Like Tree3Likes
Old 11-26-2008, 11:22 PM   #3451
RC MARKET's Avatar
Originally Posted by or8ital View Post
How much in USD?
This weekend FRI-SAT arrive !
pre-order now !
RC MARKET is offline   Reply With Quote
Old 11-27-2008, 12:04 AM   #3452
the 3.5 degree toe as std is interesting, i have ran 3.5 before, but it tends to overheat the rears towards the last few laps.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 11-27-2008, 01:57 AM   #3453
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
On the Team Magic set up station my current setup reads on 3.5mm toe already (xa & e) so this it will be alot closer to 4mm toe.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 11-27-2008, 02:56 AM   #3454
CraigM's Avatar
Trader Rating: 34 (100%+)
Even more interesting because they were running xa/e at the worlds
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 11-27-2008, 08:10 AM   #3455
quantum's Avatar
Originally Posted by RC MARKET View Post
Servo Horn
i think jimmymac will be very happy to see this lol
quantum is offline   Reply With Quote
Old 11-27-2008, 09:04 AM   #3456
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by TryHard View Post
actually john to be pedantic.. the very first 415 (TAM58320) came with the 414/TA04 style suspension, which did have the 1150 bearings, which is what I was refering to in my post
All the cars from the MS (TAM49349) onwards with the Lwt reversible suspension had the 950's.
The castor blocks etc are all the same as on the 416, 05IFS-R and TB03. All the different suspension types can get confusing...
TRF414 (and derivatives), TRF415, TA04, TBEvo3, TA05 - 1150 bearings, non reversable arms
TRF415 (MS, MSX, MRE, MSXX & MSXX MRE07), TBEvo4 (& MS), TA05 R & MS - LWT reversible, 950 bearings
TA05 IFS - LWT reversible, 950 bearings, but with 416 style castor blocks
TBEvo5 - Short LWT reversible, 950 bearings
TRF416 - LWT reversible, 1050 bearings
TRF416WE, TA05 IFS-R, TB03 IFS, TBEvo5MS - Short LWT reversible, 1050 bearings
The only thing you need with the suspension set is dogbones, which given the myraid of options in the tamiya world (48mm, 46mm, 44mm, 42mm) to suit different cars (such as the TA05, TB03, 415, 416, evo5 etc) is probably a wise idea. Nothing else is needed.
I only suggest running the 42's on the rear to avoid any chance of the blade hitting the diff nut, otherwise you can stick with the 44's and just clear.
Ed
I just measured my 05 and TRF415msxx and they both have different axels and 9x5 bearings.. I wouldnt know about the 414. But like i said b4.. thanks for the info...
John St.Amant is offline   Reply With Quote
Old 11-27-2008, 09:14 AM   #3457
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
yea, Ed's pretty well spot on with that info, other than leaving out the 50mm cvd bone option from the F201. had to use those long ago when using the old Yokomo diff in the front, before there was an optiong for a spool, or even a factory made diff.
your MSXX might have had those gold colored lightweight axles, might be the difference.
have owned most all those up to the IFS/TB03 stuff. havent really tried those yet.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 11-27-2008, 09:42 AM   #3458
Gold axels ? Ti- tri nitrated coated hinge pins yes... blue alum. cvd,s rear , black metal fronts. I bought the titaniun axels... wow what a difference ! Almost no rotating mass.. w/o tired of course . LOL I tricked that friggin thing out . I should keep it and run it T/A style if they'd let me.
And I totally miss my R32..... never shoulda sold it!
Old 11-27-2008, 01:01 PM   #3459
kentech's Avatar
Someone asked for the TRF416 parts list a couple of days ago.
I just scanned and uploaded the pages from the manual here: http://kentech.blogs.se/
Build pics and comments coming hopefully this weekend.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 11-27-2008, 01:11 PM   #3460
miccal's Avatar
Trader Rating: 23 (100%+)
That was me, and thankyou so much. But it says I need to log on to download it?
miccal is offline   Reply With Quote
Old 11-27-2008, 01:53 PM   #3461
kentech's Avatar
Sorry bout that...should work now...
Old 11-27-2008, 02:16 PM   #3462
94eg!'s Avatar
Trader Rating: 17 (100%+)
More like bronze, they are aluminum with a hard coating. They knock another 25% off the mass of the expensive titanium axles. Rather unpopular though as they are soft and get damaged easily. They were standard equipment on the MSX-MRE only and an easy drop-in option for all the other cars with the 950 wheel bearings...
94eg! is offline   Reply With Quote
Old 11-27-2008, 02:45 PM   #3463
JimmyMac's Avatar
haha, Damn, someone actually remembers me! haha. I haven't raced since April! My car has been sitting on the self, and I haven't even unpacked my stuff since April! But I have been reading here off and on. And I did get excited to see the servo horn! haha. Right now (or back in April), I ran the aluminum horn and spring set from uhh.... damn, who made it... uhhh, some hk or jp company. Speed something, But anyways, it had a lot of slop in it. So I superglued it all together. No more slop! It's almost like running a direct servo horn, but it will give under a crash.
Anyways, I've been busy here with college and playing with my real car. Getting too cold for asphalt racing. Maybe I'll make it out early next year. I do need to cycle my SMC lipo packs. It'll be a good long term storage test to see how they have held up to 7months of storage with no use.
Well it's good to see some of the same ole Tamiya supporters here, as well as a few boneheads! haha
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 11-27-2008, 03:35 PM   #3464
RC MARKET's Avatar
Old 11-27-2008, 03:38 PM   #3465
miccal's Avatar
Thanks, could you explain how the new motor mount and center post are attached? If the center post is vertical and connects to the new hole in the motor mount, won't it hit the belt?
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
