements.
Oh, and if anyone hasn't seen, the 416 wce manual is now online...http://www.tamiya.com/japan/download/rc_index.htm
Regards
Ed[/QUOTE]
Thanks guy's for your replies.
I'm not completely sold on this car yet as there is no support for it in S.E Queensland, but I know of one 416 being used and it seems to have helped that racer to jump up a level with his racing. If I were to change over to this chassis, where is the best place to get parts from for it. Both in Aus and online.
As for the springs, why do you use HPI springs instead of the Tamiya one?
Cheers
Aaron
zacabrandy is offline   Reply With Quote
Old 12-09-2008, 04:28 AM   #3604
veecee's Avatar
Trader Rating: 34 (100%+)
Spares in Oz are hard to come by. I normally buy my spares from RC-Model (http://shopping.rcmodel.hk/). Others also use RC Market (http://rcmarket.com.hk/) and RC Champ. Generally the only spares needed are arms, castor blocks and rear hubs - all of these can break when you hit a board. Just stock up on a few of these bits when you buy the car and you'll be sweet. I have been running the car for almost a year and I'm still on original belts and pulleys. I haven't even had to rebuild the diff although I built them up with ceramics balls and adhesive backed diff covers. The 416 is an awesome car and with all the help on this thread, you will also have a great knowledge base to back you up.
The HPI springs have been used by the team drivers with some success. A few of us here have also tried them and they feel a little nicer - some say more progressive than the Tamiya springs. I have been running the HPI Blues all round lately and the car feels glued with them.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 12-09-2008, 04:33 AM   #3605
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
I've only started running the 416 a few months ago and would recommend Hongkong shops like rcmarket, precisionrc or rc-mushroom. Champrc is also good but with the exchange rate with the yen. Hongkong shops are better price wise.
If you get stuck you can also get parts from Castlehill hobbies in Sydney but they are more the generic Tamiya stuff that was use in the 415 and is also used in the 416.
Not sure about the spring as I only used the White Tamiya stuff for now.
I have a question to the 416 pros here.
Whats the pros and cons of upgrading to a 2.5mm chassis. I know the thicker the chassis the less flex = less grip.
I order and paid for a 2.25mm chassis but got a reply from the shop saying they forgot to update stock and has sold out but his willing to send me a 2.5mm chassis instead.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 12-09-2008, 06:08 AM   #3606
Low_E's Avatar
Send a message via MSN to Low_E
IMHO, the 2.5-chassis might perform better on carpet, in high grip situation.
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 12-09-2008, 06:42 AM   #3607
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Or you could run softer springs, lighter oil and use bigger sway bars.
John St.Amant is offline   Reply With Quote
Old 12-09-2008, 07:16 AM   #3608
Low_E's Avatar
the reversible suspension arms that are used on the WE, of which car do they come, or are these brend new?
They seem larger, as there are less shims on the suspension-shafts, larger the the ones I use (TA-53928 Short Reversible Sus Arm ) ... or am I wrong?
nope, I'm wrong. They are the same (tam 53928)
Old 12-09-2008, 08:10 AM   #3609
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I really wouldn't recommend PrecisionRC, I ordered 10 pairs of Sorex tires on their site and they sent 1 pair, I've tried to contact them, but no reply at all. My buddy Patrick had a similar situation happen with them some time ago.
Old 12-09-2008, 09:33 AM   #3610
Koen's Avatar
Oeh, I am not very happy to hear this. Two days ago I've ordered a 416Worlds and for over 200 dolars of spares at precisionRC. Payment is already done...
If someone has a better experience with precisionRC please tell me to take away my bad feelings
Koen is offline   Reply With Quote
Old 12-09-2008, 09:38 AM   #3611
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i have ordered from precision in the past with good results... some tools, tires, parts.... a tad bit slower to ship compared to Champ and RCMarket, but no serious problems.
but, it has been a while, maybe 6 months.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 12-09-2008, 09:52 AM   #3612
Koen's Avatar
thanks for the response, I feel a bit happier now But after reading this tread:
Precision RC? Reputable? I'm still not sure about my order...
Old 12-09-2008, 10:02 AM   #3613
I've ordered from them in the past without problems, one time they forgot to send an order but replied quickly and sent it the same day when I asked where it was. This last time they screwed me for just over $90 though.
Ordering from some of the overseas sites can be a pain in the ass, I've tried to order from other sites but they want a copy of your ID, proof of residence, etc.
Old 12-09-2008, 10:12 AM   #3614
Adam?'s Avatar
For the unsponsored in the US, that's pretty much a way of life if you want to run Tamiya.
Adam? is offline   Reply With Quote
Old 12-09-2008, 10:15 AM   #3615
Koen's Avatar
well I keep my fingers crossed then...
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
