Old 11-21-2008, 03:29 PM   #3391
94eg!'s Avatar
Trader Rating: 17 (100%+)
Yes, both the milky blue and white spring sets are same standard length springs. They can be identified by a small colored dot at the bottom of the spring. I use the white set, so the car looks nice...
94eg! is offline   Reply With Quote
Old 11-22-2008, 11:48 PM   #3392
Trader Rating: 22 (100%+)
Craig M, veecee or Bersercoe do any of you have a setup for Whalen I think it is. That is the new sydney track with high grip so I am led to believe.
I have the metro masters in melbourne next weekend as I hear these tracks are of similar grip level. Havent had any chance of a run due to the weather do you guys have any advice?
bjspinner is offline   Reply With Quote
Old 11-23-2008, 12:44 AM   #3393
veecee's Avatar
Trader Rating: 34 (100%+)
Craig has a setup for Whalen here - http://www.thard.co.uk/
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 11-23-2008, 04:40 PM   #3394
TryHard's Avatar
Current Tamiya Spring ratings in lb's (thanks to Linger)
Milky blue White (Extra Hard) = 17.1
Milky Blue Blue (Hard) = 14.9
Milky Blue Yellow = 13.1
Milky Blue Red = 11.53
This would be the same for the white coloured set too.
Now for the standard coloured set, I'm not too sure if the whites (extra hard) are the same... as Ling noticed there was a reduced coil count on the the milky blue (and white coloured) springs over his original testing of the whites. This increases the stiffness from 15.3 to the 17.1 noted above.
The other springs in all three sets should be similar however, it's just the whites that seem to have changed
As for the shorts... ignore them, they are really for the mini's
HiH
Ed
Old 11-24-2008, 04:20 AM   #3395
doriftu's Avatar
what is the center one-way for?
do i have to use the center one-way with the front one-way?
six-shifter.blogspot.com
supercharged-e36.blogspot.com
doriftu is offline   Reply With Quote
Old 11-24-2008, 04:50 AM   #3396
sakaguchinet's Avatar
Send a message via ICQ to sakaguchinet Send a message via AIM to sakaguchinet Send a message via Skype™ to sakaguchinet
Hi,
Center OW brings more aggressive steering.
The reason: Due to the disconnect between center shaft and the front axle the front axle won't rotate when rolling (off power!). So there will be no stabilizing effect because of turning mass. Better to use Center OW in combination with Front OW to have the maximum steering effect.
Best Regards,
Dai
http://www.rc-square.de (German and English manufacturers site)
http://www.sakaguchinetshop.com (Tamiya TRF related stuff)
sakaguchinet is offline   Reply With Quote
Old 11-24-2008, 06:44 AM   #3397
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by sakaguchinet View Post
Hi,
Well put my good man! I love a one way diff as it does not spool up if you bicycle and can always put the power down. The center one way increases the efficiency of the drive system and coasts a lot better ! I use both one ways in my 416 . They allow all 4 wheels to spin at different speeds. W/O the center one way , only 3 tires will rotate differently.
John St.Amant is offline   Reply With Quote
Old 11-24-2008, 08:06 AM   #3398
Send a message via MSN to jontang001
My new weapon for next 2 season...hop there will not come out another new edition during next 2 season...
Tamiya TRF416 / TRF416WE / TRF416X-dsc01724.jpg   Tamiya TRF416 / TRF416WE / TRF416X-dsc01725.jpg
TAMIYA TRF416, EVO5MS, TB03 FullOP
Schumacher Mi4LP, CAT SXII, Cougar
jontang001 is offline   Reply With Quote
Old 11-24-2008, 08:37 AM   #3399
Low_E's Avatar
Send a message via MSN to Low_E
I'm most interested in this manual.
Is there an online version yet??
I would realy like to know what the standard setup is for this car.
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 11-24-2008, 10:17 AM   #3400
Hahahahh guess..
40 wt and 2 hole
yellow springs...
camber and toe rods way off but equal..
just like the last 17 kits.
Old 11-24-2008, 10:56 AM   #3401
94eg!'s Avatar
Yeah....What did the suspension blocks end up being?
Old 11-24-2008, 12:39 PM   #3402
kentech's Avatar
Suspension blocks are C-C and XA-F (for 3.5 deg toe)
Springs are blue-yellow
Pistons are 3 hole
Roll centre spacers (53932) included
Serrated (Square) wheel nuts
Extra outdrives included with spool
New motor mount and centre post looks great
That's just a few first impression comments...look for a build "review" on http://kentech.blogs.se in the next week or so...
Tamiya TRF416 / TRF416WE / TRF416X-img_6260.jpg   Tamiya TRF416 / TRF416WE / TRF416X-img_6266.jpg
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 11-24-2008, 12:55 PM   #3403
Awesome ! Looks like a normal setup for a change .. And I bet it'l work well on the carpet too. Does it have sway bars ? medium in front and soft in back? Glad they squared up on the front blocks. I might have to try the c's instead of the d's I have now.. since the arms are shorter is there a spacer or 2 outside the wheel adapter , or a wider adapter?
Old 11-24-2008, 01:16 PM   #3404
kentech's Avatar
Roll bars are medium front and soft rear (black coloured) just like on the original 416
Wheel hubs are the same (4mm), 0.5 and 1mm spacers included, manual shows 0.5mm used at the front
Rear swing shafts are 42mm
TRF teflon sealed bearings included
Oil is normal yellow #400
Some new part numbers:
54143 new front belt
54144 new rear belt
54145 new larger urethane black bumper
Old 11-24-2008, 01:36 PM   #3405
Sweet .. ty !
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
